New battery....
Discussion in 'General Tundra Discussion' started by Fotnot, Jul 22, 2019.
  1. Jul 22, 2019 at 10:41 AM
    Fotnot
    Fotnot [OP] SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    So after 46k miles, I am finally replacing my battery. I'm going back with OEM because I can't complain about getting almost 50k out of a stock battery. I drive my truck almost EVERY.SINGLE.DAY....with cranking it about an average of 2-4 times a day. Surprisingly, Toyota OEM is only $115. On a side note...I may be looking for another wife per the text listed below.
    *Of course I'm not getting rid of my wife. I married WAY out of my league!*
  2. Jul 22, 2019 at 10:43 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    You don't know that she's not done with you. Soooooooooo, all the more important you edit your original post so we can see her text avatar. Gotta make some decisions on this end. :duel:
  3. Jul 22, 2019 at 10:45 AM
    War Machine
    War Machine SSEM # 5 3MW
    How is she out of your league? It’s clearly not in an intellectual sense....
    SNO BUS likes this.
  4. Jul 22, 2019 at 10:49 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    :popcorn:
    SNO BUS and War Machine[QUOTED] like this.
  5. Jul 22, 2019 at 11:06 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Some of the reason I cropped out her pic....buncha horny dudes on these sights...not to mention I wouldn't want to blast her out without her permission. lol
    Out of my league per looks (I consider myself a 6 and her an 8 or 9). Plus intelligence....she's a Chemical Engineer and I'm a Pipe Designer/Drafter. So yea...out of my league. lol
  6. Jul 22, 2019 at 11:16 AM
    War Machine
    Ok. We’ll assume she was kidding or drunk when she made the Ford comment.
    SNO BUS and Fotnot[QUOTED][OP] like this.
  7. Jul 22, 2019 at 11:22 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    She did come back and say how she was joking and just trying to mess with me. She knows better! Ain't ever gonna be a Ford or Chevy our garage! ha
  8. Jul 22, 2019 at 11:30 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    The only time I ever had batteries fail for no good reason is because I let a vehicle sit too long between outings.
    Regularly driving them a reasonable distance is good for all the systems on your vehicle including the battery.
    Now that I'm retired and not driving to work every day I have to leave vehicles on a tender which helps extend the battery's life just a bit.
    NewImprovedRon and Fotnot[OP] like this.
  9. Jul 22, 2019 at 11:41 AM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    My 16 factory batt is leaking our the caps now so.im in the market and figured more people would have been in on this thread saying what they put in there trucks.i was told.a Optima is the way to go but have not researched it yet.
  10. Jul 22, 2019 at 11:42 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    What charger is that, Jonesy? You need to get you a short, ring-terminal cord and run the SAE connector end to an inconspicuous location. Then, you can avoid having to open/close the hood to disconnect/reconnect. ;)
    YardBird[QUOTED] likes this.
  11. Jul 22, 2019 at 11:47 AM
    JohnLakeman
    Look at the NorthStar AGM batteries. (Nine Tundras.com group buys) They are flat plate AGM where Optima is spiral-wound AGM cells.
    Then buy a CTEK Multi US 7002 charger ("low and slow") if you think you'll ever need to charge it or need a maintenance charger on it.
    YardBird and NewImprovedRon like this.
  12. Jul 22, 2019 at 11:50 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    From other forums/FB pages I'm on, OEM is the way to go for price and what I'm doing. If I was running some other things like winches/lights/etc on my truck, then I would look into more high end batteries.
  13. Jul 22, 2019 at 12:08 PM
    YardBird
    Jonesy
    2005 RCLB
    I bought this at Home Depot online several years ago. I killed a couple of batteries by letting my Tundra sit without being driven.
    This unit does have the pig tail and I've installed it on my battery in lieu of using the clips pictured here.
    I was a-scared that the wires would chafe on metal somewhere and cause me another issue so I merely open the hood and hook-r-up.
    A battery tender is a must have for vehicles like mine that sit for days on end ~ it's cheap insurance against premature battery death.
    NewImprovedRon likes this.
  14. Jul 22, 2019 at 12:19 PM
    JohnLakeman
    Check out this thread (link below). Your battery appears to have failed exactly on schedule (18-30 months for a 2017) as have 36% in the limited data sample. There are two overlapping statistical curves represented by this data imo...2014-2016 with longer battery life, 2017-2019 with shorter life. My 2017 battery failed at 25 months, 3600 miles, even with diligent maintenance charging.
