35s on a Pro? Anybody? thanks for the help fellas!
Discussion in 'Wheels & Tires' started by R0CKETMAN, May 17, 2019.
  1. May 17, 2019 at 7:36 AM
    R0CKETMAN
    R0CKETMAN [OP] IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    Been running 295/70/18 Nitto’s on stock +60 pro wheels.
    Got some +35 wheels on the way.
    Would like to go with 35s
    I do have two Coachbuilder shims each side up front. Fwiw
    Thanks for the help fellas!!
  2. May 17, 2019 at 7:57 AM
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Nashville, TN
    2019 Super White TRD Pro
    I run 35x12.5x18 on my pro. Have the @Coachbuilder1 Pro kit installed. 1.25" Spidertrax, had to take all the front mud flaps off, and heatgun + hammer to the liner to clear the rub.
  3. May 17, 2019 at 8:30 AM
    RoninPro
    RoninPro Abecedarian BASTRD
    East Bay
    17 CM TRD Pro
    A lot of folks are running this config. Same as the previous poster.
  4. May 17, 2019 at 8:31 AM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Yeah Same.
  5. May 17, 2019 at 8:45 AM
    R0CKETMAN
    NGAMTNS
    Roger that. Did you try the Ekstrom shim kit?
    Thanks. Any cab chop?
  6. May 17, 2019 at 8:46 AM
    R0CKETMAN
    NGAMTNS
    Pic/s please / tnx
  7. May 17, 2019 at 8:48 AM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    No cab chop (but I'd like to do it just cause). I have some rubbing on the front fender liners when I turn in reverse only. But I did the bumper shim kit.
    Im on BG K02 35x12.5r18 with 1.25 Bora Spacers
  8. May 17, 2019 at 8:51 AM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
  9. May 17, 2019 at 9:07 AM
    RoninPro
    East Bay
    17 CM TRD Pro
    Yes, cab chop done. Ekstrom +3 Coachbuilder kit.
  10. Jul 19, 2019 at 5:04 PM
    ncomeau35
    ncomeau35 New Member
    2019 White Toyota Tundra TRD PRO
    Nitro Ridge Grappler 285/75/18
    Just put on a set of Nitto Ride Grappler 285/75/18 tires, they are listed as just north of 35". They fill out the wheel well nicely and look awesome. There is a slight rub on the front mud flap, but that will be fixed in the AM
