6112's at 2.5 setting with cb shim
Discussion in 'Suspension' started by Glennjc1978, Jul 7, 2019.
  1. Jul 7, 2019 at 10:38 AM
    Glennjc1978
    Glennjc1978 [OP] New Member
    Glenn
    2021 trd pro lunar rock
    New to forum,just have a question. Installed 6112's at the 1.9 setting with cb shim and loved the ride. I wanted a little more lift so i moved them up to top setting 2.5 and installed SPC uca.Now the ride is terrible. When i hit bumps on the highway it feels like i hit a speed bump.Even rattles the dash.Just wondering if maybe something was installed wrong or just the preload on the coilovers.It is a night and day difference between the 2 settings. The truck is 100% on road truck.Any suggestions would be helpful.
  2. Jul 8, 2019 at 10:50 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Install yourself or have a shop do it? Any pics?
  3. Jul 8, 2019 at 12:03 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Shouldn’t be that drastic. Pics of front shocks as of now? Did you get it realigned?
  4. Jul 8, 2019 at 12:53 PM
    Midmo_tundra
    Midmo_tundra New Member
    Missouri
    My 6112s have been at max height with shims for 3+ years 38k miles, and mine ride awesome. I'd post a picture of the coilover assembly maybe something was installed incorrectly or something was torqued before the truck was on the ground bearing full weight.
  5. Jul 8, 2019 at 1:40 PM
    EAK
    EAK New Member
    KY
    ‘15 White 1794
    BAMuffler 8” SS Bilstein 6112/5160 Icon UCAs
    I'm following this thread. I'll be doing a similar setup. While I'm definitely going for the aggressive look (height), I don't want to sacrifice ride quality.
    I really like the stance of your truck in the photo @Glennjc1978
  6. Jul 8, 2019 at 1:59 PM
    Glennjc1978
    Glenn
    I had a shop install them20190708_144843.jpg 20190708_144853.jpg 20190708_144843.jpg 20190708_165817.jpg
  7. Jul 8, 2019 at 2:07 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You hit it. Too much preload. And the ride gets stiffer as the angle of the arms increases
  8. Jul 8, 2019 at 2:45 PM
    Danman34
    Danman34 New Member
    Danny
    I think your bump stops are way to big. You don’t need that much extension with the 6112s, albeit with less than 3” of lift. You only need to extend them a 1/4” or so. I bet your smacking the bump stops with every bump. Take those middle pieces off and see if it changes the ride.
    1_thirsty_tundra and mojojo like this.
  9. Jul 8, 2019 at 2:58 PM
    Glennjc1978
    Glenn
    I will definitely try and see if it makes a difference.
  10. Jul 8, 2019 at 3:08 PM
    Danman34
    Danman34 New Member
    Danny
    Everything else looks fine, so there’s no reason the ride should change that significantly only going up another half inch. These shocks and springs are designed for the increased travel and preload so you don’t need that much extension to the bump stop. Let those shocks work.
    And what does your alignment specs look like?
  11. Jul 8, 2019 at 6:12 PM
    Glennjc1978
    Glenn
  12. Jul 8, 2019 at 7:18 PM
    Danman34
    Danman34 New Member
    Danny
    Alignments jacked up. Shouldn’t have negative camber. Your caster is all wrong. Toe should at least be equal on each side, albeit you have too much total toe. Whoever did this had little to no clue what they were doing.
    Your sheet on a lifted tundra should look like this:
    Camber: L 0.0 - 0.2 R 0.0 - 0.2
    Caster: L 2.0 - 2.3 R 2.3 - 2.7. Always want a few tenths more on the right to account for road crown.
    Toe: L 0.5 - 0.7 R 0.5 - 0.7. This can vary a tenth or so but total toe should be around 0.15.
    mojojo likes this.
  13. Jul 8, 2019 at 8:17 PM
    wigburner
    wigburner New Member
    09 double cab 5.7
    i feel like the top setting is harsh too.
    but want the lift.
    not sure what to do and i do take it off road.
    wish i threw down for a better front coilover.
    wondering if i should lower the setting and put a shim in?
  14. Jul 8, 2019 at 8:23 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    It will ride better but dont forget to shim the bumpstop a little if you add the shim in.
  15. Jul 8, 2019 at 8:50 PM
    equin
    Ed
    DFW, TX
    Yeah, the first thing I noticed was how big the bump stop extension is. The ones Bilstein provides look like thick washers and are much thinner. But the alignment numbers look way off. I'm guessing if you swap out those big bump stop extenders for the ones Bilstein provided and get the alignment fixed, the ride should drastically improve.
