Yellow dots just for looks ! Wtf
Discussion in 'General Tundra Discussion' started by jeremyd, Jul 15, 2019.
  1. Jul 15, 2019 at 9:21 AM
    jeremyd
    jeremyd [OP] 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I went with my Son yesterday to the Dealer to buy his first brand new vehicle. He loves it ! A 2019 4Runner.
    This morning looked at the tires and noticed the yellow dots not even close to the valve stem. It does drive smooth but also noticed at least 6 ounces of weight on one of the tires. Weird to me that it came straight off the lot like that..I guess that’s just the standard these days..
    F7723612-CBC3-4843-818E-B749BE5CFC99.jpg 999BD140-B6B4-4F3C-963C-999CF7504CF6.jpg F7723612-CBC3-4843-818E-B749BE5CFC99.jpg
  2. Jul 15, 2019 at 9:42 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Well the tire has a red dot, so they probably lined that up with the low spot on the rim so the mounted tire was as round as possible. Having the tire as round as possible is more important than minimizing added weight.
  3. Jul 15, 2019 at 9:47 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Yea, my mistake I meant red dot..
  4. Jul 15, 2019 at 9:48 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I bet if I post pictures of the weights, it would be unsat to most people..
  5. Jul 15, 2019 at 10:18 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Not quite sure I understand, Are you saying the just the wheel was balanced first ? Then the tire was mounted and balanced ?
  6. Jul 15, 2019 at 10:23 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    From what I’ve researched and been through the last year, six ounces isn't that big of deal on a suv/truck. I wouldn’t worry about it.
    jeremyd[OP] likes this.
  7. Jul 15, 2019 at 10:33 AM
    ChrisTRDPro
    MT
    No, the rim has a mark on it (or a dimple) to show where the "low" part of the rim is. The red dot on the tires show the "high" point of the tire. You usually match those up so that when you mount the tire to the rim, the tire isn't egg-shaped. If the tire has a red dot, it should take precedent over the yellow dot. The yellow dot just shows the lightest part of the tire.
    jeremyd[QUOTED][OP] likes this.
  8. Jul 15, 2019 at 10:36 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    From what I understand if the weights are under 1 percent of the weight of the tire wheel combo you’re in an acceptable range.
  9. Jul 15, 2019 at 10:52 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    4Runners are notoriously sensitive to tire alignment and balancing, even with the stock tires. If it’s out at all, you may get a little shimmy in the steering wheel around 55-60mph. If that happens, I’d definitely take it back and make them sort it out.
  10. Jul 15, 2019 at 11:12 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Thanks guys, he loves the 4Runner and it does drive smooth at all speeds.
    I’m definitely not going to put my ocd onto him , lol.
