Caulk on leather seats. Help
Discussion in 'General Tundra Discussion' started by Mr Swervlin, Jun 22, 2019.
  1. Jun 22, 2019 at 10:28 PM
    Mr Swervlin
    Mr Swervlin [OP] "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    What might get a small spot of caulk off my leather seat? Black leather, white caulk. I know laquor thinner will get it off but, will discolor the leather. Any ideas? Thanks
  2. Jun 22, 2019 at 10:34 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    U got a pic?
  3. Jun 22, 2019 at 10:44 PM
    NoRcptn
    NorCal
    2017 Platinum
    Warm water, a fraction of Dawn and a washcloth. Do not use goof-off of thinner on stained(colored) leather.
  4. Jun 22, 2019 at 10:59 PM
    Istvank11
    Istvank11 Shine On
    AZ
    2016 CM
    A wet rag should work
  5. Jun 22, 2019 at 11:54 PM
    Mr Swervlin
    O H I O
    I'll have to get one in the morning. It's a small spot that got smeared into the leather
  6. Jun 22, 2019 at 11:54 PM
    Mr Swervlin
    O H I O
    The wet rag trick didn't do much
  7. Jun 23, 2019 at 5:14 AM
    Danny
    Danny New Member
    2018 Tundra Crewmax SR5
    Leave it there until it becomes so dry and brittle that you can crack/rub it off
    Mr Swervlin[OP] likes this.
  8. Jun 23, 2019 at 6:13 AM
    Mr Swervlin
    O H I O
    IMAG1864.jpg pretty small spot
  9. Jun 23, 2019 at 6:48 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    3M makes a caulk remover that is safe on most surfaces but should probably be tried in an inconspicuous spot. You can get it Home Depot, Menards, Lowe's and many hardware stores. Northwoods Trapper should take it off too and it's all natural but again, try it in an inconspicuous spot first. Trapper is great stuff.
    Mr Swervlin[OP] and JohnLakeman like this.
  10. Jun 23, 2019 at 7:11 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If the caulk is latex based (which it appears to be), success with a wet rag would be certain until it dries...then, you're pretty much screwed. You can add Dawn to the mix, but I doubt that will be completely successful either now that it's dry. It will rub off a hard surface, but yours in down in the leather grain.
    You may have to start with hydrocarbon solvents, mildest first...lacquer thinner should absolutely be the last resort. Alcohol, paint thinner (mineral spirits), lacquer thinner...maybe even WD40 after the alcohol. Wet a cloth (just damp) on the tip of a finger, and stroke the caulk stain LIGHTLY until you determine if it's doing any good. If it does't seem to be removing the stain, or appears to be affecting your leather for the worse, stop stroking! Move to the next stronger solvent if no harm seems to be done. Try all solvents before using in a less visible location first.
    Silicone, you can just start getting used to it's ugly face...unless you can rub it off.
  11. Jun 23, 2019 at 8:00 AM
    Mr Swervlin
    O H I O
    Thanks for all the input fellas. I had to ask because, this is probably not going to be the last time this happens. I have a crew of guy's and working on windows and doors all day it's inevitable. I have seat covers in the back but was wanting to keep the front uncovered.
  12. Jun 23, 2019 at 8:03 AM
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    I would use mineral spirits
  13. Jun 23, 2019 at 3:13 PM
    Mr Swervlin
    O H I O
    Good looking out....I had an old man tell me to freeze the area with an ice cube then try rubbing it off with just my dry finger. I am not going to have time to address the problem till next weekend but, will report back with the outcome. Thanks again my fellow Tundra peeps
  14. Jun 29, 2019 at 5:46 AM
    Mr Swervlin
    O H I O
    OK....so...warm damp rags with soap does nothing. Alcohol did not do much. What worked for me was Lexol leather cleaner first. This got most of it. I then dabbed a small amount of mineral spirits just on the caulk that was left followed by more Lexol cleaner. Not to shabbyIMAG1868.jpg
    NewImprovedRon likes this.
