Removing clear protective bra
Discussion in '2nd Gen Tundras (2007-2013)' started by Recluse07, Dec 24, 2018.
  1. Dec 24, 2018 at 8:55 AM
    Recluse07
    Recluse07 [OP] New Member
    Joey
    2007 Pyrite Mica Tundra XSP TRD
    what is the best way to remove the factory clear protective bra from the hood? I started peeling it but it just breaks apart. I tried spraying goo gone on it and still it doesn’t do much. Anyone have a better method? Maybe heat gun or something similar? I added some pictures of what mine is currently doing and what it looks like.
    OR18TRD likes this.
  2. Dec 24, 2018 at 9:01 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Heat. Then maybe a 3M eraser wheel
    Stroke250 likes this.
  3. Dec 24, 2018 at 9:49 AM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    My film guy uses a steamer. There is minimal glue residue left on the surface after he lifts the film.
    OR18TRD, Stroke250 and 15whtrd like this.
  4. Dec 24, 2018 at 10:10 AM
    15whtrd
    15whtrd Mr. Blonde
    I assume the film has a life span and that’s why it’s falling apart during removal. Similar toa wrap probably 5 years. Good luck, the steamer sounds like a good idea.
    OR18TRD and NewImprovedRon like this.
  5. Dec 24, 2018 at 10:46 AM
    owb2gp
    owb2gp New Member
    ID
    I used a hair dryer on my decals to remove them. Worked great but I did this just a few months after I purchased.
  6. Dec 24, 2018 at 10:50 AM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    Steamer, hair dryer or heat gun. I use wd40 for the adhesive and it works amazingly well.
  7. Dec 25, 2018 at 10:38 AM
    Recluse07
    Joey
    I’ll try the heat gun and goo gone later and let you guys know how it goes. Do people usually re-install a new one? I understand the purpose but man, this is probably going to suck to get off..
    OR18TRD likes this.
  8. Dec 25, 2018 at 10:46 AM
    GWalker
    GWalker New Member
    North Carolina
    2014 White Tundra Double Cab Limited
    Mine was factory installed and the adhesive turned yellow in about 2 years (vehicle garage kept), mine just peeled off with no residue. I did not replace it. Considering I have a white truck, the yellowing was very noticeable, other colors will be better candidates.
  9. Dec 25, 2018 at 9:19 PM
    Recluse07
    Joey
    Yeah, I could see that is sort of has a different color to it once the light hits it. I’m sure if mine was white it would be the same way. I didn’t get a chance to mess with it today but if the heat gun doesn’t work I will definitely try a steam gun. And the same with the goo gone, if that doesn’t work I will try the WD40.
    OR18TRD likes this.
  10. Dec 26, 2018 at 1:09 PM
    Dr_Al
    Dr_Al New Member
    Al
    My '07 has them on the bed sides in front of the tires. I'm sure they are there to stop the paint from being damaged from rocks and sand. The problem is the edges now have black stuff under them. Sooner or later I'll remove them so let us know what you try and how it works out. If you use a heat gun I would be a little careful not to get the paint too hot. You may want to look into a commercial product. They do make a fake wood grain sticker remover, which is what I was going to try.
  11. Jun 24, 2019 at 10:06 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    thats factory?
