4.7 timing belt
Discussion in '1st Gen Tundras (2000-2006)' started by sidewinder81, Jun 20, 2017.
  1. Mar 23, 2019 at 6:13 PM
    #61
    Dpy
    Dpy New Member
    Got kit yesterday , mostly installed today . Still gotta finish but did get water pump and belt back in .
    revtune likes this.
  2. Mar 24, 2019 at 4:28 PM
    #62
    fischerja
    fischerja New Member
    05 Tundra SR5 98 Tacoma 07 Sequoia LTD 87 4Runner
    All i can say is..
    REPLACE YOUR BELT AT RECOMMENDED INTERVAL.
    Pics to prove these are interference engines:IMG_3565.jpg IMG_3567.jpg IMG_3568.jpg IMG_3569.jpg IMG_3566.jpg
  3. Mar 24, 2019 at 5:35 PM
    #63
    Dpy
    Dpy New Member
    Crap , well I guess I gambled for 60Thousand miles . I did see one tooth ( if I can call it that ) on the belt that was sorta frayed .
  4. Mar 26, 2019 at 5:37 PM
    #64
    Dpy
    Dpy New Member
    Just finished belt and waterpump install , had work related stuff and parts holding me up. Started up smooth , no lights no grinding HA . Gotta say not too impressed with gates brand tensioner, pulley had a little play , took pulley off and it was in bearing. Old one was tight and smooth. Also the washer between the bolt and bearing was really flimsy , not thick like the factory but they wont interchange. Tension was a bit more than old one so I went with it. Over all if I worked strait through would have been probably 7 to 8 hours maybe.
  5. May 30, 2019 at 10:07 PM
    #65
    2003 tundra 4x4
    2003 tundra 4x4 New Member
    2003 tundra 4x4 sr5
    Bigger tires "17s"
    I haven't changed mine since 90k and now it has 302k miles the truck does have starting problems luke having hard time to start at cold nights or day the truck looses may jorly of its power
  6. May 30, 2019 at 10:12 PM
    #66
    2003 tundra 4x4
    2003 tundra 4x4 sr5
    Bigger tires "17s"
    My truck has over 300k haven't replace it scince 90k it hasent brake yeet but my tentioner pully completely cheered off and the truck does start having problems like starting and losing so much power
  7. Jun 9, 2019 at 5:13 AM
    #67
    bovavet
    bovavet New Member
    2010 SR5 crewmax, 2012 SR5 double cab ,2014 limited double cab, 2016 TRD PRO,2008 FJ, 2010 FJ
    Interesting thread, I have an 01 with 360k, original timing belt. You guys are making me nervous
    Sangre Kid and Icon2000 like this.
  8. Jun 9, 2019 at 5:27 AM
    #68
    I bet you'd do well in Vegas. ;)
    Tundra18overland and bmf4069 like this.
  9. Jun 11, 2019 at 9:08 PM
    #69
    2003 tundra 4x4
    2003 tundra 4x4 sr5
    Bigger tires "17s"
    Oh man you should be mine has more than 300k and the belt jumped water pump starded spuing water from the bottom when it starts having problems the truck doesn't start when the engine is cold
  10. Jun 14, 2019 at 10:45 AM
    #70
    billw
    billw New Member
    bill
    2006 Tundra DC
    I think fischerja just answered any and all questions about the 4.7 being an interference engine!!! A friend's Lexus 470 broke the timing belt at parking lot speeds with zero damage; i can now verify to him how lucky he was.
    bw
  11. Jun 21, 2019 at 5:14 AM
    #71
    dd04tundra
    dd04tundra New Member
    david
    04 tundra 4.7
    None ......YET
    My wife and I stood on that exact spot when we went to Vancouver for our 20th anniversary. We loved that park.
  12. Jul 11, 2019 at 2:40 PM
    #72
    CreativePaul
    CreativePaul New Member
    Paul
    2004 Tundra
    Need to do the timing belt job on my 2004 Tundra. Any advice on parts brand? Toyota wants 2.5 times what some of the kits cost. Unsure about buying Dayco, etc.
  13. Jul 11, 2019 at 2:42 PM
    #73
    Professional Hand Model
    Fred
    Hand Protectors
    Go to toyota parts dot com. Enter your VIN# and they will ship the OEM parts to your door for way less than stealerships.
    CmdrDaniels and remington351 like this.
  14. Jul 12, 2019 at 6:37 AM
    #74
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Not the place to skimp IMO, given the labor involved in a timing belt replacement, and its importance. Pay whatever it costs and buy the OEM Toyota parts, my .02. chunk.
    Dannydirtyfingers likes this.
  15. Jul 12, 2019 at 8:12 AM
    #75
    duncanrc
    duncanrc New Member
    Duncan
    2014 SR5 Double Cab 2WD 4.6L
    I installed OEM parts on my 2004 4.7L
    Aisin TKT-021 Engine Timing Belt Kit with Water Pump
    CAN$225
    https://amzn.to/2l9ezWd
    Installation $400
    This is the belt with 450,000km on it
    57034724_892650154411482_424920209158884_f575787e7f8264a4a215f0f07d0c34d461e53aeb.jpg
    Sangre Kid, revtune and TX-TRD1stGEN like this.
