Opps. Drove straight over a 12" high x 12" diameter Tree stump
Discussion in 'General Tundra Discussion' started by triharder, Jun 20, 2019.
  1. Jun 20, 2019 at 3:23 PM
    triharder
    triharder [OP] Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    So I have a stump in my front yard that is approximately 12" diameter by 12" sticking outta the ground. (i was planning on cutting closer to the ground but haven't made the time yet)
    Last week i parked in a spot i don't typically park at the house and while leaving for work drove clean over that 12" high 12" round stump. Traveling at just outta park speeds (5 to 10 mph max) and being 5:30 in the morning I drove over it with the front left and rear left before I stopped the truck. Checked on the daughter in her car seat (she was actually smiling) and calmed my heart as I it was very unexpected. Kinda expected rim to be bent or tire damaged but both seemed fine.
    Truck appears to track straight, can't imagine anything is bent. Slight vibration at 55 mph but it was there before just not as bad as it is now (305/55/20 ridge grapplers). No pulling on highway just the slight vibration.
    the rebound after the first wheel cleared the stump made contact on the OEM step boards. Nothing seriously bent noted. (trucks on bilstien 6112s (top setting with shim on driver) and leveled in the rear)
    Should i be worried and get the truck aligned? or as my wife said "Isn't that what your truck is designed to do"
    Wish i had pictures. Its enough of a stump that had i done this in the wifes SUV it would have torn the front bumper and I could see it damaging the wheel.
    Perhaps i can get a picture this weekend.
  2. Jun 20, 2019 at 3:50 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Might be worth an alignment.... Is it pulling at all? (left/right)
  3. Jun 20, 2019 at 3:51 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Looks good, drives good, is good!
    Love the wife’s response by the way... I’d do it again just for fun (without the child in the back).
    Boerseun likes this.
  4. Jun 20, 2019 at 3:56 PM
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    Alignment checking it pulls. Other then that just balance and rotate the tires to get rid of the vibration
  5. Jun 20, 2019 at 4:17 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Just for chits and giggles look at the drive shaft coupler at rearend. An...skid plates Sir.:eek: If your worried about that viberation. :burp:
  6. Jun 20, 2019 at 8:19 PM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    Lol...I probably would have done the same at that time of the morning:bored:
    Watt maker likes this.
  7. Jun 20, 2019 at 8:58 PM
    You should be ok. Balance tires and watch tire wear for alignment issues.
    You could be this guy....
    Watt maker, jeremyd and Wrongside like this.
  8. Jun 21, 2019 at 5:58 AM
    Wrongside
    Wrongside New Member
    AB
    2016 Tundra
    Oh. Wow. That’s gotta be painful.
  9. Jun 21, 2019 at 7:13 AM
    and wet. :rofl:
    The boat ramp doesn’t forgive mistakes, that’s for sure.
  10. Jun 21, 2019 at 11:39 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Setting the parking brake wont stop that from happening...if that ramp has growth on it, bye, bye...
  11. Jun 23, 2019 at 4:55 PM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Whoever wrote that has never used a Tundra parking brake.......
  12. Jun 23, 2019 at 5:15 PM
    Radial GT
    Radial GT New Member
    Northern MN
    2019 Limited TRD CM
    Leveled, bagged camper hauler
    Same thing I was thinking, that parking brake is completely worthless.
  13. Jun 24, 2019 at 3:23 PM
    dd04tundra
    dd04tundra New Member
    david
    04 tundra 4.7
    None ......YET
