'02 Tundra heater not getting warm
Discussion in '1st Gen Tundras (2000-2006)' started by sfagrad83, Mar 15, 2016.
  1. Mar 15, 2016 at 5:53 AM
    sfagrad83
    sfagrad83 [OP] New Member
    Paul
    2002 Tundra 2WD
    This just started a few days ago, but the heater in the cab of my truck has lost its ability to get warm. Any ideas what might be causing this problem?
    Thanks,
    Paul
  2. Mar 15, 2016 at 6:00 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Have you checked coolant levels, and leaks?
  3. Mar 15, 2016 at 7:38 AM
  4. Mar 15, 2016 at 7:52 AM
    sfagrad83
    Paul
    2002 Tundra 2WD
    Cause and/or remedy?
  5. Mar 15, 2016 at 8:03 AM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Thermostat stuck? Does it get hot or how does the temp gauge look?
  6. Mar 15, 2016 at 8:03 AM
    sfagrad83
    Paul
    2002 Tundra 2WD
    How can that be checked?
  7. Mar 15, 2016 at 10:13 AM
    sfagrad83
    Paul
    2002 Tundra 2WD
    What temp thermostat for '02 tundra 4.7 v8?
  8. Mar 16, 2016 at 11:12 AM
    garnaz
    garnaz New Member
    Heater control valve?
  9. Mar 16, 2016 at 12:39 PM
    sfagrad83
    Paul
    2002 Tundra 2WD
    A/C blows cold. Replaced thermostat and still no warm air.
  10. Mar 16, 2016 at 12:40 PM
    sfagrad83
    Paul
    2002 Tundra 2WD
    Coolant levels are perfect and no leaks. Replaced thermostat and still not warm air.
  11. Mar 16, 2016 at 12:42 PM
    Virgils12
    Are you sure your blend door is working correctly?
  12. Mar 16, 2016 at 7:33 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Da da da daaaaaaaaaaaaa
    Not lol. No expert here.... just work on these pieces of crap;)
    Do u have no coolant problems? Engine runs fine and gets to proper Temps?
    What does ur temp know feel like? Really easy to spin? Really stiff?
  13. Mar 16, 2016 at 7:35 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
  14. Mar 16, 2016 at 7:37 PM
    sfagrad83
    Paul
    2002 Tundra 2WD
    To tell you the truth, NO. Is there an easy check?
  15. Mar 16, 2016 at 7:44 PM
    sfagrad83
    Paul
    2002 Tundra 2WD
    I just watched a youtube video on flushing a heater core, and I plan on trying that tomorrow. Thanks.
  16. Mar 31, 2016 at 11:57 AM
    sfagrad83
    Paul
    2002 Tundra 2WD
    Yes. I took the part of the dash out and checked. I have replaced thermostat and flushed heater core twice, and still no heat. I have no leaks and have plenty of coolant. I checked the valve, and no leaks and it opens and closes as it should. I am completely stumped.
  17. Mar 31, 2016 at 11:58 AM
    sfagrad83
    Paul
    2002 Tundra 2WD
    Yes it is working properly. I have replaced thermostat and flushed heater core twice, and still no heat. I have no leaks and have plenty of coolant. I checked the valve, and no leaks and it opens and closes as it should. I am completely stumped.
  18. Mar 31, 2016 at 12:35 PM
    sfagrad83
    Paul
    2002 Tundra 2WD
    Knob feels fine. And the control valve is working properly. I took both hoses loose and watched the valve operate. Opens and closes just fine. Dampers are working too. Baffled.
  19. Mar 31, 2016 at 1:03 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Pro Comp Lift, towing mirrors, Fuel rims, Toyo A/T, Nav, Viper remote start
    my old silverado stopped working too. I found out the radiator had a leak at some point the previous owner put the stop leak stuff in it. It clogged the heater core. I replaced the core and it was new again.
  20. Mar 31, 2016 at 5:25 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    No you need to look on the drivers side of the heater box down by the gas pedal. Turn the temp knob and see if the blend door is moving while u turn.
  21. Apr 11, 2016 at 6:36 PM
    sfagrad83
    Paul
    2002 Tundra 2WD
    "Check Engine" light came on today. Code: P0770 indicates a fault in the A/T Shift Solenoid "E" (SL) Malfunction (Mechanical). What's the best/worst case scenarios here?
  22. Apr 11, 2016 at 6:57 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Bet case scenario is there is chewed wires near the trans. Worst case scenario is you need a trans
  23. Aug 11, 2019 at 11:50 AM
    Levijack01
    Levijack01 New Member
    william
    2002 toyota tundra 4x4
    I have the same heating problem. I did every thing you did. If you have found the fix for the heating problem, let me know on her. levijack01 or email levijack100@windstream.net Thanks
  24. Aug 13, 2019 at 11:15 AM
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Solenoid isn't normally a shot tranny. I replaced mine and have had zero issues since. Make certain you have the same tranny (there is a sticker on the drivers side door frame that shows which model you have)
    I used the below solenoids for my truck!
    https://www.amazon.com/gp/product/B01EOAWHNO/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    This listing states that these do not fit my transmission, however upon inspection of the solenoids I was able to confirm without a doubt these are correct. Been running them for over 6 months and no problems. For the price, it's not a bad place to start...
