Key works in Ignition but not door?
Discussion in '2.5 Gen Tundras (2014-2021)' started by broken1812, Jul 24, 2019.
  1. Jul 24, 2019 at 4:20 PM
    broken1812
    broken1812 [OP] New Member
    Ohio
    2014 CrewMax Limited 5.7L 4X4
    So I found out the hard way that my key only works in my ignition and not my door. My keyfob has been the only way I've locked/unlocked my doors until recently so I didn't realize this.
    The strange thing is the key turns in the door, as a working key would, but nothing happens...
    I bought the truck (2014 Tundra Crewmax Ltd.) used about a year ago.
    Any ideas? Could the mechanism that locks/unlocks be disconnected form the cylinder or would I need to get everything rekeyed?
    Rica25 likes this.
  2. Jul 24, 2019 at 4:27 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    Did you replace your door handles with color matched
  3. Jul 24, 2019 at 4:49 PM
    broken1812
    Ohio
    I did not, they're the factory silver still, obviously anything could've occurred before I purchased it though.
  4. Jul 24, 2019 at 4:57 PM
    Rica25
    Ricardo
    Tulare
    Same thing happened to my tail gate after about 9 yrs
  5. Jul 24, 2019 at 5:58 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    pull the keyhole cylinder off like if u were replacing the handles. see if the key spins the shaft while in your hands
  6. Jul 26, 2019 at 5:49 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Doing this doesn’t change the lock mechanism.
  7. Jul 26, 2019 at 6:29 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    no it doesn't but if it was removed and the shaft was not aligned correctly it wont lock or unlock the doors.
    another test is opening the windows via the key
    NewImprovedRon likes this.
  8. Jul 26, 2019 at 9:54 AM
    mgxsequioa
    mgxsequioa New Member
    I had a similar issue and was able to remediate it by removing the cylinder and adjusting it. Hopefully it’s as simple
    for you....follow the instructions in the mod to remove the handle.
