Question after installing Kenwood DDX9905s - second amp??
Discussion in 'Audio & Video' started by BigRedFireEngine, Jun 27, 2019.
  1. Jun 27, 2019 at 8:00 PM
    BigRedFireEngine
    BigRedFireEngine [OP] New Member
    Toronto, Canada
    2016 Crewmax 1794 Edition in.... red.
    Extang Solid Fold 2.0 Trifold Tonneau, Go Rhino RB10 running boards, Kenwood DDX9905s
    As this is my first post, I would first like to thank everyone on this forum for all the great information as I deck out my new-to-me '16 Crewmax 1794 Edition.
    I have already installed a Kenwood DDX9905s head unit with iDatalink Maestro to retain factory controls. I love it. It's flat out awesome - night and day sound.
    Here's today's dilemma...
    iDatalink's matching harness (TO2) uses the front RCA outs on the head unit to send an audio signal to the (crap-tastic) stock JBL amp.
    But is there anything stopping me from running a separate set of RCAs off the "subwoofer" RCA output on the head unit to a second amp that will push a new subwoofer?
    I'm thinking it should not cut any sound to the stock amp, AND still allow for subwoofer control from the head unit - correct??
    Thank you very much for your help. Excited to be part of the forum!
  2. Jun 27, 2019 at 8:02 PM
    Welcome from NY.
  3. Jun 27, 2019 at 8:05 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Welcome from AZ!
    And no, there is nothing that should stop you from using the sub preamp outputs for a dedicated sub channel.
  4. Jun 27, 2019 at 8:20 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I don't have the jbl, but if you already pulled the head unit, why don't you get a 5ch amp and ditch the POS JBL amp?
    TheBeast likes this.
  5. Jun 27, 2019 at 8:25 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    If you're going to buy an amp for a new sub. You should just get a 5 channel amp and power all your speakers with it. You have the head unit and maestro so you're only missing the amp, which sounds like you already want to get. Do it right and toss the JBL amp all together and replace it with something to power all the speakers and new sub. That's exactly what I did and don't regret it one bit
    Trooper2 likes this.
  6. Jun 27, 2019 at 9:02 PM
    BigRedFireEngine
    Toronto, Canada
    This is exactly what I’d like to do!
    But I was worried that the stock JBL amplifier is needed for other audio functions in the truck.
    Also, the harness for the maestro unit is tied into the stock wiring to that amp. What happens to those connections?
    Are you guys saying stock JBL amp can be ripped out without any negative results?
    Thanks again.
  7. Jun 27, 2019 at 9:45 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    You don’t need the stock amp, just get a wiring harness from taco tunes or @james@tech12volts that will connect directly to the plugs that connect to the factory amp and that will power your speakers via the factory wiring from the aftermarket amp. You will just need to run a good power wire from the battery and ground it properly somewhere under the seat or wherever you will place the amp(s).
  8. Jun 27, 2019 at 10:03 PM
    Pudge
    CT
    You'll need a couple wire adapter connectors !×to connect the speakers to the amp. You're almost there with the head unit and maestro, just need the amp ana couple wire harnesses. Email James at tech12volts and he can get you set up right.
  9. Jun 28, 2019 at 1:33 PM
    BigRedFireEngine
    Toronto, Canada
    Thanks for all the replies guys. So, just to be clear, the rear traffic alert sounds and door chimes would remain after ripping out the JBL amp?
  10. Jun 28, 2019 at 1:46 PM
    Pudge
    CT
    I didn't lose ant of my warning signals when I ripped out my JBL
  11. Jun 28, 2019 at 3:51 PM
    BigRedFireEngine
    Toronto, Canada
    That’s exactly what I needed to know!! Thank you. May I ask which harness (if any) you used to attach to the factory connectors?
    Pudge[QUOTED] likes this.
  12. Jun 28, 2019 at 5:50 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    Here is the one from Taco Tunes but you can get them other places including from @james@tech12volts as well.
  13. Jun 28, 2019 at 5:55 PM
    Pudge
    CT
    James at tech12volts makes the harnesses you need for down at the JBL amp. They are about $30 but well worth it.
  14. Jun 29, 2019 at 8:19 AM
    tundraal
    tundraal New Member
    Pudge likes this.
  15. Jun 29, 2019 at 10:31 AM
    DCB500
    DCB500 New Member
    Oklahoma City
    I’ve never purchased anything from Taco Tunes so I don’t really know how they operate but I just knew they had this harness from back when I was looking for one....but $14 bucks from @james@tech12volts is obviously better than $54 from TT....so that’s a no brainer to go with him!
