Rear 12v outlet in a 2018 Double Cab
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jim LE 1301, Jun 24, 2019.
  1. Jun 24, 2019 at 5:35 AM
    Jim LE 1301 [OP] Camaro Lover, SSEM # 11,TTC#179
    I've tried looking this up with negative results. I want to remove the rear 12 volt outlet from the rear console in a 2018 double cab. Before I start trying things I thought someone can chime in with a easy solution.
    Thanks in advance. ;)
  2. Jun 24, 2019 at 6:39 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    What do you want in its place? You wanna move it elsewhere?
    TRD-tv likes this.
  3. Jun 24, 2019 at 7:11 AM
  4. Jun 24, 2019 at 7:13 AM
    I was just wondering if I had to remove a lot of the console or just a small section.
  5. Jun 24, 2019 at 7:39 AM
    Pudge
    CT
    I know on my crewmax all I just to do was pry that back panel off. It was really easy to do. Then just wire up some connectors and I was done. Not sure if the double cab part pries off as simply
  6. Jun 24, 2019 at 7:43 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I'm with Sean - it looks similar to the Crewmax so you should just pry out and up to remove that back section.
    Pudge likes this.
  7. Jun 24, 2019 at 7:45 AM
    That's exactly what I was wondering.
    Pudge likes this.
  8. Jun 24, 2019 at 4:44 PM
    Anybody?
  9. Jun 24, 2019 at 5:13 PM
    styx
    styx New Member
    Larry
    Knoxville, TN
    2017 SR5 DC TRD Offroad Magnetic Grey
    Raptor OEM Nerf Bars Leer Hard Tonnaeu Weathertech Vents Driver assist handle
  10. Jun 24, 2019 at 5:30 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    I think im gonna copy you on this one. Keep my daughter happy on long trips lol
  11. Jun 24, 2019 at 5:43 PM
    Exactly, both my son and daughter.
    Part should be coming tomorrow.
  12. Jun 24, 2019 at 5:44 PM
    Thanks Larry.
    How does the cup holder come out?
  13. Jun 24, 2019 at 7:15 PM
    Pudge
    CT
    The cup holder should be build into the panel that will pull off. Pry up along the blue line, there are a couple clips up there that will come undone. Then there are a few more near the red Mark's. Then you need to pull up and away (toward the back of the truck) and it should pull off. The only think holding it on at that point is the wire for the outlet. I added one of those and an additional dual usb port on my truck. I cut the second hole with a dremel and razor knife. I have an extra rectangle dual quick charge usb if you wanna add that too, just pay shipping. Took some finnese and careful cutting to get the rectangle hole for it just right just to warn you.
    I can go out tomorrow and take more pics and a video of me popping mine off and text or email it to you, if you want. I should have time in the late morning.
    kevine0001 and TRDFerguson like this.
  14. Jun 24, 2019 at 7:21 PM
    TRD-tv
    TRD-tv New Member
    OHIO
    2012 MGM Tundra TRD
    really?
    now mine IS a double cab, but also its a '12 - but it looks strikingly similar to the posted photo. i have pryed on that thing like crazy trying to hide an led wire, and i cant even pry it apart enough to slip a 16AWG wire through. not saying your wrong. youre most likely right in fact, im just an idiot. ill have to check this out tomorrow?
  15. Jun 24, 2019 at 7:23 PM
    Pudge
    CT
    Hmmmm I bet the 2nd gens are different. Probably some bolts inside the console. I was shocked mine pried off like it did. I was fully expecting to have to take apart half the console and remove the lid and all that.
    TRD-tv[QUOTED] likes this.
  16. Jun 24, 2019 at 7:59 PM
    Thanks Sean, I will try it tomorrow.
    I'll let you know about the other USB, but I think the one I'm putting in is enough.
    Pudge[QUOTED] likes this.
  17. Jun 25, 2019 at 11:32 AM
    Amazon delivered it about 2 hours ago. All done took me about 30 minutes to do install.
    Sean you were correct. I just pryed up the top (blue lines in your pictures) then just pulled straight up.
    Instead of cutting wires I made like a jumper with a inline fuse to plug int the factory plug. So when I trade it in for the TRD PRO I can just unplug and remove mine and put back the original.
    20190624_082214.jpg 20190625_130441.jpg 20190625_130557.jpg 20190625_130653.jpg 20190625_130713.jpg 20190625_130752.jpg 20190625_133329.jpg 20190625_135832.jpg 20190625_140147.jpg 20190625_140501.jpg
  18. Jun 25, 2019 at 1:01 PM
    Pudge
    CT
    Nice job Jim. Great cheap and easy mod
  19. Jun 25, 2019 at 2:30 PM
    Thanks Sean. Now the kids will be happy on the next 2 trips.
  20. Jun 25, 2019 at 4:17 PM
    Pudge
    CT
    Proud of ya buddy. And it'll certainly be a life saver
    Jim LE 1301[OP] likes this.
  21. Jun 25, 2019 at 5:12 PM
    Thanks Sean.
  22. Jul 2, 2019 at 9:32 AM
    West Texas Tundra
    West Texas Tundra 2016 Bronze Beast
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    20 inch CECO wheels Drop in K&N air filter 2 inch front leveling kit
    Anyone ever upgrade the front USB port?
  23. Jul 4, 2019 at 8:42 AM
    Grnjetta6
    Grnjetta6 New Member
    Darin
    Hudson Valley New York
    2018 Cement TRD Off Road DC
    West Texas Tundra likes this.
