MORIMOTO XB LED HEADLIGHTS 16+
Discussion in 'Lighting' started by eledobleu, Feb 13, 2019.
Thread Status:
Not open for further replies.
  1. Aug 12, 2019 at 6:37 PM
    #241
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    Can we get a comparison between the 2018 led lights and these morimoto
  2. Aug 12, 2019 at 6:40 PM
    #242
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    I thought so, i run a 3 in lift. so mine was always set at 2 and a half-ish
    Thanks!
  3. Aug 12, 2019 at 6:42 PM
    #243
    YotaMan
    Colorado Springs
    2021 Platinum
    These headlights outperform anything Factory LED Toyota can come up with for now. No discussion needed
    TheBeast and TRD_femi like this.
  4. Aug 12, 2019 at 6:58 PM
    #244
    TheBeast
    TheBeast The Beach
    did they mention working on a gen 2 version :)
  5. Aug 12, 2019 at 7:26 PM
    #245
    americanaaron
    americanaaron USA
    North Carolina
    2019 Tundra
    I wonder if you buy a set now while they still send error screen would they compensate some $$ after purchase?
  6. Aug 12, 2019 at 7:30 PM
    #246
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    Look what came by way of UPS!!
    1UPPER, SpeshulED, YotaMan and 7 others like this.
  7. Aug 13, 2019 at 12:50 PM
    #247
    gruntyota
    gruntyota New Member
    Mason
    2015 MGM Crewmax
    The only problem I am having is the sequential turn is hyper flashing. I suspect it is due to an impedance issue with my winjet tail lights. So for now I have it set up as a conventional blinker.
    Texas Bandit, 1UPPER, YotaMan and 2 others like this.
  8. Aug 13, 2019 at 1:15 PM
    #248
    djhase
    djhase member
    Southern Illinois
    2019 Silver Tundra TRD
    I am pretty happy with the performance of my factory LED headlights. Certainly happy enough to keep them for what these would cost to replace them. Now if I had the old halogen then I might consider them. They are awesome looking headlights and the blinkers are pretty cool too.
  9. Aug 13, 2019 at 1:56 PM
    #249
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    Has anyone with OEM LED DRL installed these? I have a 14 platinum with the LED DRL and the instructions don’t seem to be correct. It seems like the instructions are switched for the two models.
    I’ll attach a picture of my factory harness and the harness I’m supposed to use.
    ryanwgregg likes this.
  10. Aug 13, 2019 at 2:12 PM
    #250
    MMichaelJJ
    14 Platinum CM
    Everything seems to work like it’s supposed to when I wire up my truck that DOES have LED DRL per the instructions for the models that do NOT have LED DRL.
    The picture shows what’s hooked up. It’s a bit cluttered, but I pointed to everything.
  11. Aug 13, 2019 at 2:15 PM
    #251
    MMichaelJJ
    14 Platinum CM
    One tab per light is off too. They bend into place, but I think it’s weird it didn’t fit like OE.
  12. Aug 13, 2019 at 2:32 PM
    #252
    phabej
    phabej New Member
    2018 Platnium
    wow.. WAY OFF! not just by a few millimeters. That's like an inch or more.
  13. Aug 13, 2019 at 2:33 PM
    #253
    MMichaelJJ
    14 Platinum CM
    I was using VLEDs Triton turn signals with my last set of heads with one of their load resistors. I had them hooked up in the back of the truck in addition to the load resistors that were installed with my aftermarket LED tails.
    My sequential turn signals work @gruntyota
    1UPPER and ryanwgregg like this.
  14. Aug 13, 2019 at 2:36 PM
    #254
    MMichaelJJ
    14 Platinum CM
    They push down easily. Still weird they didn’t fit better.
  15. Aug 13, 2019 at 2:52 PM
    #255
    gruntyota
    Mason
    2015 MGM Crewmax
    Yeah I figured I would need to pick up a set for the tails.
  16. Aug 13, 2019 at 4:02 PM
    #256
    MMichaelJJ
    14 Platinum CM
    I’m a little curious about this step since I have LED DRL prewired for my platinum. I’m going to confirm with TRS that it’s a necessary step.
    After getting everything hooked up I unplugged the fuse tap. Everything seemed to work like it did with it plugged in. Maybe it should be just for the trucks that don’t have LED DRL?
