The Real and the Mythical
Discussion in '1st Gen Tundras (2000-2006)' started by marbleville, Jul 4, 2019.
  1. Jul 4, 2019 at 5:14 PM
    marbleville
    marbleville [OP] Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    I must say that my association with this forum has been very beneficial to me.
    First, you guys keep me mentally engaged.
    Second, you individually and collectively, teach/instruct with overall sound knowledge from a diverse group, often in disagreement, but which lends the viewer a broader knowledge than the typical "pat" answer we are so accustomed to in normal discourse, should one pursue it.
    Third, your enthusiasm is contagious and infects - no inspires - those receptive to the great fondness you have for your Tundras. I named mine Trixie; she is the only inanimate object I possess that I have so named.
    I've learned, through research inspired by forum discussion, and contrary to what I've been taught, that drilled and slotted disks have little value to the average driver and only weaken the disks. The slotted may well figure into the needs of the racer, who is willing to sacrifice an extreme short pad life for a continuing renewal of the pads surface as he brakes and shaves off a minute amount of the pad each time the slots travel over the disk's surface, thus keeping the pad clean. As to the drilled disks, the generally held position within the automotive engineer's world is that there is no value, and that the heat dispelling character so attributed to it is bunk science. Anecdotal info, for sure, with no cites.
    As a former legal researcher, I follow hunches at times as well as sound leads and legal precedent. I often enough wear the attire and carry the unperturbed constitution of the Don Quixote of our literary past, looking for dragons to wage the good fight. In a field where the most subtle change in language, word choice, can upend data/evidence; you tend to look broadly at issues and bulldog those that are unsettled, if for no other reason than to put them to rest. Sometimes all this "data" is simply coincidental, proving nothing, with no facts or linkage to support in the long run - that's what research is partly all about, finding fact over fiction, to simplify the point here.
    So it was with the ABS bleeding, as false flags from a variety of sources indicated this was a real issue for the 2002 Tundra. It still might be, though I am reluctant to pursue it further myself, having chased too many unsupported claims and having been given an unimpeachable statement from a competent witness that such a procedure doesn't exist. Formally or officially.
    I have indeed been inspired to become more involved with Trixie. I have recently gone out and replaced the tools that were stolen almost two years ago. I even upgraded to the new and very much improved lithium-ion battery powered universe, taking advantage of several seasonal sales events and buying what I perceive to be quality consumer-grade drill drivers, impact driver, impact ratchet and impact wrench. Two torque wrenches, a large breaker bar, and new floor jack. Tool boxes and tool rolls, wrench sets and sockets galore - chrome and impact. Three chargers and five lithium-ion batteries, to add to those I still possessed. Then I schooled myself on how to resurrect those batteries from the dead, while buying a multimeter to join my soldering iron for the predicted future occurrences.
    My ancestors were Scots, noted for their frugality, so any expenditure on my part that spreads itself over a large period of time is most noteworthy and unusual - so goes inspiration, I guess. I walked away from most wrenching about thirty years ago, with neither the time nor the disposition to agreeably work on cars, etc. Then I bought a Jeep and my wrenching went to hell as none of my efforts bore good fruit and I kicked the Jeep out of my garage and invested my time with my horses. Now retired as I am, and no longer owning the farm, I have the time to invest in Trixie. Short of any major issue, I will happily devote the money and effort to keep her in a "cherry" condition. She is a classic that I will ride into my sunset.
  2. Jul 4, 2019 at 6:32 PM
  3. Jul 4, 2019 at 9:19 PM
    Aerindel
    Aerindel New Member
    Montana
    The internet would be a better place if everyone had your attitude.
  4. Jul 5, 2019 at 5:35 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Good follow up.
  5. Jul 5, 2019 at 6:28 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Here - Here! :cheers:
    nlaroy likes this.
  6. Jul 9, 2019 at 2:23 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    well written and compelling. I purchased the drilled and slotted rotors for my truck several years ago and they do work better at dispersing heat than the OEM rotors for long steep descents even while using my low 4x4 gear to control speed. There are trails out here where you will still need to brake even in low :) However, for daily driving they make no sense to me.
    Black Wolf likes this.
  7. Jul 9, 2019 at 2:37 PM
    Fred
    Hand Protectors
    I’m still wondering if he ever bled his ABS module/corrected his ‘real or mythical’ problem? So many parsings of words.
  8. Jul 10, 2019 at 2:31 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    I like the name Trixie, OP.
    I've named all my trucks.
    99 taco was Pearl
    03 taco was Misti
    06 tundra is Penelope
    Tundyfundy likes this.
  9. Jul 10, 2019 at 4:19 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    A Scot??? Cheap bastard, buy a new truck! :boink:
    TXMiamiFan likes this.
