What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. Jul 11, 2019 at 6:18 AM
    #1411
    BMcLain3
    BMcLain3 New Member
  2. Jul 11, 2019 at 7:15 AM
    #1412
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Nice truck. Had the same wheels on my 15 I just traded in last weekend.
    You need the hyper tech speedo recalibrated to correct your speedo...if you are bothered by the difference. I ran it on mine. Then later got the Bully Dog from Keith for the performance part.
    Corr2626[QUOTED] likes this.
  3. Jul 11, 2019 at 9:23 AM
    #1413
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    We just got back from an epic road trip towing trailers through five states. Friends we were with towed their blue Micro Minnie and it did great. We rarely have hookups and their solar panel case keeps them going. Winnebago makes some cool stuff.
  4. Jul 11, 2019 at 4:04 PM
    #1414
    j2007
    j2007 New Member
    VA
    2017 DC Bronze Limited TRD
    Full Debadge, TRD Antisway, Platinum Grille, Baja Designs Squadron Sport Fogs, Morimoto MLED Headlight Retros, Tekonsha P3 Trailer Brake Controller with dash mount, Front Tint, Tyger Tonneau Cover, Anytime Fogs, FRAC, Fortin Evo One Remote Start, 12 Volt Bed Power Socket
    Newbie_19 likes this.
  5. Jul 11, 2019 at 4:21 PM
    #1415
    Corr2626
    Corr2626 New Member
    Corey
    2014 Tundra Limited
    That hypertech speedo seems pretty easy. Can you do more then one vehicle on that programmer or does each vehicle needs it's own? Thanks
  6. Jul 11, 2019 at 6:30 PM
    #1416
    Juanjoolio007
    Oregon
    1 vehicle. It gets left in. Plugs in-between the truck and the gauge cluster. There is a cable that you plug into it to make your adjustments. I had that cable left in after install in case any further adjustments were needed. This way you don't have to pull the dash apart again.
  7. Jul 12, 2019 at 8:59 PM
    #1417
    Donkeypunch
    Donkeypunch New Member
    Picked up and hauled 2 Pallets of sod earlier this week. St. Augustine Texas grass. Since its mainly clay, and freshly cut, I’m guessing 2000lbs-2500lbs per pallet.
  8. Jul 12, 2019 at 9:20 PM
    #1418
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
  9. Jul 12, 2019 at 10:17 PM
    #1419
    Tracy Perry
    Tracy Perry New Member
    Tracy
    East Texas
    2019 MGM TRD Off-Road 4x4
    Back in the camping game with a new trailer since the elm tree fell on our Winnebago 1790.
    Drove from Palestine to Sealy TX (3 hour trip 1 way) to pick up a trailer site unseen. Well not exactly site unseen as we had looked at one locally but he was more than what we wanted to pay for an already 1 year old trailer.
    Called the dealer up yesterday and put a grand deposit on it and took the rest today.
    On the way back stopped off to grab a bite to eat (remind me again to never eat at a Pizza Hut) and grabbed a photo as it sat in the old Pizza Hut location.
    It's a Winnebago Minnie 2401RG. 27'11" long and a lot of room when the slide is out.
    Next stop for it are trailer towing mirrors. Local dealership wants around $600 for the set and I only want OEM ones so looks like that's what I'll be paying.
    AS for the trailer, some of the specs
    Hitch Weight 650 lbs
    Dry/Unloaded Weight 5220 lbs
    Gross Vehicle Weight 7000 lbs
    And yes, even empty I could tell it was back there. We had to adjust the weight distribution hitch on the way home and it was not as near as sensitive to the cross winds (about 20mph) or the tractor trucks blasting by since I was in the outside lane tooling along at a sedate pace of 60mph.
    Last vehicle I did any 25+ foot trailers with was a 1996 Ford F250 PowerStroke - which I recently got rid of since I hardly ever drove it. Being used to something like the F250 PS and then comparing it to a 1/2 ton you can tell the difference. I would not want any bigger trailer than what we have now.
  10. Jul 13, 2019 at 7:35 AM
    #1420
    Donkeypunch
    Good info and feedback on travel trailers.
  11. Jul 13, 2019 at 8:18 AM
    #1421
    GreatBigAbyss
    GreatBigAbyss New Member
    2018 Tundra CrewMAX SR5 TRD Off-Road
    I like those Minnie Winnies. They're not a full 8' width, correct? They're more like a 7'-7.7' wide trailer?
    I'd like something similar to that when we eventually buy a bigger trailer. I would likely keep it around the 24'-26' floorplan length, with a bunkhouse in the rear.
  12. Jul 13, 2019 at 8:26 AM
    #1422
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    That’s a sweet looking boat!
    Bigboitundra likes this.
  13. Jul 13, 2019 at 8:46 AM
    #1423
    j2007
    j2007 New Member
    VA
    That’s pretty much what I have - Winnebago 2455BHS with bunks in the back. Works great for the kids. Mine is 8 feet wide.
    I 100% agree with @Tracy Perry, it tows fine with the Tundra, but I’m right at max payload on the Cat Scale and I wouldn’t want more trailer with this truck.
  14. Jul 13, 2019 at 8:55 AM
    #1424
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Hey thanks! It's only a 95 but I got a new motor for it and gave it a fresh wax so now I call it my "new" fishing boat.
    Watt maker and Y0TA PR0[QUOTED] like this.
