Brake system FIASCO
Discussion in 'General Tundra Discussion' started by Johnstoytruck, Jul 8, 2019.
  1. Jul 8, 2019 at 8:26 AM
    Johnstoytruck
    Johnstoytruck [OP] New Member
    2005 tundra double cab 4.7 v8 XSP
    I HAD MY BRAKE SYSTEM PURGED WITH NEW FLUID (DOT3) AT A NEIGHBORHOOD REPAIR SHOP. MY BRAKES WERE FINE WHEN I DROVE IN...AFTER THE PURGE THE BRAKES WERE ALMOST NON EXISTANT...THE SHOP INDICATED THAT I HAD A BAD MASTER CYLINDER. APPARENTLY DAMAGE TO THE MC OCCURED DURING THE PURGE THROUGH NO FALUT OF THE SHOP??? IT COST $400.00 TO GET MY TRUCK MC REPLACED!
    HAS ANYONE ELSE RUN INTO THIS PROBLEM?
  2. Jul 8, 2019 at 3:09 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Sounds like major BS to me.
    Black Wolf and TheBeast like this.
  3. Jul 8, 2019 at 3:55 PM
  4. Jul 8, 2019 at 4:00 PM
    timsp8
    NY
    I’ve heard of a master cylinder going out after a brake bleed. Either they forced new fluid through and damaged a seal or the clean fluid worked something loose.
    They probably let it get too low as they pumped it through and damaged the seals.
    equin and Black Wolf like this.
  5. Jul 8, 2019 at 4:01 PM
    Professional Hand Model
    Fred
    Hand Protectors
    DID YOU YELL AT THEM TOO?
  6. Jul 8, 2019 at 4:02 PM
    I WOULD HAVE!
  7. Jul 8, 2019 at 4:06 PM
    Fred
    Hand Protectors
    I CANT HEAR YOU!
    Seriously, I been seeing many 05-06 Tundra guys complaining about failed cylinders here. Likewise, many ABS problems with people losing their Marbles over it.
    Sounds like the OP’s cylinder was on the edge and the new fluid knocked it over.
    $400 sounds like a good deal for replacement.
    equin and Black Wolf[QUOTED] like this.