  17. Aug 13, 2019 at 4:23 PM
    #257
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    2016 Magnetic Grey Tundra TSS
    Toytec 2.5” Coilover boss suspension 3/1 lift w/camburg uca’s Morimoto xb headlights Morimoto fog Rough country grill 2 RC blacked light bars Volant air intake system Rear air bags (for towing) I’m sure there’s more but I’m lazy
    Maybe due to shipping and the plastic got hot on the way to you? I’d call whoever ya got them from because they fit like oem.
  18. Aug 13, 2019 at 4:24 PM
    #258
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    Trs10 also gives you a 10% off on theretrofitsource.com
    Flyinryank likes this.
  19. Aug 14, 2019 at 2:57 AM
    #259
    gruntyota
    Mason
    2015 MGM Crewmax
    How much adjusting did you have to do? I swear mine are both straight to the ground. It is not the leveling switch. At 20 feet the beam is where the wall meets ground.
  20. Aug 14, 2019 at 4:48 AM
    #260
    coTony
    Tony
    Montrose, CO
    getting me interested... got to have something attract me away from my 2018 Platinum OEM's. I had a pair of aftermarket headlights that fit like that with having to bend the mounting point to the connection point and it fit ok but it did end up breaking right where it was stressed from bending.
  21. Aug 14, 2019 at 6:10 AM
    #261
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    TRD_femi, did you swap your OEM TRDP headlights for these Morimotos? I was wondering if these were PnP for trucks equipped with halogen lights and amber DRL?
    gruntyota, same question to you. What trim level / headlights did you swap out for these? I thought I read originally these were for trucks equipped with LED DRLs, but looking at the instructions others have posted, it seems to be PnP for any.
  22. Aug 14, 2019 at 6:13 AM
    #262
    gruntyota
    Mason
    2015 MGM Crewmax
    My 2015 SR5 came with the non drl halogens. However I am coming from a set of custom retrofits to these.
  23. Aug 14, 2019 at 6:28 AM
    #263
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    looking at the instructions again, you had to swap the relay under the dash?
  24. Aug 14, 2019 at 6:38 AM
    #264
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    I haven't installed them yet, I'm toooo busy admiring it's good looks!
  25. Aug 14, 2019 at 8:15 AM
    #265
    MMichaelJJ
    14 Platinum CM
    I just talked to TRS and I think they’re going to have the instructions updated. A couple things...
    The DRL fuse tap isn’t necessary for the people who have LED DRL from the factory. Trucks that are prewired for it can power the LED DRL and turn signals in the Morimoto lights.
    The instructions right now say trucks with and without OEM LED DRL. I wired the lights using the instructions that for trucks WITHOUT OEM LED DRL, but my truck came prewired (platinum) for the LED DRL.
    The included adapter is if you have the multipin connector or the H4 hi/low. The other adapter is if you need to swap wires for the turn signals. I’m pretty sure the people with OEM LED headlights are the ones that need to use the harness. The people who went from halogen to LED headlights will know what I’m talking about. We had to use an adapter or repin to make the turn signals work.
    I hope this helps.
  26. Aug 14, 2019 at 8:25 AM
    #266
    MMichaelJJ
    14 Platinum CM
    Here are some photos of the back of halogen and LED headlights. Might be helpful when comparing them to the XB headlights and what adapters you’ll need to use.
    I’m making it sound more complicated than it is. Just be a little flexible when you’re reading the online instructions for the XB lights.
  27. Aug 14, 2019 at 8:26 AM
    #267
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    Now I'm confused.
    I'll be going from a TRS retrofit to the XBs, what instructions do I use?
  28. Aug 14, 2019 at 8:34 AM
    #268
    MMichaelJJ
    14 Platinum CM
    If your truck is prewired for LED DRL, you won’t need the LED fuse tap.
    If your truck doesn’t use the multipin connector , then you won’t need to use the included adapter / harness.
    I’m not 100% on who needs to use the turn signal adapter. I think it’s the people with OEM LED headlights. Easy thing is look at the wiring when it’s connected and make sure it lines up.
    If you look at the adapter you’ll see how it moves the wires in the plugs. Pre adapter the black and yellow wires are next to each other. After the adapter there’s a blank spot between them.
  29. Aug 14, 2019 at 8:38 AM
    #269
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    @MMichaelJJ Thx for the detail.
    Who needs the non DRL relay?
  30. Aug 14, 2019 at 8:40 AM
    #270
    MMichaelJJ
    14 Platinum CM
    Are you asking about the fuse tap? If so, it’s needed to power the LED DRL. So if you’re truck didn’t come with LED DRL, you’ll need it.
Thread Status:
