What are good/bad years for Tundras
Discussion in '2.5 Gen Tundras (2014-2021)' started by MWD, Jul 5, 2019.
  1. Jul 5, 2019 at 1:54 PM
    MWD
    MWD [OP] New Member
    Pagosa Springs, CO
    2017 TRD Off Road Double Cab
    Camper frame mounted tie downs, Firestone air bags, E rated tires
    Very first post! We plan to buy a used Tundra to haul a popup camper - 4 Wheel Camper or Hallmark Milner 6.5 foot bed length - (not a popup trailer type camper.)
    Are there year models to avoid? Year models that are known to be good. Can be 2nd or 3rd Gen, 5.7L, double cab, 4WD. THANKS in advance for your input.
  2. Jul 5, 2019 at 2:19 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    2017 is the best year! Last one before TSS was implemented.
  3. Jul 5, 2019 at 2:47 PM
    Ostrich
    Ostrich One bit me once.
    Nikki
    Marion, Texas
    2014 MGM Crewmax SR5 4x4
    3/1 level, black leather, raptor style grille
    There is no bad year.. They're all good. I personally love 3rd gens, but some people on here have some sweet 2nd gens.
    15whtrd likes this.
  4. Jul 5, 2019 at 2:48 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    I'd recommend 09+ purely because the early 2nd gens like my 08 had really twitchy throttles
  5. Jul 10, 2019 at 2:08 PM
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    If you plan to haul a camper, I'd recommend a '16 or newer with the SR5 Upgrade package (38-gal fuel tank) :thumbsup: Otherwise, you might be stopping every 200 miles for gas.
  6. Jul 10, 2019 at 2:13 PM
    Professional Hand Model
    Fred
    Hand Protectors
    If you want good looks, perfect size, and dependability with a higher payload... then a 1st Gen is the call.
    If you want to tow the Space Shuttle, then the later models suit your bill.
    nvrgvup444 likes this.
  7. Jul 10, 2019 at 2:17 PM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    If I've been reading correctly, seems like 07-09 had frame rusting issues. I'd go with 2010-2017. All-in-all though, these trucks are awesome.
  8. Jul 10, 2019 at 2:26 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    ‘08-‘09s run like scalded dogs.
    Mnorris1206 likes this.
  9. Jul 10, 2019 at 2:50 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    You might be better off worrying about color choice. As most people will say, "all years are good, but Blue Ribbon Metallic is the best color." Stay away from MGM, Black and White. :rofl:
  10. Jul 10, 2019 at 2:58 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Fixed
    WFD473 and nvrgvup444[QUOTED] like this.
  11. Jul 10, 2019 at 4:08 PM
    Nick T
    Nick T New Member
    Avoid them all. A fully loaded pop up camper is going to overload a Tundra. If you really want a camper you can haul, get something that has the payload rating you need.
    Why not get a trailer? Much easier to stay under the payload rating of a Tundra with a trailer and all the gear / food / water you bring with you.
    They can tow, just can't haul all that much..get a 3/4 ton if you want to haul
  12. Jul 10, 2019 at 5:50 PM
    Mnorris1206
    08 tundra
    My 08 lift with 35s will burn the tires off lol I have even chipped the tires starting out pulling my 30' camper lol I really dont know what it is about the 07-09 tundras but they will move.
  13. Jul 10, 2019 at 5:56 PM
    Woodguy65
    Woodguy65 New Member
  14. Jul 10, 2019 at 5:58 PM
    Woodguy65
    If your looking for actual data go to the above site (Carcomplaints.com) - you can compare years with owner complaints etc. Otherwise your just going to get everyone stating their year is the best year, and yes 2015 is one of the best
  15. Jul 10, 2019 at 6:02 PM
    Mnorris1206
    08 tundra
    I would add one more thing just look around do your research on the vehicle you choose used if your going that direction because you definitely dont want other people's problems. my biggest issue I have with my truck is the bed rust. For an 08 will it have some rust yes but I didnt expect it at all with only 80k mile when I found it. So a truck bed camper make sure your buying a good solid truck. No drop in bed liner if it does tell them you want it removed for inspection.
  16. Jul 10, 2019 at 6:10 PM
    Blueknights75
    Ron
    Clayton, NC
    Couldn’t agree more!
    Sas[QUOTED] likes this.
  17. Jul 10, 2019 at 6:20 PM
    Mnorris1206
    08 tundra
    My 08 is definitely fast it must be the color.
