Screw in tire
Discussion in 'General Tundra Discussion' started by RobN22, Jul 31, 2019.
  1. Jul 31, 2019 at 8:34 AM
    RobN22
    RobN22 [OP] New Member
    Rob
    2014 Tundra SR5 Crew Max
    Level Kit, 33x12.5x18 Toyo M/T, Fuel Maverick wheels, rear air bag suspension
    E022BC54-A34F-4BBC-BA38-E5DF5CBD1579.jpg Repairable or nah? Want to repair myself. Less than 2,000 miles on tires
  2. Jul 31, 2019 at 8:35 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    If you have road hazard warranty, replace. If not I would plug if needed.
  3. Jul 31, 2019 at 8:36 AM
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    I would use it as an excuse to trade those 33s in for 35s lol
  4. Jul 31, 2019 at 8:38 AM
    TylerDurden311
    TylerDurden311 Paper Street
    2018 Tundra CM
    Plug that bad boy!
  5. Jul 31, 2019 at 8:39 AM
    Wiscdave
    Wiscdave New Member
    Northern Wisconsin
    19 Tundra Sport
    Old ride 13 RW BA budget, 3/2 lift JL W7
    Easy Plug and play
    TylerDurden311 likes this.
  6. Jul 31, 2019 at 8:39 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Tire shop probably won't, But I would stick a plug in that bitch.
  7. Jul 31, 2019 at 8:49 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    That's what she said.
  8. Jul 31, 2019 at 8:49 AM
    Drill, Phillips head, screw it all the way down, send it.
  9. Jul 31, 2019 at 8:54 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    My thoughts exactly. Send it!
  10. Jul 31, 2019 at 8:55 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    If you go with the screw method, at least use a little bit of RTV. Lol
  11. Jul 31, 2019 at 8:56 AM
    I had a screw in one of my tires for around 35k miles. Wore the head off and took the tires down to the wear bars.
  12. Jul 31, 2019 at 9:03 AM
    WNY PAT
    WNY PAT New Member
    They won’t plug that at any reputable tire shop. You can do it yourself and it’ll probably hold. Are you sure that screw punctured the tire? I’ve seen more than my share that when you back out the screw, it never went through. I’d say that’s the risk with driving it home... unless you’re hearing air come out or it’s pretty low on air... you might ruin the tire for no reason. If you aren’t sure, take in to a tire shop and have them spray it or ask them to put it in a tub. Hope it’s easy! Otherwise, I’d follow the advice of trying to get to warrantied through the road hazard if your have it. Fingers crossed for you!
    Edit: if you’re taking it to a tire shop for the spray and pray, I’d wouldn’t drive it there like that. Take it off and bring it with you.
    ColoradoTJ likes this.
  13. Jul 31, 2019 at 9:06 AM
    TXMiamiFan
    Jose
    If I were do add a few more to my tires, could that work as a snow tire in the winter? I could always move the screw up/down for summer/winter driving.
  14. Jul 31, 2019 at 9:07 AM
    Add summer and winter air accordingly
  15. Jul 31, 2019 at 9:08 AM
    Absolutely. I’m thinking 100 per tire will do the trick.
  16. Jul 31, 2019 at 9:11 AM
    TXMiamiFan
    Jose
    Georgetown lake here we come!
    Once again, another serious thread derailed :rofl:
  17. Jul 31, 2019 at 9:17 AM
    All joking aside, take it to the tire shop and see if they can plug patch it. Usually if the puncture is within 1” of the carcass, the tire is done.
    Sucks it happened on such a new tire. Same thing happened to my current truck within 500 miles of being brand new.
    Prostar 190 and jeremyd like this.
  18. Jul 31, 2019 at 9:18 AM
    RobN22
    Rob
    It punctured. If I move the screw around any amount I can hear air leak out of it. I'm just going to plug it and hope it works
  19. Jul 31, 2019 at 9:25 AM
    Woody40
    Woody40 New Member
    Panama City Florida
    2017 Tundra
    3/1 lift, BFG KO2's, Westin black drop steps, 2019 TRD PRO Grille, Black out bumper caps, Black out emblems, Winjet taillights
    After Hurricane Michael came through north Fl. I have put 6 plugs in either my truck or my wifes car. Plug it and keep on truckin
    TXMiamiFan likes this.
  20. Jul 31, 2019 at 9:43 AM
    TylerDurden311
    2018 Tundra CM
    It should work. Be generous on the glue and clip the ends close to flush.
  21. Jul 31, 2019 at 10:06 AM
    WNY PAT
    WNY PAT New Member
    Ah. That blows. At a minimum, I’d plug and patch it but there’s a risk of a blowout or tread separation with that. Leaving the screw in there increases the risk of a blowout or sudden failure even more., especially with the screw in that location. Not sure if you have a spare. If not, this might be the perfect time to grab a cheap rim and mount this tire to it for emergency / temporary use only. Then grab a new tire for daily use. Food for thought anyway.
  22. Aug 1, 2019 at 6:49 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    You probably can get a tire shop that will put a boot in it. It’s like a patch.
