2004 Toyota Tundra Timing Belt
Discussion in '1st Gen Tundras (2000-2006)' started by JMHA1997, Jul 3, 2019.
  1. Jul 3, 2019 at 6:01 AM
    JMHA1997
    JMHA1997 [OP] New Member
    2004 Toyota Tundra 2WD Limited 4.7L
    3" Leveling Kit
    I have a 2004 Toyota Tundra about to break 60,000 miles. I have read in the service manual that the timing belt should be replaced at 60,000 miles, but I see some people don't replace it until over 100,000 miles in. I have no clue if it has been replaced before, but I doubt it has been. Should I think about replacing it now? I am about to replace spark plugs and flush the coolant system.
  2. Jul 3, 2019 at 6:03 AM
    andrew8404
    andrew8404 New Member
    Andrew
    90000 for timing belt change or 6 years I believe. I’d get it changed due to it being 15 years old. Coolant will be changed anyways when doing a timing belt. Also do the water pump and thermostat since it will be easy to change once your in there.
    speedtre likes this.
  3. Jul 3, 2019 at 6:16 AM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    I changed mine at 240k. It looked in good condition.
    Doutakcash67 likes this.
  4. Jul 3, 2019 at 6:21 AM
    JMHA1997
    3" Leveling Kit
    I may go ahead and change it out then just to be on the safe side!
    619Tundra likes this.
  5. Jul 3, 2019 at 6:29 AM
    619Tundra
    You may want to look at changing the water pump while you're at it. It will be an easy repair since you're taking it apart.
  6. Jul 3, 2019 at 6:30 AM
    619Tundra
    I believe this is why I changed the timing belt. Because the water pump failed.
  7. Jul 3, 2019 at 6:38 AM
    This questions pops up a lot(age vs miles). I believe Toyota recommends every 9 years, not 6 as stated above. If you do a search here you'll find mention of the Aisin kit that is sold on Amazon. That's what everyone recommends.
    JMHA1997[QUOTED][OP] likes this.
  8. Jul 3, 2019 at 7:39 AM
    speedtre
    speedtre New Member
    Inland Northwest
    If anyone wants to find the maintenance schedule (or owners manual) for your particular truck, you can go to this link....change the year at the end to your year truck.
    https://www.toyota.com/owners/resources/owners-manuals/tundra/2000
  9. Jul 3, 2019 at 8:22 AM
    JMHA1997
    3" Leveling Kit
    speedtre[QUOTED] likes this.
