Ultimate OEM Toyota Parts Thread for 2nd gens (2007-21)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2017.
  1. Jul 12, 2019 at 7:49 AM
    #1951
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    I do not know if it is compatible with the TRD skid plate. I'd contact ARB on that one. Surely they've run into that before...
  2. Jul 12, 2019 at 9:58 AM
    #1952
    cart99
    cart99 New Member
    Russ
    2016 Tundra Platinum CrewMax
    Fab Four front bumper
    great thread!
    Roman[OP] likes this.
  3. Jul 12, 2019 at 10:56 AM
    #1953
    jpdxtundras
    jpdxtundras Novice Tundra Driver
    Happy Rock, OR
    2019 Silver Sky Metallic Tundra SR5 CrewMax TRD Offroad
    Line-X, Deck Rail System
    Hi, is PT278-34071 the right part-number for the OEM bed rails for a 2019 CrewMax?
    I have to say, Roman, this is a great service you provide. If I'm ever in your neck of the woods I'd love to buy you a beverage of your choice...
  4. Jul 12, 2019 at 11:47 AM
    #1954
    Roman
    Roman
    Franklin, TN
  5. Jul 14, 2019 at 9:30 PM
    #1955
    AxeHeadTradition
    AxeHeadTradition New Member
    2018 Tundra Crewmax
    Hi @Roman are the plastic ratchet fasteners sold separately for the TRD Pro Skid plate? Part Number? Thanks!
  6. Jul 14, 2019 at 11:33 PM
    #1956
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    @Roman im looking for the bolt which holds the rear seats into the floor in a 2012 double cab. its the center bracket if that matters. thanks in advance!
  7. Jul 15, 2019 at 7:43 AM
    #1957
    1794-BlackTundra
    1794-BlackTundra New Member
    Sergio
    2019 Black Tundra 1794 Edition CM
    Rhino Linings, Smittybilt 11500 Winch (Internal), BAKflip MX4, RotopaX, MaxTrax, ARB Simpson III tent, Old Man Emu suspension, TRD rims, Pioneer Platform with Rhino-Rack Backbone System
    Woah!!! :eek2: you have an awesome set up there @Migraine :hattip: I already sent an email to ARB to be extra sure of the compatibility. Grill was swapped already, winch it's there but I might upgrade to something more robust prior to Summit bumper installation. OME suspension to be installed this Friday in preparation to the new bumper setup. I wonder it the OEM fog lights can be repositioned into the ARB bumper... if not, I'll get a decent ones beforehand and do the whole thing :spending: Oh yes... I've been doing research quite a while and lots of things are backordered from AU!
    Thanks for the heads up!
  8. Jul 15, 2019 at 8:25 AM
    #1958
    Roman
    Roman
    Franklin, TN
    Unfortunately, no. Not by themselves. They are included in the hardware kit for the skid plate.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-hardware-kit-skid-pl-pt93834140hw
    Should be these:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-seat-adjust-assembly-bolt-90119a0112
    TRD-tv[QUOTED] likes this.
  9. Jul 15, 2019 at 8:46 AM
    #1959
    AxeHeadTradition
    2018 Tundra Crewmax
    Roman[QUOTED][OP] likes this.
  10. Jul 15, 2019 at 6:42 PM
    #1960
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
  11. Jul 16, 2019 at 7:54 AM
    #1961
    Roman
    Roman
    Franklin, TN
    Here's a couple of diagram of the rear seat in a double cab. You can see the part number associated with the bolt I referenced. Same bolt holds the Crewmax seats to the floor as well.
  12. Jul 17, 2019 at 1:49 PM
    #1962
    JamesTkirk
    JamesTkirk New Member
    Moab UT
    2018 SR 4WD 4.6L
    did a search on this thread but couldn't find this...actually searched the whole forum. Just don't know why my search skills suck so bad!
    B Pillar Decals!!
    Don't have 'em, want 'em!
    -Kirk Out
  13. Jul 18, 2019 at 7:34 AM
    #1963
    Roman
    Roman
    Franklin, TN
    The black out tape on the doors? If so, what size cab do you have?
