Foldable Tonneau cover systems compatible with ladder rack system
Discussion in 'Tonneau Covers, Caps and Shells' started by doggiecareman, Sep 30, 2018.
  1. Sep 30, 2018 at 2:50 PM
    doggiecareman
    doggiecareman [OP] YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    I have a 2019 TRD Pro that I am busy adding all the bling and utilitarian accoutrements to. I am going to with a foldable aluminum constructed toneau most likely with the Rhino texture similar to the bed liner. i have researched and currently there are 2 systems I am aware that are geometrically shaped to allow the tonneau cover to fold up and stay in place behind the cab window. One is not all blacked out which I would prefer but it looks nice and the other looks like a rudimentary build from an erector set but is all blacked out. I will be using this for canoe, kayak, lumber and ladder hauling. Any suggestions are greatly appreciated.
  2. Jun 3, 2019 at 10:35 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    What did you end up with? Thoughts? I have basically the same requirements.
  3. Jun 30, 2019 at 6:54 PM
    red arrow
    red arrow New Member
    2021 Gray Metalic Limited Off Road Tundra Crew
