Run water pump off running light fuse.
Discussion in 'Lighting' started by cardo47, Jul 23, 2019.
  1. Jul 23, 2019 at 11:12 AM
    cardo47
    cardo47 [OP] New Member
    2018 red tundra
    I want to run a 12v 8 amp water pump to fill a 45 gal tank and plug it into the flat plug on my 2018 tundra. The motor says it is 8 amps. looks like I must have the running lights on to use this plug. My problem is finding the fuse so I cam replace it if I blow it. Cannot find the interior fuse cover to get to the fuses. Youtube usually helps but does not show where the panel is on a 2018 tundra. Cannot see it above the brake pedal and I removed the side panel and all I see is several relay plugs. where is the panel?
    Is there a easier way to power up my pump? Besides running wires, opening the hood and connecting directly to the battery?
  2. Jul 23, 2019 at 11:20 AM
    Jrharvey02
    Jrharvey02 New Member
    It takes more than 8 amps to run an 8 amp pump, energy is lost by the time water is actually moving, plus overcoming gravity, etc. but good luck...
    cardo47[OP] likes this.
  3. Jul 23, 2019 at 11:23 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Under the hood or the panel next to the e-brake
    may want to bring a generator though
  4. Jul 23, 2019 at 11:27 AM
    cardo47
    2018 red tundra
    got the panel off next to the ebrake. All I see is plastic plugs. Am I blind?
  5. Jul 23, 2019 at 11:29 AM
    cardo47
    2018 red tundra
    Thats why Jrharvey02 I want to find the fuse so I can replace it right away. If I blow it.
  6. Jul 23, 2019 at 11:31 AM
    cardo47
    2018 red tundra
    Several white plastic plugs under the cowling on the left of the E brake. I do not see the fuse box or panel.
  7. Jul 23, 2019 at 11:34 AM
    Jrharvey02
    I’d go with a fuse at least 50% higher, 12 amp to be safe, as safe as can be with whatever you’re attempting...lol
  8. Jul 23, 2019 at 11:34 AM
    cardo47
    2018 red tundra
    No wonder I cannot find it. Thanks I will go stand on my head. lol and look again.
  9. Jul 23, 2019 at 11:36 AM
    cardo47
    2018 red tundra
    Thanks Jrharvey02 I will first see if there is a 15 amp fuse. Scares me to put one in larger unless I know I will not fry the wiring before the fuse blows.
    Jrharvey02 likes this.
  10. Jul 23, 2019 at 12:01 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Do you have 7 pin/trailer brake wiring on your truck? If so, the constant power lead from that would be more appropriate for the load you're talking about.
    Use an inline fuse to protect the wiring.
  11. Jul 23, 2019 at 12:09 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Go buy a set of battery clamps like you'd find on a battery charger, an inline fuse holder, and connect it straight to the battery.
  12. Jul 23, 2019 at 12:44 PM
    cardo47
    2018 red tundra
    ya I planned a inline fuse anyway but since I gotta " stand on my head" to change a effing fuse the next easiest thing to do is to go directly to the battery.
    Thanks guys for all the great advice!