  10. Jul 10, 2019 at 4:33 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Shew that was a MOUTH full !!
    Welcome from northern Maryland :hattip:
  11. Jul 10, 2019 at 4:44 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I just read the first 3 sentences. Hold on... I’ll be right back. Going to look for my dictionary and thesaurus.
  12. Jul 14, 2019 at 2:07 AM
    marbleville
    Yep, last name too.
    State of Confusion
    I have been a writer for the better part of my life, off and on for about 50 years, and something hard to just walk away from when it has become so ingrained. Now retired, it is the one thing I miss the most and it shows in my comments as I indulge in my craft. Apparently in detriment to my audience, here. Sorry guys, I just don't write in any other manner.
    The ABS system is no longer in question, though I will be revisiting the brake issue at a later date, as it has been put aside for the time being as I work a perceived problem - Trixie is sporting a mileage of 125,000 and in need of a transmission fluid service. I have no info on the previous owner and his maintenance on the truck, but I do know that the truck came with the towing package and he had an electric brake controller installed, though what kind and how it operated is unclear to me. What it means is, if he did use her to tow, then I would hope that he would have serviced the tranny more often than is usual - I simply do not know, such is my concern. With this in mind and the fact that I have no idea what type of tranny fluid has been used, I decided to go beyond a mere drain of four quarts and refill, to the more thorough removal of the pan and replacement of the filter and fluids. While I am at it, I plan on installing a Magnefine filter on the tranny's return line from the cooler. And I have finally sourced 14 liters of pure Dexron III tranny fluid which will be delivered this week, as well as the drain plug washers and gasket. I plan to follow up with a complete fluid service of the diffs and transfer case, as well as flushing the power steering system and replacing the fuel filter.
    Future plans include replacing the master cylinder and both rear brake drums, before moving on to an exhaust system built around the Flowmaster 50 Delta muffler.
    War Machine, 02goes, bmf4069 and 4 others like this.
  13. Jul 14, 2019 at 6:03 AM
    Fred
    Hand Protectors
    Sweet Marbles. Where are we getting the Pure DexIII?
    You have a pic or link?
  14. Jul 14, 2019 at 6:30 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    A similar situation with my 2007, no service records and the previous owner had moved the brake controller to another vehicle before putting the truck up for sale. I systematically replaced all fluids & filters, and I performed all of the other factory recommended maintenance for a truck that towed in severe conditions. The truck had 270k when I purchased it cheap, so brakes, shocks, springs, tires and other items wear & tear items were replaced with new. It now has about 286k on it, and it runs & drives great.
    My awesome 2002 will hit 165k soon... it has required very little extra maintenance & repair.
  15. Jul 14, 2019 at 1:50 PM
    Aerindel
    Aerindel New Member
    Montana
    You should try some other forums. Your post would be considered terse on some. Although writing more than a line or two on your phone is fast becoming a lost art there are still some places where multi-page comments are common.
  16. Jul 15, 2019 at 10:44 AM
    I hate scrolling forums on my phone. I picked up my galaxy tab s3 from Verizon so it has 4g service and I can browse wherever whenever.
  17. Jul 15, 2019 at 10:47 AM
  18. Jul 28, 2019 at 8:00 AM
    Fred
    Hand Protectors
    Marbles, hows the ‘pure stuff’ working for ya?
    I’m sticking with the DEX/MERC as its more tailored to our transmissions. The Maxlife by Valvoline caters to a broader spectrum of vehicles, but if you read between the lines its probably not the best choice for 2002 year A340F.
  19. Jul 28, 2019 at 11:40 PM
    marbleville
    Yep, last name too.
    State of Confusion
    The Dex/Merc may be the ticket, but I just did the pan removal and filter replacement, refilling the tranny with almost 12.5 liters of Dex III that I purchased from Amazon after buying the last 14 liters they had. The tranny is shifting fine, as it was before I changed the fluid. I did note that the fluid that was in it looked brand new, bright pink and no burnt smell. Maybe I got ahead of myself, but it's nice to know it's all copacetic now.
    Like I said, Amazon sold me the last it could muster up, with the boxes coming from 5 different shipping points. Could it be that I bought the last Dex III in the states? It sure was a chore finding the 14 liters I did buy. I guess it will be Dex/Merc for the next service...
  20. Jul 29, 2019 at 5:13 AM
    Fred
    Hand Protectors
    How’d your pan contents look? Fine metal or chunks?
    Your screen contents? Clogged?
    Good news on the fluid looking new. Which screen/filter/gasket did you use?
    Just saying you bought something on Amazon could mean a number of possibilities. How about some actual brand names and maybe pics?
  21. Jul 29, 2019 at 5:36 AM
    marbleville
    Yep, last name too.
