Sun visor?
Discussion in '2.5 Gen Tundras (2014-2021)' started by frostybrew4me, Aug 10, 2019.
  1. Aug 10, 2019 at 6:12 PM
    frostybrew4me
    frostybrew4me [OP] New Member
    Jack
    2018 Tundra SR5 Doublecab 4x4
    TRD exhaust,TRD CAI, TRD Sway Bar
    Just curious if anyone else having this cosmetic issue with the drivers side sun visor? My Tundra just hit 11 months and 5,300 miles.
    I’ve attached two photos showing front and backside of my sunshade, I don’t use air fresheners are any chemicals to clean the interior, only soft microfiber towels for dusting. I can live with it, dealership is giving my hard time about covering under warranty. I’m just curious what might be causing it.
    shawn474 and OR18TRD like this.
  2. Aug 10, 2019 at 6:15 PM
    Welcome from NY.
    Never seen that issue before.
  3. Aug 10, 2019 at 6:55 PM
    AZTundra
    Paul
    Phoenix, AZ
    Based on the portion that changed color I'm assuming you keep the shade pulled down a lot?
  4. Aug 10, 2019 at 7:07 PM
    frostybrew4me
    Jack
    The visor is never pulled down, always up or at times I use a windshield sunshade, at which the visor is pulled down to keep the sun shield in place.
  5. Aug 10, 2019 at 7:12 PM
    AZTundra
    Paul
    Phoenix, AZ
    I'm stumped then, never seen that before. I thought maybe they were always left down and took a beating from the sun. Weird.
  6. Aug 10, 2019 at 7:26 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    What’s the problem??
  7. Aug 10, 2019 at 9:51 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
  8. Aug 11, 2019 at 5:18 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Looks like some sort of weird chemical reaction. Did something get on the sunshade and then transfer to the sticker I wonder? Or maybe a reaction between the sunshade material itself and the sticker?
    jeremyd likes this.
  9. Aug 11, 2019 at 5:22 AM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    I’m guessing when you put it down with the sunshade the sun or heat is still affecting it.
  10. Aug 11, 2019 at 6:24 AM
    BillBeauBobbins
    BillBeauBobbins New Member
    2016 Brown Crew Max 1794
    Looks like a chemical reaction. Could be air freshener, cologne - perfume, Smoke, Food. or maybe a cleaning solution that was used once.
  11. Aug 11, 2019 at 6:50 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Can you post some pictures of the sunshade your using? I’m wondering if your sunshade has a die or chemical on it that it’s causing this to happen to the OEM sun visor. I would put in your sunshade and put the visor down and look at your trucks windshield from the front view. If the faded line on your sun visor matches up with your sun shade then I think you found your answer.
    TokerJoker and AZTundra like this.
  12. Aug 12, 2019 at 1:32 PM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Mine turned pink as well, it's just the heat and I use a sun shade everyday. I live in Palm Springs, CA and the heat is intense out here. No big deal.
  13. Aug 12, 2019 at 1:50 PM
    frostybrew4me
    Jack
    thank you, appreciate the response, I figured the same thing. I was just in AZ, recently +100 for weeks at a time there.
  14. Aug 12, 2019 at 2:12 PM
    vl184009
    Vicky
    Southern, Ca.
    :thumbsup:
  15. Aug 12, 2019 at 2:21 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Post pic from out front of the sunshade in the truck as you would normally place it.
  16. Aug 12, 2019 at 4:36 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I had the exact same discoloring on mine - it almost looked like it was cooked. I had been using a cheap sun shade and I chalked it up to this. My dealer did replace the visor under warranty without any issues (I had this done at about 1 1/2 years). I also replaced the sun shade I had been using to one that they were selling at the dealership.
  17. Aug 12, 2019 at 5:50 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    I never put my shade up, it is down all the time. I also live in an area that has triple digit summers and I use a sun shield. I would think if something was going to cook it, it would have happened in my vehicle. Maybe its your sun shade. I've used the black fabric type that twists into a small circle for almost 4 years now. Cheapo Amazon style
