Considering a 2007 with replaced frame
Discussion in '2nd Gen Tundras (2007-2013)' started by marinakorp, Jul 31, 2019.
  1. Jul 31, 2019 at 6:21 PM
    marinakorp
    marinakorp [OP] New Member
    2010 DC 5.7 SR5 TRD Mica Green
    Tow Mirrors, Tekonsha p3, 12 v Solutions remote Start,Weather Tech Mats, Truxedo Roll up Tonneau
    Hello,
    Been lurking here for a bit, and came across a 2007 with 144k on the clock.
    Frame appears to have been replaced very recently.
    Would this dissuade me from owning this vehicle?
    Most everything else seems solid. The bed looked solid (has a cap on it and a bedliner. I pulled it up and gave a quick look will get on a lift to see better)
    It is from a dealer. 13.5 k.
    Car fax seemed ok. Regular maintenance.
    Will run through the Toyota owners to get more info.
    I live in Pa.
    Any reason to walk from this?
    Black Wolf likes this.
  2. Jul 31, 2019 at 6:26 PM
    Carfax good.. check!, New frame..check... fairly low miles...check......$13.5??? Reasonable. How is the overall condition??
  3. Jul 31, 2019 at 6:28 PM
    marinakorp
    13,500
  4. Jul 31, 2019 at 6:30 PM
    My bag, I saw the 13.5 K. Could be a good deal. You have pics? Can you take it to a local mechanic to check it over??
  5. Jul 31, 2019 at 6:34 PM
    marinakorp
    Overall seemed ok.
    Pain was decent. Interior decent.
    I would like the floor mount shifter. But can deal with column if need be.
    New aftermarket radio with BT
    looking for aneatntonstore my firearm while traveling. Which is why I like the center console. But might be able to work it out.
    And yes. An take to local to check it out.
  6. Aug 1, 2019 at 5:26 AM
    Dr_Al
    Dr_Al New Member
    Al
    When they replace the frame Toyota also replaces rusty parts that would be difficult to swap. Things like brake and fuel lines for example. But there's still the possibility of a rusted part that may need replacing. On my 2000 Tundra the rear axle rusted through. Most of it is thick steel but the rear center part, where the bolt is to fill it, is just sheet metal. ON an American truck it would just bolt on but on the Tundra it's welded on. I first noticed it because it looked wet but it didn't look like it was coming from the drain or fill bolts. I repaired it myself but it was quite a bit of work. If the rear axle is rusty but not leaking and you do buy the truck I would strip the rust and repaint it to protect it. The inside is filled with oil so any rust will simply be on the outside.
    What are the details? Is it 4wd? What size engine? Which package (basic, SR5, Limited)? Regular cab, double cab, or crew max? Would need that information to give you an idea on what it's worth. For example last summer I paid less for my 2007 from a dealer (4wd with 5.7, 151k miles, double cab SR5) from south Carolina (so not a speck of rust).
  7. Aug 1, 2019 at 7:21 AM
    marinakorp
    2007 Toyota Tundra
    SR5 Double Cab 6.9' Bed 5.7L V8 4WD
    Looks like brakes were replaced (thats a good thing) and the fuel pump (a separate repair)
    COMMON REPLACEMENT K 040041920C 1
    USA SOURCE PARTS KIT 040041940C 1
    ARM SUB-ASSY, SUSPEN 4806809100 1
    ARM SUB-ASSY, SUSPEN 4806909090 1
    WIRE, FRAME 821640C890 1
    COMMON REPLACEMENT K 0400419134 1
    FRAME SUB-ASSY KIT 040041680C 1
    JPN SOURCE PARTS KIT 0400419334 1
    PLUG, HOLE KIT 0400718134 1
    TUBE, FR BRAKE, NO.2 473120C080 1
    TUBE, FR BRAKE, NO.3 473130C090 1
    TUBE, RR BRAKE, NO.2 473220C110 1
    TUBE, RR BRAKE, NO.3 473230C090 1
    TUBE, RR BRAKE, NO.4 473240C081 1
    TUBE, RR BRAKE, NO.5 473250C101 1
    SPRING ASSY, RR 482100C300 1
    SPRING ASSY, RR LH 482200C300 1
    CARRIER ASSY, SPARE 5190034050 1
    SUPPORT, FUEL TUBE G 7741234010 2
    BOLT, W/WASHER 9008011717 16
    NUT, FLANGE 9008017229 1
    BOLT, FLANGE 90105A0179 5
    BOLT, U 90117A0004 4
    BOLT, W/WASHER 90119A0169 5
    BOLT, W/WASHER 90119A0170 1
    BOLT, W/WASHER 90119A0219 10
    BOLT, W/WASHER 90119A0271 2
    STUD, HEXALOBULAR 90126A0011 3
    GROMMET, SCREW 9018906236 4
    CLAMP 9046115017 1
    CLAMP 90469A0004 8
    GASKET, EXHAUST PIPE 9091706093 1
    PLUG, HOLE 9095001A31 2
    Separate order....but no part list - gotta check if replaced or just "fixed" in place with new connectors
    C/S VEHICLE SHUTDOWN COMPLETELY-TOWED IN ~|~C/S VEHICLE SHUTDOWN COMPLETELY-TOWED IN ~|~FOUND VEHICLE CRANKS BUT NO START. FOUND CODE P0230: FUEL PUMP PRIMARY CIRCUIT -FUEL PUMP IS GETTING 12VOLTS BUT IS NOT TURNING ON. CHECKED FUEL PUMP FOR RESISTANCE AND IS OPEN CAUSING THE PUMP TO NOT WORK(WHITE CORROSION ON FUEL PUMP TERMINAL). ~|~., REPLACING FUEL PUMP(PT-77020-0C082) AND FUEL TANK ORING(PT-77169-0C010) $1123.71 P/L.
  8. Aug 1, 2019 at 7:25 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    The last line would imply the pump was replaced I believe.
  9. Aug 1, 2019 at 7:28 AM
    marinakorp
    yes, I believe so...
    so from a rust perspective - the main parts were replaced...that's a good thing...so Im really only looking at some additional pard (axle and possibly the fuel lines, mounts for shock (etc)...
    this is looking a bit more promising.
  10. Aug 1, 2019 at 8:12 PM
    Civiceg94
    Civiceg94 New Member
    NYC
    2007 Toyota Tundra Crewmax 5.7 Limited
    Horn baffle delete Fox 2.5 DSC Setup DAP TUNED RW WHEELS 285/75/17 AT3 LTX
    Bought mine with a frame replacement. The truck has done me really good no regrets. Yet again it was a 1 owner has done all work threw toyota. It has brought my wife and me to california and back to nyc safe and reliable. Also keep in mind. They would need to drain fluids also. Like transmission mine was super clean. O and i bought mine with
    151,744 miles on it.
  11. Aug 4, 2019 at 10:52 PM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    i'm in california, I bought my '07 2 weeks ago 4x2 for $13,500 with only 38k miles on it. 1 owner, clean carfax. Maybe consider looking at California Trucks and getting it shipped? Found mine on Facebook marketplace with the wrong title: 2007 Toyota Prerunner instead of Tundra (old people, no offense) so keep your search kind of broad?
  12. Aug 7, 2019 at 5:13 AM
    marinakorp
    And - it got sold before Icould put $$ down on it..oh well...
