What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. Jul 20, 2019 at 3:06 PM
    #1441
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    thanks just seems like 4000 is beating it to death. at what point do you say too much?
  2. Jul 20, 2019 at 3:38 PM
    #1442
    I did just that from 4K to 89K.
    Luckydog likes this.
  3. Jul 20, 2019 at 3:58 PM
    #1443
    parkerbows
    Jack
    lost me on that one
  4. Jul 20, 2019 at 5:21 PM
    #1444
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    He beat it to death from 4k to 89k and then traded it in for a diesel.
    ColoradoTJ likes this.
  5. Jul 20, 2019 at 5:27 PM
    #1445
    parkerbows
    Jack
  6. Jul 21, 2019 at 5:24 AM
    #1446
    parkerbows
    Jack
    mine is the jayco towing with tundra obviously
  7. Jul 21, 2019 at 5:56 AM
    #1447
    trailrnr
    trailrnr New Member
    2013 Rock Warrior CM
    Work stuff
    Watt maker, CementGen3 and Casper3 like this.
  8. Jul 21, 2019 at 6:08 AM
    #1448
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
  9. Jul 21, 2019 at 6:37 AM
    #1449
    Prison rooster
    Prison rooster New Member
    Bobby
    Tn
    2018 Tundra TRD SR5
    How much does you camper way.
  10. Jul 21, 2019 at 7:39 AM
    #1450
    parkerbows
    Jack
    its heavy. 7000 dry probably 8000 with all my stuff. 99 percent of my towing is flat being on long island. after driving to PA probably done with going through NYC. i normally take it on a ferry to connecticut to get off the ialand. truck pulled great. myself though i wouldn't take it through real mountains
  11. Jul 21, 2019 at 8:05 AM
    #1451
    Zoomworms
    Zoomworms New Member
    2019 tundra TSS
  12. Jul 21, 2019 at 3:33 PM
    #1452
    PNW-Tundra
    PNW-Tundra New Member
    Brent
    Washington
    2017 Crew Max SR5 TRD
    Don’t mind the neighbors place in the background...
    ntg, Newbie_19, Prostar 190 and 6 others like this.
  13. Jul 22, 2019 at 5:44 AM
    #1453
    spicychickentundie
    spicychickentundie New Member
    Danny
    SOMD
    2014 Barcelona Red Tundra SR5 CM 4x4
    TRD RSB
    4000 rpm is fine. Like others have said already it is a gas V8. You have to rev it to get the power. You'll also see higher RPM's in tow mode since it holds the gears longer and seems to be more aggressive with the downshifts while braking.
    EDIT: Forgot to quote @parkerbows post from the last page :rolleyes:
  14. Jul 22, 2019 at 6:47 AM
    #1454
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Nice rig @Ynot_tonY. From the pic, it appears there is a WDH, but apparently the arms are not cranked in. Either that, or the adjustment needs fine-tuning.
    Mnorris1206[QUOTED] likes this.
  15. Jul 22, 2019 at 6:51 AM
    #1455
    Mnorris1206
    08 tundra
    I see what you are saying. But unfortunately with my truck myself and the guys at the camper place tried everything we could with my lift I couldn't get it to level without the bumps.
  16. Jul 22, 2019 at 7:05 AM
    #1456
    parkerbows
    Jack
    thank you i appreciate it
  17. Jul 22, 2019 at 7:28 AM
    #1457
    I purchased my 12 CM Tundra with 4004 miles and towed the hell out of it for three years. Sold the truck with 89000 miles. No blown motor towing over 3k rpm continuously.
  18. Jul 22, 2019 at 7:30 AM
    #1458
    JohnLakeman
    You might take another look at your hitch adjustment. From decades ago, I had a WDH (I think it was a Curt)...I believe that thing would have lifted the rear wheels of my little 4Runner off the ground if I didn't check front fender height. Guys selling campers should know what they're doing, but incompetence is all around us. The fact that they can't keep the tow vehicle close to level doesn't seem right to me, bwdik.
