2016 Transfer Case Issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by The Snarkist, Jul 5, 2019.
  1. Jul 5, 2019 at 7:26 PM
    The Snarkist
    The Snarkist [OP] New Member
    Calling all Yota Yodas. My 16 will go into 4H but will not go into 4L. After it goes into 4H it won’t disengage. I have to pull over and turn off the vehicle then restart. Once it cranks it’s out of 4H. Thoughts? Ideas?
  2. Jul 5, 2019 at 7:34 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Are you following the manual procedure for getting into 4Lo??
  3. Jul 5, 2019 at 8:11 PM
    The Snarkist
    Yes. Complete stop, neutral. It just flashes and never engages.
  4. Jul 5, 2019 at 8:12 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Actuator issue I bet
  5. Jul 5, 2019 at 9:07 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    When was the last time you did your transfer case oil maintenance?
