Coachbuilder Shims
Discussion in 'Suspension' started by BracedTRDSport, Jul 3, 2019.
  1. Jul 3, 2019 at 12:38 PM
    BracedTRDSport
    BracedTRDSport [OP] New Member
    Daniel
    2019 Tundra Sport 5.7 Dubl
    I've got a set of 5100's going in tmr at the top setting. I have bought three coachbuilder shims for above the struts, 2 on driver and one on passenger. Got 295/70r18's for it, wondering if I truly need 2 on one side or just put one on each, I dont want it to sit high on the driver side, its 2019 and theres no drag that I can see sitting stock.
    Thanks in advance
  2. Jul 3, 2019 at 1:04 PM
    AZTundra
    Paul
    Phoenix, AZ
  3. Jul 3, 2019 at 1:11 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    I think the “Tundra lean” only occurs once the coil springs are replaced ??
    If u are replacing shock only (5100)
    U should not develop lean?
    I’m sure someone with more knowledge then me will chime in and agree or CORRECT me!
    Good luck
    BracedTRDSport[OP] likes this.
  4. Jul 3, 2019 at 1:36 PM
    BracedTRDSport
    Daniel
    Thanks dude, I'll put one on each and if it develops lean I'll add the second, Cheers