    The ball height on WDH hitches is typically adjustable, and the first step in the adjustment process is to level the trailer/tongue and measure the height of the coupler to determine required ball height on the tow vehicle. If the ball height is too high, the tongue is sloping up to meet the ball, and some of the available travel of WDH has already been used up with no gain. There are several youTube videos by manufacturers. Here is one for Equalizer, but it starts after the proper ball height has been determined. Also, another on the effect of WDH vs air bags which I thought informative. If you already know all this, I apologize for providing too much info:
    https://www.youtube.com/watch?v=ymcB2yeZr4s
    https://www.youtube.com/watch?v=XBZu39pQ8Gg
    Edit: @Mnorris1206 Ah, now I get it. Your lift has put your ball really high. If you've run out of adjustment on your WDH, it is what it is. The only solid alternatives are a taller trailer or a shorter truck. ;)
  19. Jul 22, 2019 at 7:55 AM
    #1459
    Mnorris1206
    08 tundra
    I am going to watch those and yes I have questioned them a couple times about it. But I will try to take it to another place and see what they say.
  20. Jul 22, 2019 at 8:05 AM
    #1460
    JohnLakeman
    See my edit above. Give it shot at other places, but if your WDH is at the bottom of it's ball adjustment (something you can inspect and confirm), your options may be limited.
    Mnorris1206 likes this.
  21. Jul 22, 2019 at 9:03 AM
    #1461
    JohnLakeman
    Another thing that occurs to me is the new WDH designs have an angle adjustment for the ball-mount (has an insert with washers). My old Curt had a fixed (but height adjustable) ball-mount, and a fixed angle was built into the arm trunnions. Adjustment of the ball-mount angle on newer WDH is about the second step in the installation instructions, and done in conjunction with the ball height adjustment. If your ball height is OK, then the ball-mount angle may need adjustment, and the ball height rechecked.
  22. Jul 22, 2019 at 11:23 AM
    #1462
    parkerbows
    Jack
    Oh got it. I was thinking 4k rpms to 89k?
  23. Jul 22, 2019 at 12:27 PM
    #1463
    Turk980
    Turk980 Freedom Isn't Free
    2019 Tundra Limited TRD Double cab
    Leveling kit, tires and wheels, fender flairs, nerf bar steps, flow master dual exhaust, spray in bed liner, rear airbags
    I have a set of Ride-Rite air helper spring installed (air bags), they help a bunch, i highly recommend them.
  24. Jul 22, 2019 at 1:03 PM
    #1464
    KTM Hauler
    KTM Hauler New Member
    Rich
    Santa Clarita
    2017 SR5 Tundra 4x4
    Method 306 18"x9" Nitto Ridge Grapplers 275/65r18 Leveling kit
    Photos 234.jpg pull this - it's for sale if anyone is interested.
  25. Jul 22, 2019 at 4:20 PM
    #1465
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    @JohnLakeman my lift has me sitting level almost at a negative rake. I think when I was stock I had a very slight take with the camper hooked up or I was level.
    I might play around with it when I find some free time.
    JohnLakeman likes this.
  26. Jul 22, 2019 at 5:42 PM
    #1466
    Mnorris1206
    08 tundra
    I have thought of this my trailor is really low compared to.most I have thought about reversing the shackles on it I have seen people do that before then can run a taller tire as well
  27. Jul 22, 2019 at 6:19 PM
    #1467
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Looks like mine almost! What kind of boat is it?
    Don't mind my dad's Ford haha, at least it's the 5 liter...2019-07-22 18.14.42.jpg
  28. Jul 24, 2019 at 12:16 PM
    #1468
    KTM Hauler
    Rich
    Santa Clarita
    2017 SR5 Tundra 4x4
    It's a Sanger V230.
    Our trucks look kinda similar too, nice setup!
  29. Jul 24, 2019 at 4:52 PM
    #1469
    redryder
    redryder New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    I have a question for those of you with dump trailers. I'm looking to get one to start a little side business and I'd like to get your thoughts on what size trailer the tundra can tow after getting loaded up.
  30. Jul 25, 2019 at 5:52 AM
    #1470
    spicychickentundie
    Danny
    SOMD
    TRD RSB
    I've thought about doing the same thing. On paper I don't think the Tundra could even tow the smallest tandem axle dump trailer when loaded.
