2019 Tundra Pro 275/70/18 work ok?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by one4x4dad, Feb 7, 2019.
  1. Feb 7, 2019 at 12:58 PM
    one4x4dad
    one4x4dad [OP] New Member
    James
    Houston TX
    2019 Tundra Crew Pro
    driving by the tire store just now. Discount tire had 275/70/18 for $220 each.
    I bit. They said that was as big as they would go for full functionality. Wondering if that’s what they said as they don’t have 285’s. Will these be a large enough change to fill the wheel wells? I have a 30 day return option.
    I also bought wheel locks. Just trying to prevent someone taking the BBS rims.
    I also need to sell my stock tires. They have 1100 miles on them. Anyone know the best place to sell them around Houston?
    Thanks in advance.
  2. Feb 7, 2019 at 12:59 PM
    one4x4dad
    James
    Houston TX
    They are BFG KO2s
  3. Feb 7, 2019 at 1:00 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You could go bigger if you want. That size is just a little taller than stock, it fits great on all stock tundras
  4. Feb 7, 2019 at 1:32 PM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
  5. Feb 7, 2019 at 1:56 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    For some reason, 275/70 bfg’s are way way cheaper than the next size up. I noticed this when shopping for bfgs last round
  6. Feb 7, 2019 at 2:20 PM
    TundraRunner481
    TundraRunner481 Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    I have 275 70 18 and I like them. They're pretty close to the stock size so the I can keep the stock spare, and don't take too much of a hit MPG wise. I'm happy I went with them. Discount Tire matched a price online, and bought the stock tires for $400 so I was happy with that.
    OR18TRD likes this.
  7. Feb 7, 2019 at 2:28 PM
    one4x4dad
    James
    Houston TX
    I was $1217 out the door with road hazard etc. they offered me $30 each for the takeoffs. Had 1000 miles.
    So I kept them to sell. I’m happy with the size, as I didn’t want to bind anything when off-road. They were $100 cheaper than the next size up for some reason.
  8. Feb 7, 2019 at 3:37 PM
    one4x4dad
    James
    Houston TX
    Thanks for all of the info. I am happy with the way they fit and ride.
    OR18TRD likes this.
  9. Feb 8, 2019 at 7:26 PM
    Acrotalus
    Acrotalus New Member
    2016 Quicksand TRD Pro Tundra
    Fab Fours Elite Bumpers Total Chaos Shackle TRD front and rear sway bar Westin R7 Running boards
    I ran 285’s and they worked/fit well. Then I upgraded to 295’s and they were literally like 1mm from the UCA’s, so I got black rhino arsenal wheels that had a good offset. Looks much better. The TRD Pro wheels are +60 and really sucked in.
    Hope this helps
  10. Feb 14, 2019 at 8:30 AM
    Fabianp1122
    Fabianp1122 New Member
    Black 2019 Tundra TRD PRO
    I'm running 275/70/18 nitto ridghe grapplers with no issues at all.
  11. Jul 31, 2019 at 4:01 AM
    ncomeau35
    ncomeau35 New Member
    2019 White Toyota Tundra TRD PRO
    Nitro Ridge Grappler 285/75/18
    I run the 285/75/18 Nitto Ridge Grapplers, had a slight rub on the front mudflap, easy fix!! To remove, grab your wrench (think it was an 8mm) and remove the two screws on each flap and presto, no rub
