Lazy need Help
Discussion in 'General Tundra Discussion' started by MookTastic, Jul 25, 2019.
  1. Jul 25, 2019 at 3:32 PM
    MookTastic
    MookTastic [OP] Because I was inverted!
    Trice
    Rapid City, SD
    2013 5.7L White D/C TSS Offroad Icon Stage 8
    Icon Stage 8 AlphaRex Headlights
    Alright, ladies, Got a curious question and I don't feel like doing the work. Figure I would just take advantage of ya'lls obsessive love of answering people's questions. My current setup is Bilstein 5100s top setting at the front and nothing else. If I wanted to get just 1 more in. upfront and 1in. in the back, could I just install 1in. blocks up front and back to achieve this? Also, if yes, would stock UCAs still be good to go? At what point do those bad boys need upgrading? I look forward to any helpful, and unhelpful answers! Also, random truck pics always appreciated.
  2. Jul 25, 2019 at 3:52 PM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    im too lazy to answer...
  3. Jul 25, 2019 at 3:56 PM
    IMHO...I wouldn't do that. Others will chime in.....
    Tundyfundy and MookTastic[OP] like this.
  4. Jul 25, 2019 at 3:59 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I just read that u want 1 more inch in thru front and stopped reading cuz I’m tooo lazy
  5. Jul 25, 2019 at 4:00 PM
    MookTastic
    Trice
    Rapid City, SD
    Love it! Hey if it's not a good idea, it's not a good idea. I appreciate the input
    jewsNbrews and Black Wolf like this.
  6. Jul 25, 2019 at 4:03 PM
    Maybe go with a totally different front coil setup and new rear leaf packs or Add a leaf with shackles?
  7. Jul 25, 2019 at 4:06 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    IMG_4601.jpg I think you mean a 1 inch spacer on the front and I would say no if your Bilsteins are at max. You would be pushing the spec on your uca.. Yes on the back..
    MookTastic[OP] and Black Wolf like this.
  8. Jul 25, 2019 at 4:08 PM
    Yep, those Bilsteins at max are preloading already!
    jeremyd[QUOTED] likes this.
  9. Jul 25, 2019 at 4:10 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    Coach builder spacers and +3 shackles give you about an overall 3”
  10. Jul 25, 2019 at 4:10 PM
    MookTastic
    Trice
    Rapid City, SD
    Awesome! So maybe I'll look at a whole new setup in the future. Would 6112s up front warrant new UCAs, idle nothing else probably just a good idea at that point huh? I have always been unclear in the difference of benefits of rear blocks vs shackles
  11. Jul 25, 2019 at 5:43 PM
    MookTastic
    Trice
    Rapid City, SD
    Yeah I was just too lazy to type spacer and block...:rofl:
  12. Jul 25, 2019 at 5:44 PM
    MookTastic
    Trice
    Rapid City, SD
    How would bilstein leveled plus 1in. Be any different than a 3-1 ready lift on stock?
  13. Jul 25, 2019 at 5:45 PM
    MookTastic
    Trice
    Rapid City, SD
    What lift setup is that?
  14. Jul 25, 2019 at 6:10 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Procomp 6 inch lift
  15. Jul 25, 2019 at 6:19 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    your right there wouldn't be, but you said your on the top setting. If you add a 1 inch spacer to that you might be pushing it.. But hey ! I'm sure other people have tried it. go for it !
  16. Jul 25, 2019 at 7:09 PM
    MookTastic
    Trice
    Rapid City, SD
    Naw I'm not looking to push the limits. mainly just curious and trying to learn more about suspension and all that can be don . Thanks!
    jeremyd likes this.
  17. Jul 25, 2019 at 7:40 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    In general spacers up front are frowned upon. It changes your suspension dynamics in a way that can cause damage to your front end. Shims are thinner spacers and can be used for small adjustments. Go for the 6112s. You'll love them. I don't think you'll need UCA's but I got them and love the steering feel. Block in the rear is ok if it's only one inch. If it fails it can be bad for your truck. Shackles are very secure and will actually improve the ride of your truck. Block will not.
    On another note, be careful with the "one more inch". That's the way I started and I'm into this thing for like 10 grand already.
  18. Jul 25, 2019 at 7:40 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Bilstein's at the lowest setting are already about .7 inch higher than then a stock setting so keep that in mind... ask me how I know. Coachbuilder shackles would be good and I agree about their spacers. You'll get just about 3 inches with just +3 shackles and with a spacer that'll get ya there. Are you just going for like a 3x1 level but with an inch more in front and rear? My guess is that you're wanting 35's possibly? And that's a hard no on new UCA'S.... ask.me how I know lol.
    MookTastic[OP] likes this.
  19. Jul 25, 2019 at 8:23 PM
    MookTastic
    Trice
    Rapid City, SD
    Yeah I told myself I would just want to level when I got the truck. I did that, then decided I wanted bigger tires. Well today I did that now I'm thinking, just a little higher. Lol wouldn't mind a little more offset too, and smaller rims, but that would be a waste of new tires....I'm seeing the problem with this forum:help:
    Tundyfundy likes this.
  20. Jul 25, 2019 at 8:50 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    On my old 2014, I put Bilstein 5100 top setting and 2 shims on each side. For the rear, Coach +2's. Pretty level., Alignment caster was a little lacking but used factory UCA's. Thinking of 6112's with 2 shims and Coach +3 for the rear on my new truck.
    MookTastic[OP] and AnonVet like this.
  21. Jul 25, 2019 at 9:02 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    I hear ya man. I began with a level and 275's then went 7 inches on 35 and now I'm 9 inches on 35x12.5r18 lol... and waiting on a new bumper being delivered money and new custom grille and other stuff.... this place sucks
  22. Jul 25, 2019 at 9:03 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Thatd be a nice set up man. I have a little rake but I'm still on the first notch with my 5100's need +3 in the rear if I go up any
    Rockgate[QUOTED] likes this.
  23. Jul 25, 2019 at 9:07 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    I loved the look with 295 /70's. It rode decent to me. I've already got the +3's and shims from Coach, can't decide on front lift.
