trailer pullers
Discussion in 'General Tundra Discussion' started by Sonicbluerider, Jul 17, 2019.
  1. Jul 17, 2019 at 11:13 AM
    Sonicbluerider
    Sonicbluerider [OP] New Member
    Dennis
    2019 Tundra
    do you use air bags of better rear shocks???
  2. Jul 17, 2019 at 7:45 PM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    I use Timbrens but, also don't Max out my tongue weight. I rarely feel them. Wanted to stay away from compressors and hoses.
    JoshuaA likes this.
  3. Jul 17, 2019 at 8:01 PM
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    i also use timbrens. i only tow every once in a while and they work great. when im not towing i remove the timbren spring and put in my wheelers super bumps. takes about 5 mins to do the switch. best of both worlds
    JoshuaA and Mr Swervlin like this.
  4. Jul 17, 2019 at 8:44 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I use air bags when towing, When I'm not towing I drain the bags..The shocks don't have anything to do with height.
    JoshuaA likes this.
  5. Jul 17, 2019 at 8:59 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I have 1.5" shackles, so I use Timbrens and 1.5" spacers. When not towing most of the year, the spacers take me about 10min to remove so I'm not harshly hitting the setup in day-to-day driving over bumps etc (with spacers):
    imho if you tow a lot, Airbags probably feel better because you adjust the psi based on load. I only tow about 3-4x/year, I like the frame free when not towing, and set it forget it aspect, Airbags are always in contact with the frame.
    jeremyd likes this.
  6. Jul 17, 2019 at 9:05 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    This.
    OP, your choices are mainly Airbags, Timbrens, Sumosprings, Hellwig Helpers for suspension support. And levelling is done with a WDH.
  7. Jul 18, 2019 at 1:47 PM
    Sonicbluerider
    Dennis
    2019 Tundra
  8. Jul 18, 2019 at 1:54 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    My Firestone airbags are performing well. We've towed our 6,000 pound 5th wheel (1,050 pound hitch weight) 7,250 smooth miles with zero issues
    Sonicbluerider[OP] likes this.
