Any way to blend this in?
Discussion in 'Detailing' started by Gotyour6, Jul 28, 2019.
  1. Jul 28, 2019 at 9:21 AM
    Gotyour6
    Gotyour6 [OP] New Member
    Fairport, NY
    2019 Tundra Pro
    Tried my hand at fixing surface rust and although my skills are great for making it look smooth my ability to match the color is not so good.
    I have color match paint and clear but it looks to be an orange peel surface and can tell I painted it.
    I put four layers on, sanded it with 3000 and then clear coated it.
    I thought maybe rubbing compound would work and maybe it will if I keep going
    Any ideas?
  2. Jul 28, 2019 at 9:26 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    I would hit it with some medium cutting compound and a dual action polisher.
  3. Jul 28, 2019 at 9:29 AM
    15whtrd
    15whtrd Mr. Blonde
    From what I know you shouldn’t be sanding the paint but sanding the clearcoat if you’re looking to get it glossy. I think painters typically put multiple layers of clear so that they can wet sand it later.
    JohnLakeman and tomsinamerica like this.
  4. Jul 28, 2019 at 9:45 AM
    Gotyour6
    Fairport, NY
    2019 Tundra Pro
    Thanks guys
  5. Jul 28, 2019 at 3:26 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Base coat is typically only one coat. It is not intended to be sanded, only to provide the "color". The base coat should be top coated as soon as it is dry, with two or three coats of clear. If the clear is applied before the color is completely cured, the clear will molecularly cross-link to base coat. The clear is the real paint protection, and where the screw-ups (if any) will be fixed. Some orange peel is normal, and new trucks will have it. If orange peel is excessive, you can finish sand (there is technique) with 1500 grit paper, then polish out the sand scratches.
    You can try polishing your new paint with compound and a random orbital polisher, but I suspect you're looking at a re-deux for good appearance. A single coat of clear will not survive finish sanding/polishing without break-through.
    War Machine likes this.
  6. Jul 28, 2019 at 5:57 PM
    Gotyour6
    Fairport, NY
    2019 Tundra Pro
    Sanded it back down and redid it.
    Does look a lot better.
    Thanks again
    War Machine and NUDRAT like this.