  14. Jul 18, 2019 at 7:39 AM
    #1964
    JamesTkirk
    Moab UT
    2018 SR 4WD 4.6L
    Yep the black decals in between doors.
    I've got a double cab, SR that came without them.
    I've been on your website scouring part schematics to no avail...Thanks!
  15. Jul 18, 2019 at 7:41 AM
    #1965
    Roman
    Roman
    Franklin, TN
  16. Jul 18, 2019 at 7:51 AM
    #1966
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    ^^^^^ He lives this STUFF!! He knows this in his sleep!! He probably just checked the computer to make sure the computer was correct!!:)
  17. Jul 18, 2019 at 7:56 AM
    #1967
    Roman
    Roman
    Franklin, TN
    Computer.... What computer?
    :D
  18. Jul 18, 2019 at 8:30 AM
    #1968
    JamesTkirk
    Moab UT
    2018 SR 4WD 4.6L
    Copy. So, the four links are for: front and rear door diver's side. Front and rear door passenger side.
    $95 plus shipping for the set.
  19. Jul 18, 2019 at 8:58 AM
    #1969
    Roman
    Roman
    Franklin, TN
    Correct.
  20. Jul 21, 2019 at 7:26 PM
    #1970
    Milamber
    Milamber New Member
    Roman, you the man. Perfect timing. I had been dithering over putting the black pillar treatment on my SR. Placed my order thank you
  21. Jul 22, 2019 at 10:00 PM
    #1971
    agkleino
    agkleino New Member
    Aaron
    Arizona
    2014 Tundra Platinum
    @Roman I haven't seen any posts about a 19 Pro grille on a 14. Also, don't see Barcelona Red as an option. What would I need to make this happen?
  22. Jul 23, 2019 at 6:54 AM
    #1972
    Roman
    Roman
    Franklin, TN
    All 2014+ grilles are physically interchangeable. The new Pro grille is no different. You'll still need all of the parts associated with it listed under the 2019 Pro grille section in the OP. The new Pro models are not available in Barcelona red, so I would recommend getting a black Pro grille, and have the surround on it painted by a local body shop.
  23. Jul 24, 2019 at 1:39 PM
    #1973
    agkleino
    agkleino New Member
    Aaron
    Arizona
    @Roman The page says FORUM20 code is expired.
  24. Jul 24, 2019 at 2:21 PM
    #1974
    Black@Blue19
    Ken
    SE Texas
    I think he means page one of this, it has the pro grill on there and it’s working, it worked for me?
  25. Jul 24, 2019 at 9:20 PM
    #1975
    agkleino
    agkleino New Member
    Aaron
    Arizona
  26. Jul 24, 2019 at 9:26 PM
    #1976
    americanaaron
    americanaaron USA
    North Carolina
    2019 Tundra
    You are on sparks not cool springs Toyota, where the forum20 code applies
    Watt maker likes this.
  27. Jul 25, 2019 at 12:32 AM
    #1977
    Black@Blue19
    Ken
    SE Texas
    ^^^^* what he said, but I bet you done figured it out. Have a good day.
  28. Jul 25, 2019 at 6:13 AM
    #1978
    agkleino
    agkleino New Member
    Aaron
    Arizona
    Oh shit! This whole time I thought the OP was for Sparks. Lol. I never paid attention. Doh!
  29. Jul 25, 2019 at 12:03 PM
    #1979
    mgates32
    mgates32 New Member
    Mitch
    2018 Toyota Tundra
    Looking through many pictures around these forums, I've noticed not many, if any people color match their door handles. Any reason people don't do this relatively cheap mod to their trucks? Are the matte black plastic handles just considered better?
  30. Jul 25, 2019 at 12:17 PM
    #1980
    Roman
    Roman
    Franklin, TN
    I sell painted door handles all the time. I guess it all depends on personal preference and cost. Cost can factor in if the door handles are not available in a certain color, like Barcelona Red, for example. Then, you would have to factor in the cost to have them painted along with the cost of the parts, and some people may not want to do the swap for what that would cost.
