2006 tundra headlights under 250$
Discussion in '1st Gen Tundras (2000-2006)' started by saltyreefer, Jul 13, 2019.
  1. Jul 13, 2019 at 8:17 AM
    saltyreefer
    saltyreefer [OP] New Member
    I have seen several headlights for 250$ and under. Anybody out there had any luck with cheaper headlights that doesn’t need any modifications to install?
    Thanks!
  2. Jul 13, 2019 at 9:56 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I’ve heard good things about the cheap eBay ones
  3. Jul 13, 2019 at 10:19 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Scored a pair on Big Gurrrl from Brasil for $115. The first set developed a leak on a side marker and they sent another full set which has been holding nicely for 6 months.
    KarmaKannon, Filthyphil and bmf4069 like this.
  4. Jul 13, 2019 at 9:49 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    Have the link to where you bought these??
  5. Jul 14, 2019 at 6:10 AM
    Fred
    Hand Protectors
    Price has dropped!
  6. Jul 14, 2019 at 6:31 AM
    bajaphile
    bajaphile New Member
    Solana Beach, Ca
    2001 4x4 Limited
    Icon Coilovers, Icon AALs, JBA headers, 285/75r16 BFG KO2s
    I've always just used Depo brand replacement headlamps and never had an issue. Not sure what the consensus is around here on them...
    Now with LED/HID technologies, there may be some better options though for housings.
    Filthyphil likes this.
  7. Jul 14, 2019 at 6:52 AM
    andrew8404
    andrew8404 New Member
    Andrew
    Cheap ones are fine but make sure to seal around the lense with a water proof silicone. That will ensure water won’t get in.
  8. Jul 14, 2019 at 7:33 AM
    Outbound
    Aaron
    Northern Alberta
    I have a set of these on the way. I'll definitely be posting a review down the road. Waterproof silicone around the joint is going to happen, just because I'm paranoid. LOL
    https://www.ebay.ca/itm/282331948051
  9. Jul 15, 2019 at 1:25 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    You can stick them in the oven for a few minutes, then squeeze them. This will help the glue spread within the seam
    Yota03 likes this.
  10. Jul 15, 2019 at 1:37 PM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    I have the Amazon set for my DC. About a year old and working great so far. Were about $180 and came with both headlights and side markers and bulbs. The boxes were labeled as Angel Eyes and were made in Taiwan.
  11. Jul 21, 2019 at 5:33 PM
    saltyreefer
    Have you got the lights yet?
  12. Jul 21, 2019 at 5:45 PM
    Outbound
    Aaron
    Northern Alberta
    Yeah, they showed up. Ran into an issue with the passenger side being defective. The seller is making it right but it'll be a bit until the replacement shows up.
    https://www.tundras.com/threads/inner-lens-cap-fell-off.49640/
    I haven't had a chance to adjust them yet, mainly because it gets dark so late here this time of year and I go to bed early. LOL
    Here's a pic though
