Quick payload question
Discussion in '2.5 Gen Tundras (2014-2021)' started by mr_data, Jul 28, 2019.
  1. Jul 28, 2019 at 9:55 AM
    mr_data
    mr_data [OP] New Member
    Northern New York
    2016 Super White Tundra SR5
    Can anyone tell me if this is a factory installed sticker? I know that generally the more options you add/higher trim levels results in lower payload capacity. Just wondering if this sticker is something that the factory would have installed or if it was done by the previous owner. Thanks.
  2. Jul 28, 2019 at 11:08 AM
    Justin Case
    Justin Case New Member
    Prob done at the dealer.
  3. Jul 28, 2019 at 11:13 AM
    Storm
    Storm Elite Member
    2018 TRD SPT
    No, it was put on during assembly.
    ColoradoTJ likes this.
  4. Jul 28, 2019 at 11:56 AM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    mine has same sticker in the door jam and if i had to guess its because of the running boards and possibly the spray in bed liner all factory parts
    Bigboitundra likes this.
  5. Jul 28, 2019 at 12:13 PM
    mr_data
    Northern New York
    Mine has running boards, so that's probably why. Thanks.
  6. Aug 7, 2019 at 6:11 PM
    jrd347
    jrd347 New Member
    2018 Tundra Limited 4x4
    I know Southeast Toyota puts these on if they install any accessories at the port.
  7. Aug 8, 2019 at 10:02 AM
    VQT
    VQT New Member
    2018 TRD Sport
    6" Lift, 35-12.5-20
    Is your truck lift? bought my 2018 already lifted and it has the same sticker so I don't know if it was from the lift hardware or not.
  8. Aug 8, 2019 at 11:11 AM
    meddev
    meddev New Member
    2017 Silver Sky Crewmax
    I had a sticker put on at the dealership during service after I installed a 3/1 and bigger tires... mine was only reduced by 10 pounds though.
  9. Aug 8, 2019 at 11:16 AM
    jlocust
    jlocust New Member
    Portland, OR
    2023 Lunar Rock TRD Offroad
    I have one of those and thought it was because of the trd pro fox shocks. However my truck also came with factory spray bed liner which would probably match up closer the weight difference on the sticker.
  10. Aug 8, 2019 at 12:36 PM
    nodak67
    nodak67 New Member
    JR
    my yellow sticker says 0/0, kinda pointless but i imagine they needed to put the sticker on to justify the charge to toyota.
