At my wits end fellas, need some help
Discussion in '2nd Gen Tundras (2007-2013)' started by Shogo0320, Jul 8, 2019.
  1. Jul 8, 2019 at 7:03 PM
    Shogo0320
    Shogo0320 [OP] New Member
    Shawn
    Love my Tundra
    I have a 08 with 203k on it. A few months ago my check engine light came on, 4LO/4HI blinking with VSC blinking as well and my truck went into Limp mode, it gets up to about 40 mph and thats it. I have had it to 4 shops and all they do is clear the CPU and charge me 100$. Advance and Oreily wont clear codes anymore as its now against corp. Im stuck and need some help. Any ideas?
  2. Jul 8, 2019 at 7:20 PM
    TRDZ28
    TRDZ28 New Member
    Southern California
    2014 Tundra TRD 4X4 BRM
    What are the codes that they're clearing? Clearing codes doesn't fix the problem.
  3. Jul 8, 2019 at 7:22 PM
    AZTundra
    Paul
    Phoenix, AZ
    Which codes? They will be key in being able to help with the diagnosis.
    MotoTundra likes this.
  4. Jul 8, 2019 at 7:24 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    What those guys said^
    The truck is telling you what is wrong, you just need to listen.
  5. Jul 8, 2019 at 7:25 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    as far as clearing the codes, you can take the battery cable off for a couple minutes or buy your own OBDII scanner. Better fix the root cause as more damage may be occurring. :spending:
  6. Jul 8, 2019 at 7:26 PM
    Shogo0320
    Shawn
    Love my Tundra
    C1201 and P2442 are the consistent codes i get, also pulling the battery cable did temp fix the issue for a minute but now its not working
  7. Jul 8, 2019 at 7:28 PM
    AZTundra
    Paul
    Phoenix, AZ
    Sounds like the AIP's are going to be the culprit. What year and mileage are you at?
    Edit: I'm dumb and didn't read that you already provided the year and mileage...:der:
    CaptSpaulding likes this.
  8. Jul 8, 2019 at 7:47 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    equin and AZTundra like this.
  9. Jul 8, 2019 at 7:49 PM
    AZTundra
    Paul
    Phoenix, AZ
    MotoTundra and ShreveportTSS like this.
  10. Jul 8, 2019 at 7:54 PM
    schmitty
    schmitty New Member
    Air pumps
    koditten likes this.
  11. Jul 9, 2019 at 12:36 PM
    Brijab
    Brijab New Member
    07 crewmax limited
    I had this exact problem on my 07 crewmax limited with 88000 miles two summers ago. My tire shop who also does some mechanical jobs found that a small skid plate just aft of the muffler was gone and the heat from the muffler was causing a wire harness to malfunction. He replaced the harness and fabricated a small shield for just under four hundred bucks and the problem has not come back. I would love to tell you what the wiring harness was but the paperwork is in a storage unit 600 miles away. He said that it would be a harness that comes on the main wiring attached to the frame.
    equin likes this.
  12. Jul 9, 2019 at 4:10 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    Unfortunately it's probably an AIP problem, here's a thread devoted to this subject. Please read the entire thread is there are good suggestions on how to fix this issue. I made a couple of posts on the subject too.
    https://www.tundras.com/threads/disappointed-tundra-new-owner.46814/page-2#post-1279495
  13. Jul 9, 2019 at 5:27 PM
    koditten
    Kirk
    Midland of the Mitten
    Air pump failure. Failed pump or pumps cause you to go into limp mode.