    Battery life is typically time dependent rather than mileage dependent. Use improves your battery's longevity rather than wearing it out; i.e. your frequent usage helped your battery to last as long as it did. Toyota, like Walmart, sells them cheap. You can begin planning your next battery expenditure now...July 2021. :D
    https://www.tundras.com/threads/original-battery-life-gen-3-tundra.48235/page-2#post-1268990
    YardBird likes this.
  15. Jul 22, 2019 at 12:38 PM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    In my 14 Tundra, my battery died on the 62k (62,115 to be precise) mark. Date stamp on the OEM was 02/2014. WAAAAAAYYYYYY SHOCKED to see that date, especially shocked after reading on here how crappy they are. I got a yellow topper which I had in my taco and it did me good
  16. Jul 22, 2019 at 12:49 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Is this my friend the tin bender???
  17. Jul 22, 2019 at 12:52 PM
    RBDTx
    RBDTx New Member
    2019 Tundra TRD Pro White
    Wow. That is low mileage. Average of 144 miles per month. I have seem some threads on high mileage; wondering if that is the "low."
  18. Jul 22, 2019 at 12:53 PM
    JohnLakeman
    Production of 2014s started around August 2013, so the 02/2014 date on the battery confirms it was an original OEM battery, midyear or late. I would need a replacement date to share your excitement, but if it was this year, 60 months IS incredible these days. :D
    Did you vote in the poll?
  19. Jul 22, 2019 at 12:54 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Well. Technically it is "these sites." So what we REALLY WANT is a sight of the Mrs. on this site. Wontchyoo oblige us?????
    Fotnot[QUOTED][OP] likes this.
  20. Jul 22, 2019 at 12:55 PM
    Jrharvey02
    Jrharvey02 New Member
    I don’t think it’s a problem your battery is “leaking out the caps now”, that’s just a battery’s way of off-gassing the vapors within each cell. You want this to happen and it happens in summer time or if you leave a battery tender on too long. If you pop the cap while a battery is charging, you’ll see them “fizzing” inside...
    Sometimes it’s bad enough you have to refill the cells, with distilled water...
  21. Jul 22, 2019 at 12:55 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    I think it varies by condition. Here in SE TX, it's very hot and humid. Every OEM Toyota battery I've had, Tundra or not, garaged or not, has failed within 2 years due to leaking, including my 2018.
    I've had good luck with the advance auto AGM batteries for $~170. Half the price of Northstar and 3 year straight replacement, out of the 5 I've bought over the years only 1 needed replacement at 30 months.
  22. Jul 22, 2019 at 12:55 PM
    RBDTx
    RBDTx New Member
    Mrs.'s jaw looks nice. Think that's a jaw.
  23. Jul 22, 2019 at 12:58 PM
    Jrharvey02
    Have you tried refilling with distilled water when you notice this “leaking”. Unless a battery is cracked, they don’t leak, they off-gas...and sometimes require refilling, with distilled water and not all the way to the top, just to cover the metal plates inside.
  24. Jul 22, 2019 at 1:22 PM
    YardBird
    Jonesy
    2005 RCLB
    Hey McGov.
    I see what you did there ~ doing your Carnac The Magnificent impersonation . . .
    Yes, it's me ~ the Tin Bender from Hell with a Death Wish III.
    How's everything going in Bam-a-lama ?​
  25. Jul 22, 2019 at 2:07 PM
    YardBird
    Jonesy
    2005 RCLB
    I've been using them on a motorcycle and now my Tundra for many years.
    So far, so good. Letting a vehicle sit for long periods of time will kill a good battery every time.​
  26. Jul 22, 2019 at 2:34 PM
    ninjajay
    Spoolston, TX
    Never thought about that, is that what also causes the "furry" corrosion on the terminals?
  27. Jul 22, 2019 at 2:43 PM
    Jrharvey02
    Yup, overflow. You may have been experiencing dry cells which made your batteries take a crap. No water for the transfer of electrons = dry cell = battery failure. You don’t wanna over fill em tho, other wise you’ll be boiling over all the time. You wanna pop the caps and make sure there’s liquid just covering the lead plate within, which is about 1/2” below the hole you’re looking thru. Always use distilled water, less contaminants.
  28. Jul 22, 2019 at 2:59 PM
    JohnLakeman
    There shouldn't be any corrosion from leakage if you're buying AGM batteries. They are completely sealed, maintenance free, and leakproof.
  29. Jul 22, 2019 at 3:50 PM
    ninjajay
    Spoolston, TX
    I was referring to the OEM battery, not the AGM replacement
