Diff Breather
Discussion in '1st Gen Tundras (2000-2006)' started by remington351, Apr 22, 2019.
  1. Apr 23, 2019 at 7:11 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    A proper bidirectional seal should not depend on DP to seal. The diff breather is nothing but a relief valve. The axel seals should keep the inside in and the outside out without assistance. If the differential can heat up enough to overcome the seal, then the answer would be to vent it hence the relief valve. But a relief valve that creates a DP that overcomes the seals keeping the external pressure out is kind of stupid. As is a poorly constructed check/relief valve for the environment. I don't normally question the designer's intentions, not true because I have designers working for me, not in the automotive industry, but in this case... using a check valve to regulate internal pressure in a vulnerable area that can allow internal contamination doesn't make sense. Thus the diff breather mod.
    Aerindel, 15whtrd and dcsleeper408 like this.
  2. Apr 23, 2019 at 7:21 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    :thumbsup:
  3. Apr 24, 2019 at 12:30 AM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    I changed my diff fluids today and the rear diff hissed quite a bit when I removed the fill plug. Guess I need to order some breathers.
  4. Apr 24, 2019 at 11:54 AM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    I have not heard anyone mention oil viscosity and heat affects in your discussion re the expanding and contracting diff oil :) What if the oil thins when heated, the rotating gears cavitate the oil which causes air to be introduced into the oil thus creating an expansion and contraction during heating and then cooling?
  5. Apr 24, 2019 at 12:04 PM
    Wiscdave
    Wiscdave New Member
    Northern Wisconsin
    19 Tundra Sport
    Old ride 13 RW BA budget, 3/2 lift JL W7
    Do the diff breather mod and be done with it...
    mtntop likes this.
  6. Apr 24, 2019 at 1:19 PM
    remington351
    remington351 [OP] New Member
    2006 SR5 DoubleCab
    I did some more Googling last night and found posts by Land Cruisers, 4Runners, Tacoma's and others that also held discussions about the one way vent, pressure, temperature, thermodynamics, but sadly, no discussion of enchiladas. I also found a post in an industrial group discussion on shaft seals (Kalsi Engineering rotary shaft seal) consideration that mentioned maintaining a slight overpressure on the lubricated side of the shaft allows some beveled seals to "rotate along the shaft axis, thereby reducing the seal shaft interface for lower friction and longer seal life". Whether our seals are of such design is unknown and not worth my time to research.
    Otherwise, the off roading, mudder, yee-haw, boat trailering crowd all echoed the same concern/problem, hot axle housing suddenly immersed in cool water, mud, baby oil, or other liquid was a recipe to contaminate the gear oil due to the thermodynamic effects already discussed. If you mudd, boat, drive into your neighbors pool, do the breather mod. If not, you're probably fine replacing the oem vent every 10 years to avoid a corrosion induced vent lock.
    Good discussion.
    JMB and Professional Hand Model like this.
  7. Apr 24, 2019 at 1:47 PM
    Fred
    Hand Protectors
    So my food container seals work as designed! Yay!!!
  8. Apr 24, 2019 at 2:14 PM
    JMB
    Chesapeake, VA
    Do you keep enchiladas in them?
  9. Apr 24, 2019 at 2:29 PM
    Fred
    Hand Protectors
    Last meal I had out of that container was a combination of an Easter Ham slice, leftover restaurant linguine with Francese sauce topped with Mama Hand Models homemade green bean simmered in pork fat.
    Heated in a microwave for 2 minutes and eaten with a gas station plastic fork.
    bmf4069 and JMB[QUOTED] like this.
  10. Apr 24, 2019 at 2:50 PM
    15whtrd
    15whtrd Mr. Blonde
    I’m almost certain it only lets air out not air in.
    Casper421 likes this.
  11. Apr 24, 2019 at 4:58 PM
    JMB
    Chesapeake, VA
    Yum!
  12. Jun 23, 2019 at 4:11 PM
    msbaugh440
    msbaugh440 2019 limited, TRD package, cement
    Utah
    2019 Tundra limited, TRD off road, Cement
    Sounds like the best option is to design a hose extension with a dual pressure/vacuum vent design.
    Leave the stock overpressure valve on the extension, then T off the same breather line with a vacuum vent. It would be similar to having both the stock valve on AND a similar stock valve but flipped around backwards. You would want to design the backwards vacuum vent so that it only lets air in at or right below atmospheric pressure though.
    My guess is you would want internal pressure anywhere between 14.7 psi to whatever the current stock valve set point is. But then at altitude pressure is a little lower (where I live it’s 12.4 psi) so it would vary. This could all be a moot point though, because you would actually want to design the new inbreathing set point to a % psi above the failure point of the seals (assuming that even is your first point of water ingress and not the pumpkin seal).
    But then again we’re overthinking it, just swap your gear oil a couple days after deep water crossings!
