joonbug's build
Discussion in '2.5 Gen Builds (2014-2021)' started by joonbug, Nov 29, 2016.
  1. Aug 5, 2019 at 12:43 AM
    #1711
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    @831Tun what are the specs of the hoses and fittings if I want to try and replicate this kit?
    Thanks!
    cavalry bear, 831Tun and Rica25 like this.
  2. Aug 5, 2019 at 11:51 AM
    #1712
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Icon Billets ordered. Should make an alignment 100x easier.
    signalbobby, Rica25, KevinK and 8 others like this.
  3. Aug 5, 2019 at 5:53 PM
    #1713
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Damn Joon those are expensive! That’s 25% of an LT budget. Hahaha
    Rica25, Vizsla, osidepunker and 2 others like this.
  4. Aug 5, 2019 at 6:42 PM
    #1714
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Remember what I told you like 30 mins ago?? My first instinct was to try to make my camburgs work. Second choice was to get new Icons. I’m following my own advice and going with my second instinct. :D As much as I love those camburg arms, this will be worth the time saved alone. Plus, I should be able to recoup a good chunk selling these.
  5. Aug 5, 2019 at 10:39 PM
    #1715
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    I'm still in the process of aligning, but the manual labor is inevitable. The last shop that pulled the UCAs adjusted both heims out equally. This did absolutely nothing to help caster since they have to be offset. Right now the heim to the rear of the truck is pulled out far enough to maintain the camber I need, but the front heim will need to be adjusted in to add caster and help my maxed out lowers. I'll do my best to write it up and document as I go
  6. Aug 5, 2019 at 11:18 PM
    #1716
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    Dibs! Lol
    Shoot me a pm.
    Or I might get the Icon Billets too... $$$
  7. Aug 6, 2019 at 6:43 AM
    #1717
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    If those are the ones @KevinK has make sure you torque those pinch bolts properly and probably should add some loctite. Kevin's came loose...
    Seriously haha
    The shop I use runs the LCAs all the way forward and does the entire alignment with the UCA heims. Its more work, but a much better way to do it. Find a shop that works on commercial trucks, they usually know what to do
  8. Aug 7, 2019 at 9:59 AM
    #1718
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    Yeah, I finally figured out why that was happening. The inner collar has a notch just like the outer portion of the pinch. You have to align the notches to each other, otherwise tightening the pinch bolts on the outer doesn't actually pinch the inner collar. I had the collar and the outer at 90 degrees to each other.
    Hopefully this pic makes sense.
    Sunnier, Watt maker, Rica25 and 2 others like this.
  9. Aug 7, 2019 at 10:04 AM
    #1719
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Will it be obvious once I see it?
    GodlessPro likes this.
  10. Aug 7, 2019 at 10:11 AM
    #1720
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
  11. Aug 7, 2019 at 10:36 AM
    #1721
    KevinK
    Tundras to Sedona
    yeah, I think so.
    I google image searched for an icon billet upper for the tundra, and Lisa's truck is the first result. :rofl::anonymous:
    Here's the image I was hoping to find. There's the heim, the collar and pinch. The collar and pinch have to be aligned like in this picture in order to actually pinch the collar tight on the heim bolt. This pic is of a Tacoma, but the _principle_ is the same @osidepunker ;)
  12. Aug 7, 2019 at 10:43 AM
    #1722
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    So do they come loose mostly on high speed events or low speed events? Chop or softballs? :D
    jc153, Rica25 and osidepunker like this.
  13. Aug 7, 2019 at 10:50 AM
    #1723
    KevinK
    Tundras to Sedona
    I'd say high speed events - like softball size inputs at around 40 mph... :bananadance:
    jc153 and joonbug[QUOTED][OP] like this.
  14. Aug 7, 2019 at 11:04 AM
    #1724
    osidepunker
    Alex
    2013 Tundra DC 4x4
    At least you're following along. I feel like I'm alone in there with dweedle dee and dweedle dumb
    jc153, joonbug[QUOTED][OP] and KevinK like this.
