Transfer Flow 46 Gallon replacement tank
Discussion in 'Towing & Hauling' started by timwells122, Jun 27, 2019.
  1. Jun 27, 2019 at 8:57 AM
    timwells122
    timwells122 [OP] New Member
    2013 Toyota Tundra
    Transferflow 46 gallon tank,just getting started
  2. Jun 27, 2019 at 9:17 AM
    MIM
    MIM New Member
    SLC, UT
    2015 CM Ltd MGM
    I love mine. One of the best upgrades I've made on my truck. Big upgrade from the 26 gallon tanks.
    ATHiker likes this.
  3. Jun 27, 2019 at 9:18 AM
    timwells122
    2013 Toyota Tundra
    Where did you go to get the tank? Did you do the install your self?
  4. Jun 27, 2019 at 9:23 AM
    MIM
    MIM New Member
    SLC, UT
    2015 CM Ltd MGM
    I ordered it straight from TransferFlow about 18 months ago. I installed it myself with a friend. It was actually a lot easier than I expected. The hardest part is when you first drop the OE tank. You have to drop it about 3-4 inches and then blindly reach up above tank and disconnect the fuel lines. Not too hard, you just can't see what you're doing.
    Quicktan66 likes this.
  5. Jun 27, 2019 at 9:25 AM
    timwells122
    2013 Toyota Tundra
    Wow!
    Nice looking Tank..
    Thanks for the picture.
  6. Jul 22, 2019 at 2:34 PM
    NomadsLand
    NomadsLand The 719
    TS
    Future Tundra
    Awesome find!
    I actually plan to build a Tundra from the ground up for full-time road travel, and this is the exact aftermarket fuel cell I need to alleviate frequent pit stops at a gas station.
  7. Jul 22, 2019 at 2:36 PM
    timwells122
    2013 Toyota Tundra
    Awesome!
  8. Aug 1, 2019 at 1:47 PM
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    Does the gas gauge still read correctly?
  9. Aug 1, 2019 at 2:26 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    There’s several threads about this. Easy to use the search function, type in “transferflow fuel tank”.
    I bought mine directly from the company but had it shipped to the shop doing the install. Best mod ever for a bug out or expedition or towing rig.
    Only down side is that the extra fuel plus the steel tank will add over 200lbs.
    NomadsLand likes this.
