Tundra wont start after sitting
Discussion in '2nd Gen Tundras (2007-2013)' started by prodigey, Jun 26, 2019.
  1. Jun 26, 2019 at 4:22 AM
    prodigey
    prodigey [OP] New Member
    scott
    tundra
    I have a 2008 Tundra 5.7 i had some battery issues last summer truck would randomly lose power and sometimes lose charge. Had alternator tested it came back fine so purchased a new battery. Truck ran perfectly till last week i got in it and acted like it had little power key would barely crank then eventually it would start. I replcaes battery terminals and noticed the top of my battery where post is is cracked possibly from tightening battery post. Could this be my problem?
  2. Jun 26, 2019 at 5:35 AM
    Jrharvey02
    Jrharvey02 New Member
    Picture please...
  3. Jun 26, 2019 at 6:14 AM
    15whtrd
    15whtrd Mr. Blonde
    I bet your battery is a piece of shit LOL Have it tested. It happens, sometimes they just don’t last.
  4. Jun 26, 2019 at 6:35 AM
    prodigey
    scott
    tundra
    I'm currently at work I can get a pic later. its broke right below the positive post it's a Delphi max start battery wasnt real cheap but evidently not worth it
  5. Jun 26, 2019 at 6:47 AM
    Jrharvey02
    That positive lead is prolly toast now that it’s broken, it prolly has intermittent contact. You CAN redrill a post on a battery but prolly better off buying new. It always made me nervous watching somebody drill into a battery with a 1/4” bit to re tap.
  6. Jun 26, 2019 at 6:52 AM
    prodigey
    scott
    tundra
    heres a pic before I put new terminals on. the crack runs under the terminal so pic doesnt really do justice
  7. Jun 26, 2019 at 7:00 AM
    Jrharvey02
    If you over tightened terminals enough to crack the plastic, you likely disassociated the positive post from the plates within the guts of the battery...my best guess...aside from the obvious problem you’re having, a cracked battery will evaporate the water within in time and you’ll be left with dry cell(s).
  8. Jun 26, 2019 at 7:03 AM
    prodigey
    scott
    tundra
    ok that's what im.hoping my problem is. thanks for the help I'll buy a new battery today
  9. Jun 26, 2019 at 7:11 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Get a new battery.
  10. Jun 27, 2019 at 10:16 AM
    Dr_Al
    Dr_Al New Member
    Al
    Get a different brand of battery. I don't think the positive wires should put that much force on the batter to damage it like that. I've had good luck with Interstate brand.
  11. Jun 27, 2019 at 10:30 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    I'd also replace the battery terminal. It looks pretty corroded and may be part of the problem. Clean the battery cable with a wire brush and install the new connector. Then spray liberally with a terminal protector. I've had excellent luck with these two products.
    TheBeast likes this.