  15. Jul 13, 2019 at 2:38 PM
    #1425
    Tracy Perry
    Tracy
    East Texas
    They keep changing the names. Ours says Minnie on the side. The 1790 we had Mini Drop used in its name.
    The 1790 was around 6.5' wide (actual box, wheel to wheel was around 7' and was one of those that literally was easy to forget about being back there. The one we just got is the standard 8' width. The Mini frames were C type and very light. The new one is a full rectangle frame and is much heavier than the 1790. The 1790 used a 2" ball and the Minnie requires a 2 5/16" ball certified for class 5.
    Forgot all about the mileage - 18.7 going down empty with truck only (well, the hitch also). We got 8.4mpg coming back with trailer unloaded and in S4.
    Watt maker likes this.
  16. Jul 13, 2019 at 2:40 PM
    #1426
    Volchek
    Volchek New Member
    18 Tundra DC XPS 5.7
    The Minnie Drop, the Micro Minnie, and the Micro Minnie 5th Wheel are 7' wide. The Minnie, the Minnie Plus, and the Minnie Plus 5th Wheel are 8' wide.
    The Minnie Drop is 7' wide at the outside of the wheels. I think the cabin is like 6' or so?
    I think my next one will be a Micro Minnie 5th Wheel. It would be at the upper end of the Tundra's towing capacity.
    I love my Tundra. I wish Toyota would amp up the towing power some how.
    I steadfastly refuse to buy a Chevy or a Dodge. Ford is a maybe, but I'm not that impressed with the F150. The engine and ride is OK (my wife got an F150 rental for almost 2 weeks while her car was in the body shop), but the interior is just not that comfortable to me. Love the seats in my Tundra, super comfy for me and the ergonomics really suit me and my wife.
    And don't get me started on the gas mileage when towing. Even with my light weight Micro Minnie, keeping under 70mph. my mileage is still under 10mpg. Wish Toyota would do something to improve that as well.
  17. Jul 13, 2019 at 3:58 PM
    #1427
    Midway
    Midway New Member
    Pull my Airstream Travel trailer with 4.88s, pulls like a train.
  18. Jul 14, 2019 at 8:21 PM
    #1428
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    First tow with the lift. The trailer actually pulled better this way. 10.6 MPG from San Antonio to New Orleans.
  19. Jul 14, 2019 at 8:49 PM
    #1429
    Snowboard Tundra
    Snowboard Tundra New Member
    Not that much really, but it does good for what I need it for...
    We cut down, limbed, bucked and pulled 13 trees off the mountain. Split a bunch on site and took some loads back to the house. Winter is coming (I typically go through 3 cord or so)
    Hammerhead, trailrnr, Midway and 3 others like this.
  20. Jul 14, 2019 at 8:57 PM
    #1430
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    I had a similar load with a hydraulic dump trailer with my 98 4runner. Lost all but 1st and 2nd gear. Good thing I've moved on to a tundra! Nice haul
  21. Jul 14, 2019 at 8:58 PM
    #1431
    Snowboard Tundra
    Thanks! Will prob do 2-3 more in the coming months.
  22. Jul 14, 2019 at 10:30 PM
    #1432
    CementGen3
    CementGen3 Gas station Attendant
    Will
    Western WA
    2018 Cement SR5 CM 4x4
    TRD Dual Exhaust TRD rear sway bar Method Wheels Vex 311
    18’ Hewescraft Sportsman
  23. Jul 14, 2019 at 11:41 PM
    #1433
    Just wondering what your idea of towing MPG on a gas powered V8 should be? 10, 11, 12, or more?
    jeremyd and HappyGilmore like this.
  24. Jul 15, 2019 at 7:00 AM
    #1434
    spicychickentundie
    spicychickentundie New Member
    Danny
    SOMD
    2014 Barcelona Red Tundra SR5 CM 4x4
    TRD RSB
    Just did a 40ish mile tow with a 23ft Stingray (boat) and I got 10.6 mpg. I thought double digits were good.
  25. Jul 16, 2019 at 3:41 PM
    #1435
    bdean38
    bdean38 New Member
    Here's a pic of my baby and Heidi the Hideout. 24' bunkhouse. Pulls up the mountains like a champ!
    plumber802, Hammerhead, ntg and 6 others like this.
  26. Jul 16, 2019 at 4:49 PM
    #1436
    Mnorris1206
    08 tundra
    Sweet set up! now get you some load helper bump stops. To keep the truck nice and level.
  27. Jul 16, 2019 at 6:11 PM
    #1437
    Sp33dNut
    Sp33dNut New Member
    2019 White Tundra DCOR
  28. Jul 20, 2019 at 1:33 PM
    #1438
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
  29. Jul 20, 2019 at 2:39 PM
    #1439
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    towed my camper from long island to hershey PA. must say NYC sucks balls otherwise not too terrible. let me ask how many rpms are you guys comfortable with?
    i hit 4000 a few times and really didnt like it.
    literally had a Amazon prime 18 wheeler truck 1 inch from my camper down a bouncing congested road in the bronx
    Watt maker and ColoradoTJ like this.
  30. Jul 20, 2019 at 2:51 PM
    #1440
    Mine was at 3000+ all the time and mostly was at 3800 rpm. This is a V8 gasoline motor. Gonna have to make it sing to make power and torque.
    Top two lines are with DT headers.
    As you can see, ~4000 rpm is the best bang for your buck in the towing RPM if you need the power.
