Really simple. Want to replace rear speakers. Not looking for BIG BOOMERS
Discussion in 'Audio & Video' started by paddyboy, Jul 23, 2019.
  1. Jul 23, 2019 at 10:05 AM
    paddyboy
    paddyboy [OP] New Member
    Patrick
    '07 Tundra CrewMax Limited
    Want to replace rear rattling speakers. Simple, no boom, boom. Just good quality speakers. Very confusing issue on web.
    Rica25 likes this.
  2. Jul 23, 2019 at 11:49 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    You are talking about the rear door speakers right? Nothing you put in there will give you any big boom boom anyway.
    Is your system still stock? No amps or anything?
    I'm not 100% certain on this, so hopefully someone will say for sure. But I think you may need 2ohm speakers if everything is still stock.
    You will need to research it. If you put speakers in that require a lot of power, and you don't have that power, they won't sound good.
    I'm sure someone will chime in.
  3. Jul 23, 2019 at 6:46 PM
  4. Jul 23, 2019 at 7:05 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Why are they rattling, did you look, something loose?
    Spend the money on a head unit, improved sound all around by instantly doubling max watt RMS, speakers alone will just give you a bit more clarity.
    After that, +1 James Tech12V, speakers, brackets all hardware you need at an excellent price. He leaves nothing out for the install.
    Trooper2 likes this.
  5. Jul 23, 2019 at 7:10 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    +1 this
    New HU with 50w x 4 does wonders.
    JoshuaA[QUOTED] and Rica25 like this.
  6. Jul 23, 2019 at 7:14 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    They are rattling because they are probably all tore apart/blown. You will see when you get the door panel off. Just put stick speakers back in and don’t let the kids turn up the bass so much??:)
  7. Jul 23, 2019 at 7:16 PM
    Trooper2
    JR
    Crutchfield.com
    Lots of options in wide range of prices.
    Rica25 and Fiestee23 like this.