    State of Confusion
    Well lets see now...[​IMG]
    [​IMG]Beck Arnley 044-0307 Automatic Transmission Filter
    [​IMG]Transmission Drain Plug Gasket Engine Oil Crush Washer Seal Rings for Toyota 4Runner Sequoia Tacoma Tundra Lexus GS450H, IS F, IS250/350, LS430, LS460
  22. Jul 29, 2019 at 5:39 AM
    marbleville
    Yep, last name too.
    State of Confusion
    [​IMG]Plews LubriMatic 75-068 All-Purpose Extra Long Super Funnel for Engine Oil, Transmission Fluid, Power Steering Fluid, and More - 2 Quart Capacity
    [​IMG]Lisle 17942 Black Plastic 4.5-Gallon Drain Pan
  23. Jul 29, 2019 at 5:39 AM
    War Machine
    War Machine SSEM # 5 3MW
    Haha don’t sweat it. I tend to get pretty long winded myself.
  24. Jul 29, 2019 at 5:40 AM
    marbleville
    Yep, last name too.
    State of Confusion
    I also bought and used a lube gun and some Valvoline red lithium grease[​IMG]
  25. Jul 29, 2019 at 5:51 AM
    Fred
    Hand Protectors
    Looks like you cleaned out the stock. You very well may have the last batch of pure DEXIII in the world.
    I saw that Beck Arnley screen when doing research. There is a Wix filter, as well. How’d your old pan contents look?
  26. Jul 29, 2019 at 6:18 AM
    marbleville
    Yep, last name too.
    State of Confusion
    The Beck Arnley didn't come with a cork gasket but rather a soft black rubber one. I used a utility knife (razor blade) and a razor blade affair made for removing decals, etc., from glass to scrap off the old gasket material. The old filter had nothing, no shavings, crud, nor pieces of metal in it. The pan was basically clean, as were the 4 magnets.
    Using the funnel made for an easy but slow fill. I only had to top the fluid up on one occasion. Well, so far. I did the service by myself, as my son was far too busy. That's it.
    My next project is the replacing of my instrument cluster lighting with LEDs - going for the blue look, though I want to have a differing light scheme for the gear indicators. Then on to the interior lighting. I have already spent a great deal of time trying to ascertain what the differing bulbs are called, part#, etc., where they go...it's been a pain trying to decipher. Seems some bulbs have several names/numbers to identify them, ouch! Anyway, that is what's currently on my task list.
  27. Jul 29, 2019 at 7:45 AM
    marbleville
    Yep, last name too.
    State of Confusion
    @Professional Hand Model ...Just to put this to rest while addressing your skepticism and questioning of my comments, actions, etc., I decided to include this redacted (and now unformatted) invoice. BTW: it was seven boxes not five.
    Order Details
    Ordered on July 11, 2019 Order# 111-2058449-853XXXX
    Shipping Address
    XXXXXXX Russell
    XXXXX S. Shore Drive XXX
    XXXXXXXX, WA 982XX-XXXX
    United States
    Payment Method
    XXXXXX Card **** XXXX
    Order Summary
    Transactions
    7 Shipments
    Delivered Jul 15, 2019
    Package was left in a parcel locker
    Track package
    3
    3 of Total 802355 Neptuna Hydrofluid3 GM DEXRON III Automatic Transmission Fluid - 1 Liter Bottle
    Sold by: Amazon.com Services, Inc
    Return eligible through Aug 14, 2019
    Track package
    Track package
    Track package
    2
    2 of Total 802355 Neptuna Hydrofluid3 GM DEXRON III Automatic Transmission Fluid - 1 Liter Bottle
    Track package
    3
    Track package
    Track package
    3
  28. Jul 29, 2019 at 7:46 AM
    Fred
    Hand Protectors
    Good news and it is piece of mind knowing your pan looked good!
    Your info here has helped me make a decision NOT to drop my pan for purposes of installing a new screen. I have been researching valve body kits that ‘improve/customize shifting points’ and if I decide to go that route will have to drop the pan and use a WIX screen gasket kit that reviews well per Toyota commenters.
    Your findings on your pan corroborate two other 2002 Tundra/Sequoia owners as being super clean on drop inspections. Bottom line seems to be don’t fix if its not a problem.
    Thanks for your info.
  29. Jul 29, 2019 at 7:51 AM
    Fred
    Hand Protectors
    Only questioning for answers on findings etc. to help others and myself. See above comment. Not sure where the paranoia about skepticism/actions (if there is any) comes into play.
    We can’t read your mind so pictures and specific descriptions help. Thanks again.
    FirstGenVol likes this.
  30. Oct 6, 2019 at 7:19 AM
    Fred
    Hand Protectors
    Yeah Marbles. Reading your progression here over the last several months and it appears you’ve finally gotten your meds adjusted to proper levels? Anyways, I’m surprised with your extensive law-fare background you missed the option of DEX VI due to a loose marble or three?
    DEX VI Licensed and Approved by GM as replacement for DEX III.
    bmf4069 and TX-TRD1stGEN like this.
