HELP diagnose this
Discussion in '2nd Gen Tundras (2007-2013)' started by brandonparton, Aug 7, 2019.
  1. Aug 7, 2019 at 2:31 PM
    brandonparton
    brandonparton [OP] New Member
    Brandon
    I started up my Toyota Tundra (2012) today at about 4:00 PM. On startup I sat there for a few minutes to get the oil to warmup. I sat there for about 5 minutes then a noise happened. Like an almost grinding noise. The noise happened then white smoke started coming out of the front right tire. I immediately turned it off and didn't drive it for the rest of the day as I am scared to start it. Please help me!
  2. Aug 7, 2019 at 2:46 PM
    brandonparton
    Brandon
    please help
  3. Aug 7, 2019 at 2:50 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    :worthless:they could help us diagnose the problem
    Black Wolf likes this.
  4. Aug 7, 2019 at 2:52 PM
    TylerDurden311
    TylerDurden311 Paper Street
    2018 Tundra CM
    Have you looked under the hood? Serpentine belt intact?
    landphil and Prostar 190 like this.
  5. Aug 7, 2019 at 2:54 PM
    FXFormat
    FXFormat New Member
    Sounds like cam tower leaked onto manifold and creating that smoke.
  6. Aug 7, 2019 at 2:55 PM
    Jrharvey02
    Jrharvey02 New Member
    It’s summer in the northern hemisphere. Is there a back story to why you sat there for 5 min. to let the oil warm?
    Trooper2, BlackSheep and Black Wolf like this.
  7. Aug 7, 2019 at 2:56 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    First thoughts, need to look under the hood to see if you can tell where the smoke was coming from. May need to scan for codes that may reveal something.
    Call around to Toyota shops and describe what you experienced.
    Good luck!
  8. Aug 7, 2019 at 2:57 PM
    Jrharvey02
    Cam towers leaks don’t suddenly do this nor make a grinding sound.
  9. Aug 7, 2019 at 3:24 PM
    FXFormat
    FXFormat New Member
    If the leak was bad enough, he sat there for 5 minutes oil could pool onto the manifold, it's literally right underneath it. Not sure what the grinding noise is but if OP had any common sense he would open the hood and see where it's coming from.
    Jrharvey02[QUOTED] and Trooper2 like this.
  10. Aug 7, 2019 at 4:19 PM
    AgileTundra
    AgileTundra New Member
    2018 Silver Sky Tundra Platnium 4x4
    2 posts from brandon with in 15 min now crickets!
    2manytoys and BlackSheep like this.
  11. Aug 7, 2019 at 4:30 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Guessing he is trying to find out how to lift the hood
  12. Aug 7, 2019 at 5:45 PM
    Jrharvey02
    i get ya...but it should be referred to as the cam tower seep it’s so small. :anonymous:
  13. Aug 7, 2019 at 6:34 PM
    FXFormat
    FXFormat New Member
    There are a few cases where owners had it dripping on their manifold and fumes entered the cabin, in one case, one person claimed the leak got so bad his truck caught on fire. Just what i read over at the Cam tower leak thread, i'm lucky my 2008 with 200K miles on it is bone dry, it's the later ones that were affected.
  14. Aug 7, 2019 at 6:35 PM
    All of your fluids good?
  15. Aug 10, 2019 at 6:50 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    2 posts too fast then nada for 3 days. Hopefully it didn't blow up.
