Suspension help? UCA
Discussion in '2.5 Gen Tundras (2014-2021)' started by Grizzly660, Jul 15, 2019.
  1. Jul 15, 2019 at 10:30 AM
    Grizzly660
    Grizzly660 [OP] 21 Army Green Sport
    North Dakota
    2021 Army Green Sport
    20 inch XD Hoss wheels with Nitto EXO Grappler Wetokole seat covers
    Just returned from road trip little over 600 miles and did a once around check on my Tundra and noticed some grease. See pic. It is on both driver and passenger sides. Is this normal or how much is it going to cost to fix?
    Also does the circled in yellow link look bent? This is drivers side.
    I've never done any off roading other than gravel and minimum maintenance dirt roads, never hit anything...
    Any input would be appreciated. Thanks in advance!
  2. Jul 15, 2019 at 10:59 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Yellow circle is sway bar end link. I does look bent to me. Shouldn’t be too critical but should be cheap to fix. Second picture is your ball joint. I heard a guy from the dealer say they put a syringe with grease under the boot to refill them with grease and that some leaking is normal.
  3. Jul 15, 2019 at 11:04 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    UCA seepage is normal.
    Sway bar end link is bent.
  4. Jul 15, 2019 at 11:13 AM
    The good news is that someone probably makes sway bar end links that are better than factory. I'm not as familiar with current Tundra's but I can't imagine they will cost much.
  5. Jul 15, 2019 at 6:47 PM
    Heeler13
    Heeler13 21MGM
    Eastern NC
    2021 Sr5 XP
    Bilstein 5100 Front @ middle setting Bilstein 5100 Rear @ stock height Oem older Pro wheels 285/75/18 Maxxis Razr a/t
    As stated above.....
    Sway bar end link bent. Easy fix.
    Ball joint seeping grease, wouldnt worry about it
  6. Jul 15, 2019 at 7:00 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    The sway bar end link shows about $138 each at Sparks Toyota parts.
  7. Jul 16, 2019 at 4:45 PM
    avgasman
    avgasman New Member
    It never ends does it?
    Ouch! That's about twice what I thought it would be worth.
  8. Jul 16, 2019 at 4:57 PM
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    We actually discussed the uca ball joint leak in a thread not too long ago.
    Since we're all giving opinions, here's mine; ball joints leaking grease is not normal. Would I replace it if I had to pay for it? Not until there was play in the snow joint. Would I ask to have it replaced under warranty, if I had coverage? Sure.
    On my 2018, one joint leaks, the other does not. If leaking were normal, they would ALL leak.
    (...and I've never known a manufacturer to suggest that a leaking joint was normal...)
    ...and to push the subject, if grease can get out, contaminants can get in.
    I agree that the end link is bent.