  16. Jul 12, 2019 at 1:10 PM
    #76
    duncanrc
    duncanrc New Member
    Duncan
  17. Jul 12, 2019 at 8:42 PM
    #77
    CreativePaul
    Paul
    2004 Tundra
    Where can I find a resource for the locations specs for a 2004 4.7 V8 pulleys/belt?
  18. Jul 19, 2019 at 1:00 AM
    #78
    Icon2000
    Icon2000 New Member
    Renaldo
    2004 SR5 Crew Cab 4.7l
    Just purchased a 2004 SR5 DC with 103,000 miles. So this thread is very interesting! Will change mine soon.
  19. Jul 19, 2019 at 1:19 AM
    #79
    Aerindel
    Aerindel New Member
    Montana
    Mine has 320...belt replaced at 310....I need to find the pics....but it was cracked to hell and back...a crack at every tooth. I don't know how the hell it was holding together. It must have been the original belt.
  20. Jul 19, 2019 at 1:47 AM
    #80
    Icon2000
    Icon2000 New Member
    Renaldo
    Wow longevity
  21. Nov 2, 2019 at 2:49 AM
    #81
    05dustytota
    05dustytota New Member
    05 tundra 4
    Air intake and leveling kit
    I have a 05 tundra with 240k I’ve owned it all but the first 40k and it’s spinning on original running belt
    Icon2000 likes this.
  22. Nov 2, 2019 at 3:47 AM
    #82
    Drfarquad
    Drfarquad New Member
    Bobby
    Milford
    2005 Tundra Limited DC
    OME 3 inch lift level, UCAs, Icon AAL
    Im in the middle of doing mine right now. Just bought the truck about a month ago didn't see any records of it being changed. Truck had 132k on it. Pulled it apart and yup original Toyota belt. I would assume that it is original. About to get back out in the driveway as soon as it gets lighter outside.
  23. Nov 2, 2019 at 4:04 AM
    #83
    Icon2000
    Icon2000 New Member
    Renaldo
    How does your original belt look?
    Drfarquad likes this.
  24. Nov 2, 2019 at 5:03 AM
    #84
    Drfarquad
    Bobby
    Milford
    Honestly it looked great. I watched kaling somewhere that typically the color of the numbers and lettering on the belt itself typically wears away around 50k to 60k. If this is true mine was well over that. There wasnt any coloring left to the belt. Other than that, it was dry(no oil or coolant), not cracked what so ever, and everything looked intact. Even all the components to the timing belt looked to be in great order. I'll see if I still have the belt. I'll take a picture of it. Although I'm quite positive it got thrown out.
  25. Nov 2, 2019 at 6:00 AM
    #85
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    I just ordered the same kit, plus OEM thermostat and gasket from Amazon yesterday, and a belt drive component kit from RockAuto. At 127,000 miles, I was getting a little nervous thinking the sky is falling. Hope to install it by mid-month.
    Sangre Kid, revtune, bmf4069 and 2 others like this.
  26. Nov 2, 2019 at 6:23 AM
    #86
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I think the tensioner loosening is more of a concern then the belt breaking. That's what causes trucks to "jump" timing.
  27. Nov 2, 2019 at 8:16 AM
    #87
    Bergmen
    Bergmen New Member
    Ukiah, California
    Both times I replaced the belt on my 2006, they were almost indistinguishable from new. I had to be careful where I set it down on my workbench, I didn't want to accidentally put the old one back in. Both done at around 100,000 miles.
  28. Nov 2, 2019 at 6:24 PM
    #88
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Aisin/OEM parts needed will run about $250-$300.
    I also recommend getting the aisin (FIPG) or something like optimum gray for around the square water pump inlet/outlet.
    find a good pro independent mechanic and labor should be between $300-$500.
    I wouldn’t mess with the crankshaft seal or camshaft seals unless they are leaking.
  29. Nov 2, 2019 at 7:51 PM
    #89
    marbleville
    Yep, last name too.
    State of Confusion
    And that Aisin FIPG is what?
    Done. I house sit and took care of my neighbor's dogs for eight days while he went on his honeymoon to Mexico. In repayment he is going to HELP ME do the install. He is a professional mechanic and has done a couple timing belt replacements. I will be doing the work with him assisting and advising. It is at his advice that I am replacing the belt components I ordered from RockAuto, along with the two major radiator hoses. He wants me to do it right the first time, and I like his suggestion enough to spring for the parts.
  30. Nov 2, 2019 at 8:29 PM
    #90
    revtune
    revtune New Member
    Dane
    Houston Texas
    :thumbsup:
    FIPG stands for “formed in place gasket” the Aisin kit I got did not have a gasket for the square hole on the water pump. Instead there was a note inside suggesting aisin FIPG.
    This is a list of the parts I got when I had my timing belt job done:
    Timing Belt
    Timing Belt Tensioner Bearing
    Timing Belt Idler Bearing
    Water Pump
    Water Pump Gaskets and Seals
    Thermostat
    Thermostat O'Ring
    Serpentine belt
    Aisin FIPG
    2-3 Gallons of pre mixed anti freeze with zerex (I like valvoline):thumbsup:
