Falken Wildpeak A/T3W Issues
Discussion in 'Wheels & Tires' started by ScandinavianMountainJesus, Jul 22, 2019.
  1. Jul 22, 2019 at 3:48 PM
    ScandinavianMountainJesus [OP] New Member
    2018 Blazin Blue Tundra Platinum
    So I recently lifted my 2018, and had the dealer mount and balance a set of LT305/65r18 Wildpeaks... After two trips back to the dealer for steering wheel vibration, I was told that three of the four had excessive road force (around 45 lbs each), and there was nothing else they could do for me.
    I have run many A/T tires, and have never had this issue. I have a few signs that point to lazy techs, like my alignment being slightly off, and the recommendation of buying balance beads, but at least I can give them credit for mounting them with the red dots in line with valve stems. DTD has been awesome through the process, and I have three new tires arriving tomorrow. Skipping the dealer and going with a very reputable local tire shop.
    So I guess the point of all this is to see if anyone else has had issues with Wildpeaks, or lazy service departments, and to share the experience. Thanks.
  2. Jul 22, 2019 at 4:25 PM
    thetwood
    thetwood New Member
    Louisville, CO
    2017 Blazing Blue Limited CrewMax TRD
    Kings, SPC, Icon Six Speed, Falken Wildpeak AT3w
    I have Wildpeak AT3W's in 35x12.5 r17 and haven't had any issues through 18k miles (other than a nail through the sidewall, but that wasn't the tires fault). Shop didn't have a problem mounting or balancing and they run pretty quiet for a big AT tire. Been happy with mine. Hope you can figure out if it's the tires or the shop and all goes well.
  3. Jul 22, 2019 at 5:26 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Stock wheels? What kind of lift?
  4. Jul 22, 2019 at 6:25 PM
    I have them on Level 8 Slams, and the lift is OME 614s and Dakar leafs with +1 shackles and JBA UCAs.
  5. Jul 22, 2019 at 7:00 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Except the red dot is supposed to be lined up with the lowest part of the rim. Highly doubt that's where your valve stem is on all 4 rims. That is probably your issue...
  6. Jul 22, 2019 at 7:10 PM
    Jmmtjoy
    Jmmtjoy Livin the dream
    Bristow, Virginia
    2016 Crewmax SR5 Super White
    Had a similar issue. Had them balanced 3 times and still shook. Had them road force balanced and it’s good to go. Took a good amount of weight, several ounces and in more than one spot on the wheel but rides fine now. Won’t buy these tires again though.
  7. Jul 22, 2019 at 7:12 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Is the alignment correct
  8. Jul 22, 2019 at 7:27 PM
    Could very well be the case. I've always understood it that if the tire has a yellow dot, align with the valve stem. If it has both yellow and red, align red. While all four have both, the "good" tire, according to the dealer, has both dots relatively close to each other, while the other three have the dots basically directly across from one another.
    If there is anything that requires analysis beyond that, like identifying high/low or heavy/light parts of the rims and/or tires, I can easily see it being a lazy tech issue. Hopefully the place I'm dealing with on Thursday is more on the ball.
  9. Jul 22, 2019 at 7:57 PM
    ChrisTRDPro
    MT
    You are correct in the fact that the yellow dot should be ignored if there is a red one.
    There is usually a very small dimple (sometimes notch) in the rim that indicates where the low point is. Should be easy enough to spot once you know it's there.
  10. Jul 23, 2019 at 2:52 AM
    It is, but it could be better. I'm having it checked when I have the new tires mounted.
  11. Jul 23, 2019 at 2:54 AM
    Thanks for the tip. I'll check it out, and mention it to the shop that's mounting the new tires.
  12. Jul 23, 2019 at 4:26 AM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    I had similar issues. 3 different shops. The first shop installed a tire with water in it. The 3rd shop finally dismounted the tire and found he water. It has been good since then.
  13. Jul 23, 2019 at 6:05 AM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    I’ve got a set on my truck without issue and I’ve got about 55,000 miles on the set on my Tacoma. I think when people have issues, it’s more likely a lazy shop than all these tires are bad
  14. Jul 23, 2019 at 6:17 AM
    That's what I'm thinking as well. I've heard great things about these tires, and can't believe QC would be poor enough to let this happen. I think it's hit or miss with dealers, and my spider sense is screaming lazy service department... I'll report back on Thursday, after I have my local tire shop take a stab at it.
  15. Jul 23, 2019 at 6:31 AM
    shellshock
    Iowa
    2019 TRD PRO
    I’ve had all mine done by discount tire. I don’t goto the dealer for anything these days
    thetwood likes this.
  16. Jul 23, 2019 at 7:26 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Falkens are cheap tires. I looked at some for my F150 and decided that the old saying "you get what you pay for is true". F150s are tire eaters and will chew up a cheap tire.
    Hbjeff likes this.
  17. Jul 23, 2019 at 7:53 AM
    blizz86
    blizz86 New Member
    I've had two sets - 315/70r17 and 285/75r17. both balanced fine and had zero shaking. Haven't seen many other complaints so it may be a bad batch (unlikely), or your techs keep doing something slightly wrong?
    equin likes this.
  18. Jul 25, 2019 at 4:32 PM
    So I took the three new tires to a local discount tire shop in town... They were basically appalled at the balancing job done by the Toyota dealer. Long story short, there was very likely nothing wrong with the tires I'm sending back to DTD... Truck is driving like a dream now. Posted an after pic below. Now the only thing wrong with this picture is the crappy wash job from the touchless wash I took it through after.
    equin, blizz86, nowayout and 2 others like this.