  15. Aug 7, 2019 at 11:08 AM
    #1725
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    :rofl: It is entertaining. I'm just waiting for you to get the shocks done and get it on dirt so we can prove one of you two wrong!!! Even though that person will never admit defeat. :laugh:
    jc153 likes this.
  16. Aug 7, 2019 at 11:10 AM
    #1726
    greggm
    greggm New Member
    Gregg
    Los Gatos, CA
    2019 CM TRD 4x4
    Man, so many nice mods in your build! My wallet is already on fire and I think its about to get worse! :annoyed:
    Rica25 and joonbug[OP] like this.
  17. Aug 7, 2019 at 11:10 AM
    #1727
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I have no problem admitting I am wrong about something. But it wouldn't be "defeat" because I'm the only one of the group who actually has touched a shim stack so that makes me a winner
  18. Aug 7, 2019 at 11:52 AM
    #1728
    KevinK
    Tundras to Sedona
    I don't think there's any 'defeat' involved, but you might want to ask Les how many shim stacks he's touched. ;)
    I'm definitely the loser from a shim-stack-touching perspective...
    But I masturbate a lot, so I'm touching something.
  19. Aug 7, 2019 at 11:53 AM
    #1729
    osidepunker
    Alex
    2013 Tundra DC 4x4
    uh he's touched exactly zero shim stacks that are relevant to what we do
  20. Aug 7, 2019 at 12:13 PM
    #1730
    KevinK
    Tundras to Sedona
    There's not an eye roll gif that is extreme enough to respond with. :rofl:
  21. Aug 7, 2019 at 12:16 PM
    #1731
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    What bumper is that?
    joonbug[QUOTED][OP] likes this.
  22. Aug 7, 2019 at 12:30 PM
    #1732
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    I think it might be a Westin Outlaw?? @Vizsla ?
  23. Aug 7, 2019 at 2:07 PM
    #1733
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    Thanks @joonbug. I found it.:headbang:
    BestGen and joonbug[QUOTED][OP] like this.
  24. Aug 9, 2019 at 9:34 AM
    #1734
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    If ya send a PM I'll try to locate the parts list. Been gone for a week so, sorry for the late response.
  25. Aug 9, 2019 at 11:12 AM
    #1735
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Hey Warren can you send me that list please. That’s one thing I keep neglecting to do
    joonbug[OP] and 831Tun[QUOTED] like this.
  26. Aug 9, 2019 at 11:27 AM
    #1736
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Be glad to Francis.
    joonbug[OP] likes this.
  27. Aug 9, 2019 at 7:53 PM
    #1737
    Sunnier
    Sunny
    San Diego, CA
    Hey Warren, can you post the part numbers over on your build thread so your entire fan base can follow along?! :p :boink:
  28. Aug 10, 2019 at 11:48 PM
    #1738
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    I already told warren to write a book lol. It would be a lot easier on us all lol
    831Tun, SpeshulED, JDL17CM4x4 and 3 others like this.
  29. Aug 17, 2019 at 6:23 PM
    #1739
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Switchpro
    ARB Compressor
    SDHQ Battery Terminals
    After a couple of years of thinking where to mount a Switchpro I finally decided to mount it where the brake controller is. Starting to prepare for a rear locker so I had to get the compressor installed. Cut out the panel, made it fit perfectly and it turned out great. Then a couple months ago I went to @dcsleeper408 to have it installed but the main piece that mounts in the engine bay went missing. Well I finally found it and got it installed today.
    Mounted the brains on the fuse box. I pull my ABS fuse every time I wheel high speed so I had to leave some slack on the wires to open the fuse box easily. While we were hooking it up we threw on the SDHQ battery terminals that @DMathys gave me. Thanks bud.
    And finally got on board air with Bannock’s mount.
    Thanks again to Mark for the awesome install.
    https://www.tundras.com/threads/ins...francisco-bay-area-norcal.43905/#post-1125664
  30. Aug 17, 2019 at 7:00 PM
    #1740
    Porschetech29
    Francis
    That’s exactly what my day looked like
    831Tun, Vizsla, GodlessPro and 3 others like this.
