Window Trim
Discussion in '1st Gen Tundras (2000-2006)' started by SexyBeast00, Jul 23, 2019.
  1. Jul 23, 2019 at 9:03 PM
    SexyBeast00
    SexyBeast00 [OP] New Member
    Not sure what this is called so we will say window trim. It was cracking and the chrome underneath was showing. I attempted to remove the remainder however I couldn’t. I ended up covering it with plastidip as a quick fix. Does anyone know how to remove it and replace it? Is there some place I can take this to and get it done?3C65F2F2-0197-4C88-B999-73E57DDE69D8.jpg938BE076-858F-4792-A813-338D7EF6CD82.jpg
  2. Jul 23, 2019 at 11:12 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    It’s called the belt molding. You can get a new one from Toyota for a reasonable price usually.
    30-50 bucks typically, I haven’t looked up tundra ones
    Tundyfundy likes this.
  3. Jul 24, 2019 at 12:06 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Tape it off. Sand it down. Spray 4-5 coats of big box bed liner on it. Cost $8.
  4. Jul 24, 2019 at 12:13 PM
    War Machine
    War Machine SSEM # 5 3MW
    I got some from @Roman pretty easy to replace.
    OR18TRD and Roman like this.
  5. Jul 24, 2019 at 12:18 PM
    Casper421
    In the woods
    06 DC
    OR18TRD likes this.
  6. Jul 30, 2019 at 11:22 PM
    SexyBeast00
  7. Jul 31, 2019 at 6:23 AM
    Casper421
    In the woods
    06 DC
    He moldings just snap out. I removed the door panel to get a better look at the release tabs. You also need to loosen the 3 bolts for the side mirror to remove and insert the new molding. Here’s a useful how to video for removing the door panel:
    https://m.youtube.com/watch?v=ILp3UkaN8e4
  8. Jul 31, 2019 at 6:26 AM
    War Machine
    If it’s just the outside, you don’t need to remove the door panels. Just pull up on them. They come right off. They generally break though.
    deptrai likes this.
  9. Jul 31, 2019 at 6:35 AM
    Casper421
    In the woods
    06 DC
    The moldings had to pull out(giggity). It was also tucked under the side mirror. 2nd gen might be different but this is how I did it on my 1st gen.
  10. Jul 31, 2019 at 6:45 AM
    War Machine
    Didn’t realize it was first gen. My Gen 2 and Sequoia didn’t have that issue. They broke, and I just had to make sure none fell inside the door.
    Casper421[QUOTED] likes this.
