Pinch weld mod
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jimes, Jul 21, 2019.
  1. Jul 21, 2019 at 5:12 PM
    Jimes
    Jimes [OP] New Member
    Bay Area, California
    2015 toyota tundra trd pro
    So I searched for the title and lots of stuff popped up, but barely any pics and no dedicated thread. So I figured I would start this thread to help people out who are searching to do this. The first pics are of the initial cuts and flattened pinch weld. I used a wired dremel and metal cutoff wheel and mini sledge hammer. I went the lazy route and left the wheels on. Looking back at it I’m sure it would have been easier to do with them off, but oh well. I cut the pinch weld as well as the inner fender on the bottom so now the open area starts at the end of my bushwacker fender flares. After all the cutting and hammering I used some metal files and filed all the cuts and sharp edges and rounded them off just in case the new tires rub. I did this mod to fit 37s on a 2-3” lift. After that I used a 3m adhesive over all cuts and flattened pinch weld. https://www.amazon.com/3M-08115-Panel-Bonding-Adhesive/dp/B000PEW4MI
    After it cures(24 hours) I will POR15 the entire area as well as the frame in the wheel well. I’m doing the entire frame in sections. Will post pics of that tomorrow. https://www.amazon.com/POR-15-40909-Stop-Rust-Kit/dp/B077J66P27
    A879921E-8828-471F-9F83-6826F6DC432F.jpg995B2289-BD6B-4A91-B48C-D982CB299AE3.jpgC34A51CC-C850-4E24-8C0D-C0D1FEC0D5D1.jpg8F64C71B-BC24-465D-94D9-B5239723D243.jpg1BF64227-A7EA-4C15-8DEB-CFE0FD02B107.jpg801638F8-C203-4B2E-8EC6-1EAB2A1C909B.jpg4C42452F-C08C-4F7D-94A4-DF4FD306FA2E.jpg7A8DBE72-1247-4951-ADE6-92C36330B06C.jpg986C8127-7013-4DE2-A2EC-8E3D66572EA2.jpgC879080A-8985-437F-AF3F-DA4E795FB6A9.jpg42964ACB-03D7-47DE-A60B-F8172CCA5FAD.jpg08AD726E-6592-45B4-ABFE-DBB798788AED.jpg6A6538F0-5A89-442A-91D5-4FDD9E251F3D.jpgD9646661-3526-484F-828F-4627657EF214.jpg
  2. Jul 21, 2019 at 5:38 PM
    Speedkills119
    Speedkills119 Shenanigator
    2017 Silver Tundra 1794
    Mostly Stock Procomp 4" lift Prospeed cold air intake Bakflip bed cover HID head and fog lights 2000W JL Audio build Magnuson supercharger w/ Sniv Pulley AR Headers/full exhaust Auburn Limited Slip Prospeed fuel system w/ 1000cc injectors Dual 450 in tank fuel pump 2nd pump on a Hobbs boost reference switch Lexus RCF throttle body Prospeed catch can system TRD sway bar Prospeed Flex Fuel Tune Dirt Logic coil-over and shocks VR forged wheels CalTracs Nitto 420V 305/50R18
    I think I'll just buy tires that fit.
  3. Jul 21, 2019 at 5:47 PM
    Jimes
    It’s not for everyone. Shit at first I never wanted to do a BMC and was happy with 33s. Then I had skinny leg syndrome and said let’s go 35s. I had to do the BMC to make them fit. I told myself no bigger cause I didn’t want to do this mod, but..... here we are. Lol.
  4. Jul 21, 2019 at 7:20 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I started this today. My dead blow is at work so I tried with a hammer. Oh hell no. Did about 3 inches and gave up.
    Jimes[OP] likes this.
  5. Jul 21, 2019 at 7:34 PM
    Jimes
    Warren @831Tun recommended to cut every 3” and then hammer down. He was right. It makes a hug difference. I did one side with just one cut and all hammer work. It was not fun. Cut the other side in several places and it went faster. It’s not easy either way.
    Darkness, equin, 831Tun and 1 other person like this.
  6. Jul 21, 2019 at 7:43 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah, I made a cut and did a 3” section. But with a hammer and the wheel on. When I get my dead blow, I’m taking the wheel off and going to town.
  7. Jul 21, 2019 at 7:55 PM
    Jimes
    Oh man. That must have been an adventure. I’m sure with the dead blow and the wheel off it should go a lot smoother. Good luck.
    joonbug[QUOTED] likes this.
  8. Jul 21, 2019 at 8:42 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Are those Relentless Fabrication Body Mount Chop Plates?
  9. Jul 21, 2019 at 8:43 PM
    619Tundra
    Go Big or go home.
