CLOSED - Coachbuilder Shackles Group Buy #2
Discussion in 'Deals & Group Buys' started by Coachbuilder1, Nov 19, 2018.
Thread Status:
Not open for further replies.
  1. Aug 2, 2019 at 9:39 AM
    #961
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    Holy schmokes! Got shipping info today as well!! This is for the +2’s
    Ely010606 likes this.
  2. Aug 2, 2019 at 10:25 AM
    #962
    Pbear1454
    Pbear1454 New Member
    NorCal and SoCal
    2010 Tundra TRD
    Bilsteins SPC RCI Steel Bumpers
    Any recent confirmation for +3 ?
  3. Aug 2, 2019 at 11:17 AM
    #963
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    just got my notification at about 9 am this morning on the +3... should be here monday.
    Ely010606 and Pbear1454[QUOTED] like this.
  4. Aug 2, 2019 at 5:36 PM
    #964
    19greysport
    19greysport New Member
    2019 crewmax sport
    Got mine today. Order number 1742 +3 shackles!! Not I can finally put my lift in.
  5. Aug 3, 2019 at 12:11 AM
    #965
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    Congrats, looks like my order is further back from yours so mine is still in the queue.
  6. Aug 3, 2019 at 10:46 AM
    #966
    Stainlesst
    In the "Zone"...
    mine was 1753.
    Pbear1454[QUOTED] likes this.
  7. Aug 3, 2019 at 12:34 PM
    #967
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    Mine is 1764 so I guess it won't be much longer :thumbsup:
  8. Aug 4, 2019 at 1:09 PM
    #968
    19greysport
    2019 crewmax sport
    I got the +3 shackles. And got the spacers for the carrier bearing. Didn’t come with bolts. It says only the big drop needs bolts. Anyone got info on this? Do I need longer bolts?
    Rica25 likes this.
  9. Aug 4, 2019 at 1:18 PM
    #969
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    Just use the bolts that are already in it. They are plenty long.
    Rica25 and Ely010606 like this.
  10. Aug 4, 2019 at 3:49 PM
    #970
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Installed. DF47A160-6D84-4A9F-9EF3-F13E96808B74.jpg9292FB8E-7B78-446E-AEFE-F65718BAC3BC.jpg D2744638-32AA-4692-8F66-DBFBBCD5F884.jpg
    saybng, AZTundra, Rica25 and 2 others like this.
  11. Aug 4, 2019 at 3:57 PM
    #971
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    I hope your install wasn't too long with those daytime temps
    Rica25 likes this.
  12. Aug 4, 2019 at 4:19 PM
    #972
    19greysport
    2019 crewmax sport
    Awesome thanks for the heads up
    Rica25 likes this.
  13. Aug 4, 2019 at 4:42 PM
    #973
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    It took a while for the pass side bushing to get pushed out. Drivers side took 10 mins. Overall, job took about 2.5 hrs.
    AZTundra and Rica25 like this.
  14. Aug 4, 2019 at 4:58 PM
    #974
    19greysport
    2019 crewmax sport
    Everyone just using ball joint press like instructions say? Anyone got other tricks?
    Tundyfundy and Rica25 like this.
  15. Aug 4, 2019 at 5:01 PM
    #975
    TRDProLife
    St.Louis
    Big hammer and a block of wood. Don't mess up your threads though.
    Rica25 likes this.
  16. Aug 5, 2019 at 8:45 AM
    #976
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I did use ball joint press tool. Took a little bit to figure out getting it lined up right. Kept trying to use 27mm socket on punch side. Finally just put it on w/o socket and hit it w electric impact wrench Stock bushing came right out.
  17. Aug 5, 2019 at 9:20 AM
    #977
    AZTundra
    Paul
    Phoenix, AZ
    Any side shots of the tundra after the install?
  18. Aug 5, 2019 at 9:38 AM
    #978
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Looks pretty much the same. I went with the +1 so about 1/2” of lift.
    AZTundra likes this.
  19. Aug 6, 2019 at 9:00 AM
    #979
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Anyone who is still waiting on their shackles from part of the group buy please like this post. PLEASE IGNORE THIS POST AND DO NOT LIKE THIS POST IF YOU HAVE RECEIVED YOUR SHACKLES
    Thank you
  20. Aug 6, 2019 at 9:59 AM
    #980
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Just got an email from David. He said that the last batch of +3's are out at the powder coat shop and should be back on Thurs/Friday.
    Pbear1454 and cmiller219[QUOTED] like this.
  21. Aug 6, 2019 at 12:09 PM
    #981
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    Hopefully that means I'll have some +3 next week .
  22. Aug 7, 2019 at 12:21 PM
    #982
    Stainlesst
    In the "Zone"...
    just received mine!
  23. Aug 7, 2019 at 6:44 PM
    #983
    mugzy
    mugzy New Member
    Utah
    2014 Platinum
    TRD CAI, TRD Front and Rear Sway Bars, TransferFlow 46 Gallon Fuel Tank, LED lighting
    60CDF9E5-1261-42E6-A2A7-938AA0C73151.jpg Big THANK YOU to @Coachbuilder1 for such great products for us Tundra owners! Looking forward to getting these installed soon.
    Also want to thank @cmiller219 for getting this second group buy going!
    Inquiringone, Rica25 and cmiller219 like this.
  24. Aug 9, 2019 at 4:15 PM
    #984
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    Got my shipping confirmation today
    Rica25 likes this.
  25. Aug 9, 2019 at 4:23 PM
    #985
    ESTundra937
    ESTundra937 All American Paratrooper
    Eddie
    San Diego
    2019 TRD Sport 4x4, 2003 SR5 Moto truck
    Got mine on the 5th and haven't received a thing. Tracking still shows no update and still in Utah. :playball:
    Rica25 likes this.
  26. Aug 9, 2019 at 4:38 PM
    #986
    speckmon
    Thornton, CO
    I was late in the group I'm sure you'll get yours soon
    Rica25 likes this.
  27. Aug 9, 2019 at 4:41 PM
    #987
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    I'm in for shackles and shims
    Rica25 likes this.
  28. Aug 9, 2019 at 4:59 PM
    #988
    TRDProLife
    St.Louis
    If your trying to get in on the group buy, I think it is closed, sorry.
    Rica25 likes this.
  29. Aug 9, 2019 at 5:06 PM
    #989
    TundraCoast
    Ian
    California
    1794 4x4
    Just went back and saw that it was closed.... next time. thx for the heads up
    Rica25 likes this.
  30. Aug 10, 2019 at 8:38 AM
    #990
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
Thread Status:
