1794 Tow/Play Build
Discussion in '2.5 Gen Builds (2014-2021)' started by Red_Leg, Jul 27, 2019.
  1. Jul 27, 2019 at 6:59 AM
    Red_Leg
    Red_Leg [OP] New Member
    Will
    When I started this build I wanted something that could perform offroad, tow, and still be comfortable.
    Performance
    K&N Intake
    Suspension and Steering
    Falcon Coilovers and Shocks
    Coachbuilder Shims X2 upfront
    Camburg Balljoint UCAs
    Coachbuilder Bump Stop Extensions
    Coachbuilder Steering Kit
    Coachbuilder +1 Shackles
    OME Rear Springs with Xtra Leaf
    Timbren Bump Stops
    To Do List
    Dirty Deeds 10” System
    Front Bumper
    Winch
    Sound System
    2019 Pro Rims and Spacers
    Timbren Front Bumpstops
    Lights
    Current Truck
    First Tundra
    Favorite Thing to Tow
    HappyGilmore likes this.
  2. Jul 27, 2019 at 6:59 AM
    Red_Leg
    Will
    Front Suspension and Steering
    Falcons installed on highest setting with coachbuilder shims. Everything aligned perfectly with the Camburg UCAs and Coachbuilder steering kit.
  3. Jul 27, 2019 at 7:00 AM
    Red_Leg
    Will
    New rear suspension vs factory
    Falcon shocks are 2.25 with piggyback plus 3 settings for towing.
    The factory springs are thicker with one over load spring. The Dakar is 5 springs counting the add-a-leaf plus two overload springs.
  4. Jul 27, 2019 at 7:01 AM
    Red_Leg
    Will
    Bed
    Decked System
    Voodoo Fab Crossbars x3
    Yakima Off-grid Basket with extension
    Rocky Mounts Brass Knuckles x2
    Total Chaos Bed Stiffeners
    Rigid 40" Radiance
    Power outlets
  5. Jul 27, 2019 at 7:01 AM
    Red_Leg
    Will
    Audio
    Pulled out the Phoenix Radio after a year of constant hardware problems. Screen died was a wiring issue. Fixed the screen then it turned green. Determined it was caused by a bad pin. Could never get Phoenix to send me a new harness. So I pulled it and went with the Dasiata head unit. It's not as big but functions alot better. No issues with it crashing.
    Speakers
    Just received JL C2s from tech12volts and subs. I will had pics as I get it all installed.
  6. Jul 27, 2019 at 7:02 AM
    Red_Leg
    Will
    Electrical
  7. Jul 27, 2019 at 7:03 AM
    Red_Leg
    Will
    Armor
    RCI Engine Skid
    RCI Transmission Skid
    P&P Fuel Tank Skid
    P&P Sliders
    Pelfreybilt Rear Bumper
  8. Jul 30, 2019 at 1:37 PM
    trailrnr
    trailrnr New Member
    2013 Rock Warrior CM
    Looking at running this exact setup with Camburg UCAs and coach builder shims up front. Going to just go shackles in the rear. What was your exact shim setup in the front and any idea of total lift height? I'm looking to land in the 2.5" -3" range upfront. Thanks for any info.
  9. Jul 30, 2019 at 1:44 PM
    throughitalldude
    throughitalldude New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
  10. Jul 30, 2019 at 6:36 PM
    Red_Leg
    Will
    I did not measure before lifting. Here are the measurements on 275 55 R20
    PR 42.25”
    DR 41.75”
    PF 40.5”
    DF 40”
    I have the coilovers set to Heavy Accessories with 2 Coachbuilder shims on each side. I will be calling Coachbuilder about possibly doing a third on the driver side.
    There is a 2” setting just below the heavy accessory setting. I went the way I did because I will be adding a bumper and winch.
  11. Jul 30, 2019 at 6:40 PM
    trailrnr
    trailrnr New Member
    Awesome. Thanks. Think I read in a different thread that you are liking the ride more than your previous OME setup on a different truck. Good to hear. I'm mostly on jobsites, beaches, and gravel and forest service roads so think this might be a good setup for me.
  12. Jul 30, 2019 at 7:14 PM
    Red_Leg
    Will
    I am definitely liking the ride more. I pulled 5,000# this weekend on the 2nd setting of the rear shocks. It rode smoother than the OME did unloaded.