    Jimes[QUOTED][OP] likes this.
  10. Jul 21, 2019 at 9:02 PM
    Jimes
    No. Milo from Milpitas did the BMC and they are his custom plates. He does really good work. He also made my awning brackets.
    joonbug likes this.
  11. Jul 21, 2019 at 9:03 PM
    619Tundra
    Where is Milpitas?
  12. Jul 21, 2019 at 9:23 PM
    TheBeast
    TheBeast The Beach
    next to San Hoe
  13. Jul 21, 2019 at 9:24 PM
    TheBeast
    TheBeast The Beach
    when I got my BMC done, the guy also did the pinch weld mod. Package kinda deal....just in case I wanted to go big ;)
  14. Jul 21, 2019 at 9:33 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I have relentless plates. They’re not very aggressive. Good enough for 35’s but I’m pretty sure I’m going to have to redo them to fit 37’s.
    TheBeast likes this.
  15. Jul 21, 2019 at 9:39 PM
    Jimes
    Hit up Milo. He’s legit. You got his info?
  16. Jul 21, 2019 at 9:42 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah. I know Milo. But I’m going to do it myself.
  17. Jul 21, 2019 at 10:03 PM
    Jimes
    I didn’t know I could just cut it off. Figured it would make it a weak point unless you added something over the cut. What did you do to the cut to finish it off? Shit would have made my life easier for sure. I was always reading people going to town with a BFH. Oh well. This is exactly why I wanted to start this thread. I knew I wasn’t the only person that has done this and I’m sure there was a better way. Unfortunately I couldn’t find that info before hand.
    joonbug likes this.
  18. Jul 21, 2019 at 10:10 PM
    Jimes
    If you’ve done this before and have pics, post them. Would love to see how everyone did theirs and how they finished them off to make them look clean and keep the area solid still. The more info the better for the next guy who is going bastardize(I mean customize) their truck. Ha ha.
  19. Jan 12, 2020 at 2:31 PM
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Who did the work I’m looking to do the same
  20. Jan 12, 2020 at 2:38 PM
    Trdwillie14
    Billy
    2014 trd off road
    I have the bmc but with zero offset I rub again :yes:but not to experience in the cut and hammer application
    J&ATundra, COTundra23 and Flyinryank like this.
  21. Jan 12, 2020 at 2:42 PM
    Trdwillie14
    Billy
    2014 trd off road
    These are my numbers but 831tun says my caster should be around 4 and it won’t rub but the shop said it maybe the best they can do
    Jman245 likes this.
  22. Jan 26, 2021 at 1:06 PM
    Jman245
    Jman245 Just moving about my way.
    Jay
    R.CUCAMOMGA,CA
    '19 Tundra TRD SPORT, ‘21 Trail Edition
    Trd pro suspension
    Thanks for the thread and info! Got bmc done awhile back for 34s, now 37s, gonna need the pinch weld mod!
    saybng and Jimes[OP] like this.
  23. Jan 26, 2021 at 2:53 PM
    Jimes
    What brand of upper control arms do you have? I got SPC so that it would help with the alignment.
  24. Jan 26, 2021 at 2:55 PM
    Trdwillie14
    Billy
    2014 trd off road
    Total Chaos
    Jman245 likes this.
  25. Jan 26, 2021 at 3:02 PM
    Jimes
    Nice. I thought they added caster by design? But I guess it would make it harder to achieve the numbers you are looking for with a control arm that you can’t adjust cause you only have the lowers you can play with which is not much to be honest.
  26. Jan 26, 2021 at 3:02 PM
    Trdwillie14
    Billy
    2014 trd off road
    Yah I’m also thinking of BFG cause it’s not a true 37
    Jman245 likes this.
  27. Jan 26, 2021 at 5:28 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    Heim or bushing?
  28. Jan 26, 2021 at 5:40 PM
    Trdwillie14
    Billy
    2014 trd off road
    Bushing
    Jman245[QUOTED] likes this.
  29. Feb 26, 2022 at 7:53 PM
    Bullhead
    Bullhead New Member
    Jake
    2014 Tundra Platinum
    Are the BMC plates that SDHQ and others sell aggressive enough for 37's or will more material have to be removed? I have an ICON 3" lift with a Delta joint in the UCA and I don't know if the caster can be adjusted (says it's auto-adjusting, whatever that means). I'm also going to be running 17" ICON Rebounds which have a +25 offset which I've been told helps a lot. Thanks for any info.
    NoMoreGreen likes this.
  30. Apr 10, 2023 at 9:48 AM
    NoMoreGreen
    NoMoreGreen New Member
    Robert
    2020 Tundra
    did you ever find an answer?
