Chrome swap out 2019
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cpa757va, Jul 8, 2019.
  1. Jul 8, 2019 at 2:44 PM
    Cpa757va
    Cpa757va [OP] New Member
    Chad
    Hampton roads VA
    2019 Tundra limited TRD off road
    See build thread below.
    E02DF14C-158E-48EA-A7E2-C39084B97D94.jpg Decided to swap out the chrome handles, mirror caps, and chrome grill on my 2019 Limited to a TRD PRO grille and color matched handles and caps. Super easy to install and all of it took less than 90 minutes. Let me know what ya think or if you have any questions!
  2. Jul 8, 2019 at 2:51 PM
    TorinWallace
    TorinWallace Yota Addict
    2020 TRD Pro, DoubleCab, Army Green.
    CB Shim + Shackles | 305/70r18 KO2's | 18" Method NV's | Firestone Airbags | Tow Mirrors | Marlon Sleddeck | Spyder smoked taillights.
    Looks super clean man! I'm a big fan of color matched look.
    Time to get yourself some black bumper caps and debadge/ or switch to black badges to complete the transformation :smokertransformer:
    jewsNbrews likes this.
  3. Jul 8, 2019 at 3:11 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 GMC Sierra At4x AEV
    Looks great! I just got all my parts in to do the same on my black too. How did you get the mirror caps off?
  4. Jul 8, 2019 at 3:12 PM
    Shanesyota
    Shanesyota Midnight
    Shane
    Ohio
    2019 Black Tundra Platinum
    Weather tech Floor mats Weather tech bedliner and tailgate liner Black TRD shift knob Tonneau cover Match front window tint
    Look up Tundradude34 on YouTube he tells how to
    Do it
    TundraLaw[QUOTED] likes this.
  5. Jul 8, 2019 at 3:13 PM
    TLBranch
    TLBranch New Member
    NB, Canada
    2019 Red extened cab 8ft box
    Chrome delete Tow mirrors Emblem black out Driver side A-pillar grab handle LIneX spray in liner, color matched Fuel Tactic 18" wheels Toyo AT2 275/70R18 tires
    Nice work :thumbsup:, I did something similar but did the bumpers too
  6. Jul 8, 2019 at 3:28 PM
    Cpa757va
    Chad
    Hampton roads VA
    I folded the mirrors in and started at the bottom corner closest to truck with a small pry tool (i used a flathead carefully). Super easy.
    jewsNbrews and Black Wolf like this.
  7. Jul 8, 2019 at 3:29 PM
    Cpa757va
    Chad
    Hampton roads VA
    Love it!! I plan on doing bumper ends next.
  8. Jul 8, 2019 at 5:49 PM
    javy55
    javy55 New Member
    Javier
    I'm looking to swap out all the chrome on my truck. Any pointers on where to get the color matching parts?
  9. Jul 8, 2019 at 6:05 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Anything non-obvious about relocating the sonar sensor to the new location? I'm waiting on the garnish to show up, then my grille is getting swapped out.
  10. Jul 8, 2019 at 6:08 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    check out "Sparks Parts" out of Myrtle Beach, SC. Lots of color matching parts available. Also look around for the forum discount.
  11. Jul 8, 2019 at 6:12 PM
    Looks great!
    @Roman Our forum parts guy
    jewsNbrews and Roman like this.
  12. Jul 8, 2019 at 6:13 PM
    javy55
    javy55 New Member
    Javier
    Cool thanks
  13. Jul 8, 2019 at 6:19 PM
    Cpa757va
    Chad
    Hampton roads VA
    https://www.tundras.com/threads/ultimate-oem-toyota-parts-thread.10707/
    This thread was a life saver and made it so easy to figure out exactly what you need. Fast shipping as well.
    Also sparkparts is another good site, as mentioned above, good luck.
  14. Jul 8, 2019 at 6:21 PM
  15. Jul 9, 2019 at 7:06 AM
  16. Jul 11, 2019 at 4:34 PM
    Xtaco16
    Xtaco16 New Member
    2018 Tundra TRD sport
    Looks good!
  17. Jul 11, 2019 at 4:52 PM
    Cpa757va
    Chad
    Hampton roads VA
    How easy is it to switch badges to black? I’ll probably just remove the tundra emblems on the doors but would prefer to keep the engine and limited emblems but just switch to black.
  18. Jul 11, 2019 at 4:57 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Many options...as others have said, can order from @Roman for help. Check out the previous post thread on how to choose what color matched grill you want.
    Another option is wrapping in vinyl if you are good with wraps.
    Some places will paint the chrome to color match and other shops will say you cant.
    Lots of options on getting everything color matched, just depends what best for you.
    Roman likes this.
  19. Jul 11, 2019 at 9:45 PM
    TorinWallace
    It's pretty easy really, I did it on my tacoma a few years ago by using painters tape to mask off the exact position of the badge vertically and horizontally, then used a hair dryer to heat them up ( a hot day works just as well) and use some fishing line to get between the badge to pull it off if needed. Lastly pull off the existing adhesive and lay your new black badges smack in the middle of your masked off box.
    Alternatively you could have an auto shop pull them and paint the existing ones and stick them back on (pricier route).
    And lastly to remove those tundra ones follow the same steps as I listed before (beside the tape masking) and use some goo gone to get the adhesive residue off. Then finish off with a little wax and your set!
    This tool 3M makes for a drill to remove adhesive makes taking off the adhesive a hell of a lot easier: https://www.amazon.com/3M-03612-Adhesive-Eraser-Wheel/dp/B005RNGN8I
  20. Jul 11, 2019 at 9:53 PM
    TorinWallace
    1 more even easier option for the limited is this overlay kit, no removal just goes over the badge: https://www.ebay.com/p/Toyota-4runn...em-Overlay/28022450038?iid=254262187993&rt=nc
    And here is a link to a pair of black iforce badges: https://www.amazon.com/IFORCE-Emblem-Nameplate-Sticker-Tundra/dp/B07PZ1TVF2
  21. Jul 11, 2019 at 11:06 PM
    TundraLaw
    Northern Nevada
    Big fan of the Toyota overlays!
  22. Jul 12, 2019 at 3:28 AM
    Cpa757va
    Chad
    Hampton roads VA
    So these just go over current emblems? No removing necessary?
  23. Jul 12, 2019 at 3:29 AM
    Cpa757va
    Chad
    Hampton roads VA
    T
    Thank you!
  24. Jul 12, 2019 at 4:50 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Let us know when you decide to dump your existing grill and surround. Some of us like the chromed, modern grill.
    javy55[QUOTED] and jewsNbrews like this.
  25. Jul 12, 2019 at 6:42 AM
    TLBranch
    TLBranch New Member
    NB, Canada
  26. Jul 12, 2019 at 9:18 AM
    TundraLaw
    Northern Nevada
    yup. they go on in about 20 seconds. Makes a lot more sense for me, as I don't really believe in messing with things that are glued on. They look legit, and black out the emblems with no hassle.
  27. Jul 12, 2019 at 6:18 PM
    Cpa757va
    Chad
    Hampton roads VA
    Where did you buy your engine size emblem overlays from? I’m trying to find just the engine ones without having to buy a whole set since the set doesn’t include the “limited” overlay.
  28. Jul 13, 2019 at 10:47 AM
    TundraLaw
    Northern Nevada
    Sparks par
    Sparks parts has an entire kit including the limited badges!
