2015 Tundra Pro Tire Size
Discussion in 'New Member Introductions' started by TundraPro15, Aug 2, 2019.
  1. Aug 2, 2019 at 12:06 PM
    TundraPro15
    TundraPro15 [OP] New Member
    So I’ve read through the countless threads about 295/70/18 tires on a stock Tundra Pro. Some say it rubs and some don’t. Does anybody have a definitive answer for me on whether or not I should pull the trigger on the 295 or if I should just settle for the 285. I’ll be using the stock Pro rims and I have zero modification done on the truck thus far. Any and all help appreciated.
    Prostar 190 and Pinay like this.
  2. Aug 2, 2019 at 12:24 PM
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    I have a 19 pro, put 295/70/18 Falken wildpeaks on. Only had to remove the little mud flap in front of the front tires. Rubbing gone
    15whtrd, Raxman80, Jmad1997 and 3 others like this.
  3. Aug 2, 2019 at 1:46 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCal!!!
  4. Aug 2, 2019 at 4:40 PM
    TundraPro15
    I’m going to go with the Nitto Terra Grappler G2 if I decide to go 295.
    OR18TRD[QUOTED] likes this.
  5. Aug 2, 2019 at 4:53 PM
    TrdUllrPro
    TrdUllrPro New Member
    Bozeman, MT
    2015 TRD PRO DC
    Fuel Vector 18x9, 295/70 Yokohama Geolander MT, AFE Dry Pro S Air Filter, TRD Air Flow Accelerator, carbon air filter delete, Firestone airbags, stubby antenna, inlay decals, WT mats, frogskinz center console, Leer topper.
    I bought 295/70 Yokohama Geolander MT’s and mounted them to my stock ‘15 Pro. From what I’m told, they run kinda big for that size. I think they’re basically 34.5”. At full lock, yeah I did rub the plastic on the mud flap and the plastic behind the front bumper. I removed the mud flap and dealt with the very minor rubbing of the front plastic for about a month. I have since bought wheels with +18 offset. Our stock wheels have +60. This means the tires moved out about an inch and a half. I then removed the plastic piece that’s behind the front bumper. Yeah there’s a gap that exposes my fog lights, but fuck it.
    1st pic Fuel Vector 295/70. 2nd pic was stock Pro wheels same tires. 234EC10E-7693-4761-81A7-B7AA3B9FF014.jpg 6696C691-EDEF-498D-9375-D2A29C944841.jpg
    JH5370, Trooper2, Luckydog and 2 others like this.
  6. Aug 2, 2019 at 4:57 PM
    TrdUllrPro
    Bozeman, MT
    2015 TRD PRO DC
    Just get the 295’s man. You’re gonna regret it if ya don’t. I think the Nitto RG’s are very slightly smaller than my Yoko’s. So you’ll only have to take the front mud flap off. Also, look at the Toyo RT’s. They won’t rub.
    OR18TRD likes this.
  7. Aug 2, 2019 at 4:59 PM
    TundraPro15
    Damn nice truck! Alright I’m pretty much sold. Last question: read on a thread that the 295’s could screw with the gears some. Anything to that? I got full unlimited warranty so not overly worried about it.
  8. Aug 2, 2019 at 5:34 PM
    TrdUllrPro
    Bozeman, MT
    2015 TRD PRO DC
    Well, what do you mean screw with? Is it gonna mess up your tranny, no. But you’re increasing the circumstance of your tires so there are things that come with that. You will lose some MPG, which you probably knew. I think I went down a full mile per gallon after going to 295, maybe a bit more. it’s also important to mind your driveline. Most guys that jump up to 35’s, which 295’s are real close, install a carrier bearing drop kit. It’s a simple install that realigns your drive shaft. With 295’s you would never notice, but it’ll start vibrating if you increase the angle any more. Check out the Coachbuilder threads in here. Mucho informative! As far as regearing... do it!! It’s spendy as fuck tho. If you’re gonna regear, definitely get it tuned by D.A.P.
  9. Aug 2, 2019 at 6:29 PM
    TundraPro15
    So essentially the coach builder just gives you way more room in the wheel wells... is that the jist? Read up on regearing and it seems to only be necessary when throwing big boy lifts on and 37 inch tires and bigger so should be good there. Thanks for your help. Ordering the 295’s tmrw.
  10. Aug 2, 2019 at 7:21 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  11. Aug 2, 2019 at 8:00 PM
    Welcome from Ohio.
  12. Aug 2, 2019 at 8:38 PM
    Welcome from
  13. Aug 5, 2019 at 7:09 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
  14. Aug 5, 2019 at 7:28 AM
    Welcome from Colorado.
  15. Aug 6, 2019 at 7:43 PM
    lepinem
    lepinem New Member
    2015 TRD Pro
    I have 305/65/r18 KO2s on my TRD Pro - no modifications, no rub...nice ride
    Watt maker and phogallen like this.
  16. Aug 8, 2019 at 2:44 PM
    TundraPro15
    Whelp pulled the trigger on 295/70/18 Nitto Grappler Terra G2’s. THEY FIT. Just take the mud flaps of the front. Rides smooth thus far. Can’t tell a difference in road noise. Heading down to the NC outer banks next week to rip the beaches for the week. Thanks for the advice!
  17. Aug 11, 2019 at 1:19 PM
    Raxman80
    Raxman80 New Member
    Ray
    Downey
    2018 red tundra double cab trd off road 4x4
    Custom bed rack. Roof top tent Baja designs fog lights
    Welcome friend
  18. Aug 11, 2019 at 2:57 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome and congrats on one beautiful truck!
    TundraPro15[OP] likes this.
  19. Aug 18, 2019 at 1:45 PM
    Andrew19
    Andrew19 New Member
    Andrew
    Baytown TX
    2019 TRD PRO
    Stock
    Just putt some 295 70 18 general grabber x3's removed spat from front. No rub nothing. Slight road noise, a little more body roll and shitty gas mileage. But they look awesome 20190817_145801.jpg 20190817_145823.jpg
    TundraPro15[OP] and MakMurph like this.
  20. Aug 30, 2019 at 9:50 AM
    TundraPro15
    Took her down to OBX to rip the beaches for a week. What a blast!
    15whtrd and JH5370 like this.
  21. Aug 30, 2019 at 10:57 AM
    15whtrd
    15whtrd Mr. Blonde
    No carrier bearing drop needed if you’re not lifting the rear end. Larger tires do not require a carrier bearing drop. Only if you’re adding longer shackles blocks or lifted springs etc.
    monaco730 likes this.
