Bumper cap fog light question
Discussion in '2.5 Gen Tundras (2014-2021)' started by VietGuy, Jun 29, 2019.
  1. Jun 29, 2019 at 7:00 AM
    VietGuy
    VietGuy [OP] New Member
    Houston
    2019 Tundra CrewMax Cement
    hey everyone. First I just want want to say thank you for all the good information and help I’ve received on this forum. Without this forum, my truck would of just stayed stock but who wants that? Haha... back to the main topic. I couldn’t find much information on the bumper caps. I bought a set of color matching bumper caps on spark parts and I’m stuck with an issue. The caps that I bought fits nicely but covers the bezels of the fog light housing. I tried to save my life pry with a plastic tool to get them over the caps but no go (scratched a little of the edge of the paint). Been wanting to change the foglights out to trd pro rigid ones but I don’t see that as an option anymore unless I try to cut the old ones out and push them in to take it out. Has one had this issue and can chime in for a solution? I would greatly appreciate it. Thank you!
  2. Jun 29, 2019 at 7:35 AM
    Boxer310
    Boxer310 New Member
    2018 white tundra crewmax sr5
    Bumper covers usually sit over the fog light bezels u can still upgrade the dog lights just know that the bumper covers will still sit over them which should be fine as long as the fog lights sit flush
  3. Jun 29, 2019 at 7:40 AM
    VietGuy
    Houston
    Hey boxer I tried to get the bezel out from the font but it won’t come out due to the cover being in front of it. That was my issue. I tried taking the cap back off but the adhesive on there was pretty tough. I felt like I was going to break the cap cover cap.
  4. Jun 29, 2019 at 7:42 AM
    Boxer310
    Boxer310 New Member
    Yeah the only way to remove the fog lights u need to remove the covers and the adhesive is strong so I would reccomend using a heat gun to weaken the adhesive and some alcohol but even then you would need to replace the adhesive with new double sided tape
  5. Jun 29, 2019 at 7:53 AM
    VietGuy
    Houston
    I kinda figured that was going to be the case. My other option was debating on getting the oem led foglight and replacing that from the back while the bezel is still in place or go with the baja designs one.
  6. Jun 29, 2019 at 9:17 AM
    VietGuy
    Houston
    Thanks for the heads up! I’ll keep that in mind when I decide on which fog lights to go for.
    NewImprovedRon likes this.
