Fuel pump relay question
Discussion in '1st Gen Tundras (2000-2006)' started by Sponkafide, Apr 28, 2019.
  1. Apr 28, 2019 at 6:13 PM
    Sponkafide
    Sponkafide [OP] New Member
    2004 Tundra
    Truck starting but fuel pump relay stay clicking. Flat spot when trying to accelerate
  2. Apr 28, 2019 at 6:30 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Look on the drivers fender well, there's a resistor there for the fuel pump that may be bad.
  3. Apr 28, 2019 at 6:38 PM
    Sponkafide
    2004 Tundra
    How does it look?
  4. Apr 28, 2019 at 6:52 PM
    Festerw
    Festerw New Member
    04 Tundra DC
  5. Jun 25, 2019 at 7:50 PM
    Sponkafide
    2004 Tundra
    Change my fuel pump, resistor, fuel pump relay, open circuit relay, EFI relay and my relays keep clicking.
    I ended up jumping the fuel pump circuit and open circuit and the truck starts and accelerate fine.
    Now my cruise control indicator blinks and ac compressor not coming on.
    Any suggestions?
  6. Jun 26, 2019 at 9:04 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    I have this same issue. It's feels like a slight stumble or misfire, typically when going up a hill at partial throttle, between 30-45mph. Did a google deep dive hoping it was the resistor, but a couple of posters on other said the only improvement came once they installed a new fuel pump. The resistor increases or decreases the voltage to the pump to make it spin faster or slower. Some pumps just don't behave well with at the lower voltage setting.
    Filthyphil likes this.
  7. Jun 26, 2019 at 10:45 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Speaking of fuel pumps: Anyone have a good upgraded recommendation on a replacement new one?
    I saw DD Kieth had one on his site last year for our 1st Gens, but no longer there? It was on the same page as the fuel injectors.
  8. Jun 26, 2019 at 12:51 PM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    Oem would be best walbro is a good one also.. I think when mine goes out I'm going to convert mine to outside(external) fuel pump for easier change outs and higher psi for bigger injectors..
